12-22-2011, 02:01 PM | #1 |
Supreme Allied Commander
3848
Rep 54,378
Drives: F80 M3
StopTech Racing STR High Performance Brake Fluid
Like all StopTech products, StopTech High Performance Brake Fluid is carefully designed to give drivers an edge in the punishing world of high performance motoring. For over a decade StopTech has engineered and delivered race- and championship-winning brake components and systems for high performance street driving as well as pure racing. StopTech High Performance Brake Fluid adds a new dimension to the company’s offerings.
Available in STR-600 and STR-660 formulations for high performance street and racing applications respectively, the new StopTech High Performance Brake Fluid is a DOT 4 motor vehicle brake fluid, engineered to optimize brake system performance at high operating temperatures. In addition to guarding against boiling and subsequent loss of efficiency at severe racing temperatures, StopTech Brake Fluid maintains its excellent viscosity, lubricity and non-compressibility. StopTech Racing Brake Fluid stands out not just for its exceptional performance, but also for its stylish and functional packaging. StopTech Brake Fluid comes bottled in a special metal container that is not only more durable, but also gives the fluid up to 25 percent longer shelf life than typical plastic bottles provide. Both in looks and in performance, StopTech Brake Fluid stands out from the crowd. StopTech® High Performance Brake Fluid conforms to and exceeds the current specification of U.S. FMVSS 116 (§ 571.116) DOT 4, is road legal, and compatible with modern ABS and other vehicle dynamic control systems. StopTech brake fluid is mixable with all DOT 3 and 4 products. StopTech STR-600 High Performance Street Brake Fluid - $16.99 Typical Dry Boiling Point: 594°F (312°C) Typical Wet Boiling Point: 404°F (206°C) Minimum Wet Boiling Point: 383°F (195°C) 500mL metal container gives fluid a 25% longer shelf life Part Number: 501.00001 StopTech STR-660 Ultra Performance Race Brake Fluid - $27.99 Typical Dry Boiling Point: 622°F (328°C) Typical Wet Boiling Point: 404°F (206°C) Minimum Wet Boiling Point: 383°F (195°C) 500mL metal container gives fluid a 25% longer shelf life Part Number: 501.00002 ORDER HERE: http://www.hpashop.com/StopTech-Raci...?categoryId=-1 |
10-05-2012, 04:11 PM | #2 |
Rep 219
Is one 500ml bottle enough for my shop to perform a brake fluid flush?
2011 E90 M3 | Space Gray | RKP CF Roof | MPerf Recaro | Full Interior CF & Alcantara | BMW MPE v2, MS Test Pipes | BPM Tune | MFactory CF DS | Bilstein B6 Damptronic | Full DINAN & Eventuri & DO88 | Modesta BC-04 | Potenza RE-71R
2020 X3M 2020 Range Rover Sport SVR |
10-05-2012, 05:30 PM | #3 |
3848
Rep 54,378
Drives: F80 M3
