M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      12-15-2012, 06:32 PM   #1
bowen600
Drives: 2013 silverstone M5
10W30
Was wondering if I can use this oil on and off with the recommended 5W30.
I inadvertantly reversed these grades in a post last week.
What do you think/
      12-15-2012, 09:51 PM   #2
bradone1
BMW Extraordinaire
Drives: 2019 X7 M Sport, 2015 M4 Vert
Shouldn't be a big issue but it should be LL01 approved oil. That is the key.
      12-19-2012, 07:51 PM   #3
bowen600
What's LL01. Seems dumb to have to ask.
Bob
      12-20-2012, 05:55 AM   #4
bobblehead
bobblehead's Avatar
Drives: warp speed
http://www.bimmerfile.com/wp-content...hetic-oils.pdf
LL01 is the 2001 BMW certification
      12-21-2012, 05:36 PM   #5
bowen600
Thanks. Guess I'll just stick to 5W30
      01-02-2013, 02:52 PM   #6
nybimmerfan
nybimmerfan's Avatar
Drives: 6-Spd Manual MCB M5
Originally Posted by bobblehead View Post
That pdf recommends a somewhat different rating than the M5 manual. The manual that comes with the 2013 M5 (page 177) recommends engine oil viscosity grades SAE 0W-30 or SAE 0W-40 and alternatively SAE 5W-30 or SAE 5W-40. Whereas on that pdf, recommendation is as follows:
The following is the only recommended and approved synthetic oil for BMW M
(Motorsport) vehicles in the US market with gasoline engines, at the present time.
BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles
equipped with S54, S62, S65 or S85 engines
Castrol TWS Motorsport SAE 10W-60 Synthetic Engine Oil, or
Castrol Formula RS SAE 10W-60 Synthetic Engine Oil
(BMW part number 07 51 0 009 420)
So, what correct viscosity should be followed? I would go with what the manual says as that pdf may be obsolete.
      01-02-2013, 03:30 PM   #7
bobblehead
bobblehead's Avatar
Drives: warp speed
Do the F10 m5 manual ...
All the (North American) bmw dealers are using the 5w30.
      01-02-2013, 09:14 PM   #8
Netwon
Netwon's Avatar
Drives: '12 BMW M5 Alpine White
2012 BMW M5  [0.00]
Obsolete... M5/M6 engine code is S65tu. Engine is different from X5M.... What is the date on the pdf?
      01-03-2013, 10:36 AM   #9
Ak3249
Ak3249's Avatar
13
Drives: BMW F12 M6 Cab
I work at a BMW service center and also have an f12 m6. I know for a fact that 5w-30 is the recommend oil for the tri-state area.
      01-04-2013, 05:34 PM   #10
Head
Head's Avatar
20
Drives: RRS Supercharged / 991 Turbo S
Oil Spec...
Here in New Zealand the spec for F10 M5 is Castrol Edge BMW LL01 5-30w. Trust this helps.
Cheers
Craig
      01-14-2013, 04:26 AM   #11
PappSchlumpf
Drives: M5 F10
Cheers
Craig
Here in Luxembourg it was Castrol BMW LL01 0W30
      01-28-2013, 09:45 AM   #12
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
oil spec
Just had my 1st service today. Dealer insisted that correct spec is 10W-60, & that's what they filled into my engine (Castrol TWS Motorsport SAE 10W-60), no matter what I said.
Not sure what i should do now ? What harm will it do to the engine if keeping it running with 10W-60?
      01-28-2013, 10:10 AM   #13
nybimmerfan
Did you check the manual that came with your M5 MY? For my 2013 M5, the manual that came with it on page 177, it recommends engine oil viscosity grades SAE 0W-30 or SAE 0W-40 and alternatively SAE 5W-30 or SAE 5W-40.
      01-28-2013, 11:24 AM   #14
bobblehead
bobblehead's Avatar
Drives: warp speed
If I were you, better drain that oil and do it yourself (buy the oil yourself) right away. 10w60 is for N.A V8 ... hopefully, no long term issue down the road.
      01-28-2013, 07:38 PM   #15
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
If it's their mistake, they should replace the oil for me, but the problem is, I have to prove them wrong first. Is there any official document (other than the oil recommended list) to support this?
      01-28-2013, 08:06 PM   #16
bobblehead
bobblehead's Avatar
Drives: warp speed
For NA & Europe & Australia ... none mentioned 10w60. 0w30/0w40 ; 5w30/5w40
see page 179 on the owners manual.
http://f10.m5post.com/forums/showthread.php?t=762582
      01-28-2013, 09:46 PM   #17
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
Yes, I know. It says so in the printed manual as well as the on-board digital one. I actually showed it to the BMW people, but they still said it's 10-60W from their internal record.
      01-29-2013, 12:11 AM   #18
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
Any other member in HK can share what engine oil you have for your F10 M5 & whether BMW changed the differential fluid during 2000 km service (mine not changed) ?
      01-29-2013, 01:21 AM   #19
aus
Drives: Odysse
Dude, drain the oil ASAP and sell it to the E60 M5 or E9x M3 guys!!
Your dealer SUCKS BALLZ!!!
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      01-29-2013, 04:57 AM   #20
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
0W-40
After all the hassles, the dealer finally got back to me, saying the correct oil spec for F10 M5 in the region should be 0W-40. They will drain the 10W-60 & refill with 0W-40 for free.
Yes, they suck big time. It's just ridiculous for the dealer to have an owner tell them what the correct oil spec should be.
Thanks to you guys & the forum for the extensive info sharing.
      01-29-2013, 06:09 AM   #21
bobblehead
bobblehead's Avatar
Drives: warp speed
for the 2000km first service, your dealer is required to change to rear diff fluid as well. (If you have a manul tranny, then it is also to be changed)
Another major screw up ! you better bring this up with the GM of the dealership of how incompetent the service people are.
      01-29-2013, 09:33 AM   #22
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
will talk to them again about missing differential oil change. damn!
what else should have included in the 1st service? some kind of ECU activation (launch control activation)? How to tell if they Did that or not?
m5post
