M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      03-26-2013, 08:32 AM   #1
nybimmerfan
nybimmerfan's Avatar
Drives: 6-Spd Manual MCB M5
Prescribed tire pressure
Guys what are the prescribed tire pressure for the front and rear tires for the 2013 M5? I can't find anything in the manual that actually tells in PSI what the recommended tire pressure should be for the front and rear tiers. The manual only tells about loss in tire pressure which will be indicated in the monitor.
      03-26-2013, 09:25 AM   #2
AGS
AGS's Avatar
501
Drives: 2022 M5 Competition
Look inside the driver's door on the sill. There's a psi chart. I'd do it for you but my car is at the train station in another state!
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      03-26-2013, 12:13 PM   #3
nybimmerfan
I did look but just wanted to confirm what would be written in the manual whether or not it conforms with the tag. On the tag it states 32 PSI for all 4 tires both front and rear. I thought normal car settings would have the front tires' psi different from the rear. TPMS shows I currently have the front tires at 32.3/31.5 and rear tires as 29.5/29.6.
      03-26-2013, 12:47 PM   #4
johntomferg
Drives: Formerly drove a 13 F10 M5
nybimmerfan - I'm pretty sure there is information in the paper manual. I remember specific language about if going over 100MPH for extended periods that you need to have the tire pressure at a larger value (40 PSI???) vs the lower. If you still can't find, I'll pull my manual out at the house tonight (didn't drive the car today).
      03-26-2013, 12:57 PM   #5
AGS
AGS's Avatar
501
Check page 168 of the owner's manual. It has recommended front and rear pressure for both under and over 100 mph.
      03-26-2013, 01:21 PM   #6
bobblehead
bobblehead's Avatar
Drives: warp speed
did not go with the manual figures. My jamb says 35 psi all around. But still, after having driven for about 2000km, I noticed the tire wear on the middle wears faster than on either side, I am now lowering it to 33 psi all around, hoping to have them wear evenly.
      03-26-2013, 03:49 PM   #7
nybimmerfan
Thanks AGS. For some reason, on my BMW M5 SEDAN owner's manual that info is on page 166 not 168. I will set the tire pressure accordingly. Thanks all for your help.
      03-26-2013, 05:53 PM   #8
AGS
AGS's Avatar
501
No problem.
It's pasted from the online version I downloaded from the BMW website. There must be some slight revisions to the printed version included with the car.
      03-27-2013, 07:48 AM   #9
johntomferg
Here is the door jamb for reference.
      03-28-2013, 05:56 PM   #10
dr.skp.ortho
dr.skp.ortho's Avatar
Australia
15
Drives: 991 911 Carrera S, F06 M6 GC
Run 41PSI/280KPa. Who doesn't go over 100MPH/160KMH in this car relatively often?!?!
Porsche 991 911 Carrera S
BMW F06 M6 Gran Coupe
BMW F15 X5 5.0 Xdrive M Sport.
Mercedes C250
      04-02-2013, 06:12 PM   #11
DietCokeOfEvil
DietCokeOfEvil's Avatar
11
Drives: F10 M5
In AZ, on our warmer and fast roads, my dealer always fills the 20" up to 37.5 PSI this past "winter".
      01-06-2017, 03:23 PM   #12
steeve13m
Drives: F10 M5
I use 36/37psi but the rear R888 tires did wear out more on the inside/middle vs both outside edges so maybe 34 rears is best I drive 140mph+ daily
High 40+ psi is risky in wet conditions for traction
2019 F90 M5 Competition - Marina bay Blue Pearl - Executive and Bowers & Wilkins package
Gone:2013 F10 M5-DCT-Montecarlo Pearl Blue-BBMR 800 Stage 1 system 700whp+(93oct)
2004 Lamborghini Gallardo-Manual-Giallo Midas Pearl Yellow-Modified
2018 Range Rover Velar S-White
m5post
