02-01-2013, 03:19 PM | #1 |
432
Rep 4,650
♦ Sonic MS | Ohlins R&T Coilover System for the E9X M3
Sonic Motorsports 1045 West El Camino Real Mountain View, CA 94040 tel: 650-733-6506 fax: 650-691-9009 email: info@sonicms.net We at Sonic MS are proud to present Ohlin's new Road & Track Performance Coilover System for the BMW E9X M3. Long anticipated but well worth the wait, these R&T coilovers are a culmination of over 30 years of long tradition of high end racing commitments and state of the art solutions within advanced suspension technology. The focus has been clear from the very beginning - superior road handling without sacrificing comfort in your day to day driving. Ohlins has also added a clever lightweight design with a majority of the parts in aluminum and on top of all that, the shocks have been put through vast corrosion tests according to Global ISO 9227 standards. This product comes with a 2 year standard limited warranty. Feature Benefit Summary: - DFV (Dual Flow Valve) - Rebuildable - Corrosion salt spray tested (ISO 9227) - 2 Year Limited Warranty Front Units: - McPherson Struts w/ Single bleed adjuster - Spring preload adjuster (15mm lower than standard) - Coil Springs (60N/mm) - Dustcovers - Use with original top mounts Rear Units: - Conventional Shock Absorber - Single bleed adjuster - Separate spring preload adjuster (10mm lower than standard) - Coil Springs (120N/mm) - Dustcovers - Use with original top mounts Note - cars equipped with EDC requires the EDC delete kit (MFG PN 35020-01) MSRP Pricing: $3159.00 *Price listed does not include shipping and/or taxes (CA 8.25%) if applicable. For best pricing and ordering information, please email at cal@sonicms.net or send me a PM. |
03-18-2013, 12:27 PM | #4 |
///M
161
Rep 1,867
I think its time to upgrade my KW SLEEVE
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI |
04-16-2013, 01:19 PM | #7 |
///M
161
Rep 1,867
Are these bad boy still on back order?
