10-27-2011, 01:31 PM | #1 |
Rep 868
M3pnoy e90 m3 build thread, *update ess installed* page 6
Brief overview of mods as of 3/11/12:
Cosmetics- Front bumper-Shaved reflectors, shaved headlight spout Gloss Black grills Gloss Black side grills Slon Workshop CF 1x1 Roof Lci tail lights Lci trunk Vorsteiner diffuser Brakes: Brembo 380 mm Front slotted kit in red Brembo 380 mm Rear slotted kit in red Interior: Single hump no idrive conversion M-performance alcantara steering wheel P3 vent boost gauge Suspension- Bilstein B16 damptronic coilovers with ground control camber plates Engine- ESS VT2-600 with Flash Cable Wheels BBS LM's (Summer setup) LM225DSPK 5x120 20x9 et3 (reverse lip) LM232DSPK 5x120 20x10.5 et15 Hankook v12's 245/30/20 Hankook v12's 295/25/20 BBS 80 MM Studs Kics r40 Gunmetal lugs Exhaust: Akrapovic e90 full evo system, titanium tips and cf tips If you didnt see my first introduction in the metro thread, the following is the link: http://www.m3post.com/forums/showthread.php?t=600975 I know i said i wouldn't mod this vehicle as it is my daily, but i couldnt resist after only less then a month of ownership. Figured i would start a build thread. The following is when i picked up my alpine white e90 m3 on 10/3: Here it is in the background along with my recently sold e46 m3, After getting the vehicle, i sent it directly to the bodyshop to get the orange reflectors shaved along with the headlight washers, i also got the front and side grills painted a gloss black to match the gloss the trim, the following is the outcome of that bodywork: After the bodywork, i thought i was done, and was going to put my volk le-37's from my old bmw but then i found a great deal on a set of BBS lm's in 20's nonetheless, if anybody close that knows me, ive had close to every brand of wheels and the LM's have always been my dream wheels, but have somehow eluded me, the following are pics and specs of the lm's, as you can see these are the Lm's with the more aggressive rear: LM225DSPK 5x120 20x9 et15 LM232DSPK 5x120 20x10.5 et15 Hankook v12's 245/30/20 Hankook v12's 285/30/20 The following are pics of them on the car: As you can see it looks like a 4x4, , since i want to keep edc, i went with the kw sleeve over kit, that has yet to be installed, pics will follow. I also was able to purchase the last set of 80mm bbs studs in the country and will be using my gunmetal kics r40 along with them. Here is my update 11/2: Left work early to catch UPS guy but he ended up leaving these 4 boxes at my doorstep and dropped these babies off.. After i loaded up the car, i rushed over to my friends shop and got these installed... Unpacking brand new, KW sleeve over kit First pic of front 6 piston brembo caliper... pic of installing kw sleeve over kit over shock Pic of Kw sleeve over kit and pic of 6 piston front caliper and 4 piston rear caliper in background, sorry for crappy phone pic again... Front Kw sleeve over kit, Brembos, and BBS 80mm studs done... Sorry didnt get pics of the rear brembo setup, jeff "e92 m3" had arrived to check out some parts and I was busy checkin out his AW// ess supercharged beauty... Nways, here are the last 3 pics i have for now, sorry for the dirty car, havent had time to give it a wash , i am on the lowest possible setting on the kw's... Jeffs sick "e92 m3" supercharged m3 in background... 12/11 update: Gettin ready for winter so decided to take off the Lm's and put on my winter wheels: 19 inch zcp reps courtesy of Eric and Tam at supreme power mounted on Bridgestone blizzaks 245/40/19 and 275/35/19. Reason i went with 19's was because i was limited in the selection of winter wheels that cleared my brembo 380/380 kit. And reason i went with reps is because im saving up for that bigger purchase in the spring Following are pics off my phone: 2/7 update: Well its been a good winter so far in terms of not having a lot of snowstorms in the northeast, but its also been a good winter for modding, After much research and deliberations i went with the ESS Vt2-600 kit, customer service from roman@ess has been bar none fantastic as he answered all my questions and was patient with all the questions i had regarding the kit. If you know me from the s2k forums, ive dealt with a lot of vendors and roman is on the top of my list for great customer service. I also have to thank izzy@img who made this kit happen, and that i needed this kit like "oxygen" i truly did, he showed me the light, thank you bro. I also gotta thank, well maybe not since he put a hole in my pocket , jk, my good friend gixxer_kidd, thai. If you dont remember our 20 inch lm shoot back in november i was the only non-supercharged car the following is the link: http://www.m3post.com/forums/showthread.php?t=616650 I didnt want to drive his supercharged car because i knew i would have to have this kit, well lone and behold i had to drive his car at times during the shoot as he was shooting our cars. After that meetup and talkin with chris and jeff also about there ess kits, supercharging my car sparked/ignited a light in my mind Well fast forward to this day, and a ess vt2-600 kit is on my front step courtesy of fedex, , here are a couple pics for now, still need to get manifold painted and hoping to do install this week: Heres also a pic of a little project me, thai, and our good buddy jesse did over the winter, used 3m gloss black vinyl: 2/26 update: Update as of 2/26: SC is awaiting install still as my plenum is still with painter, as he had some personal health issues to take care of, but in the mean time decided to do other things to car,: Heres one pic all for just this fox red extended leather what was once novillo black is now fox red extended leather, Decided also to upgrade my tail lights to LCI and also find a karbonwerke trunk, couldn't find a Karbonwerke trunk but found a trunk similar, fitment i would give an 8/10: While i also wait for my plenum anxiously, i decide to install my p3 enhanced vent boost gauge, fit and finish is awesome, and looks oem: Last but not least, i just picked up this piece, Innotech f1 full valved system for e90, havent installed it yet, but will give my impressions once installed: 3/11 update: Vorsteiner diffuser 3/30 update: 4/10 update: Brand spankin new OEM clutch/flywheel S/C housing powdercoated gloss black Pic of intercooler Pic of filter: Pic of blower/plenum installed: Stay tuned for upcoming pics and updates... Last edited by Yea Boi; 06-16-2021 at 08:23 AM.. |
10-27-2011, 01:45 PM | #3 |
Rep 2,491
Drives: 991 C2S Guards Red
LMs look great on AW... really beautiful E90! Can't wait to see the KWs mounted too
991.1 C2S PDK, Guards Red | PDCC | Sport Chrono + | Clear Tail Lights | Alcantara Steering Wheel | HRE FF01 | TechArt Springs | Sport Exhaust
Previous: Porsche 997 Turbo 6MT, Atlas Gray | Cobb Stage 2 | HRE FF01 | Europipe Stg. 2 Exhaust | GMG LMS Rollbar | GT2 Exhaust Tips | Pagid RS-29 | Rennline Pedals | SSK 997.2 Track Car, heavily modded & E92 M3 DCT, still miss her daily & E92 335i heavily modded |
10-27-2011, 01:48 PM | #4 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Good stuff
10-27-2011, 02:05 PM | #6 |
Rep 2,829
Drives: E36M,E46M,E90M,X5M,i3,M2,i8
looking good
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
10-27-2011, 02:59 PM | #11 |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
Looking good pare!!! Nothing can ever beat the classic look of BBS LMs.
WHOA!!! Happy Belated!! Hopefully you had a good one!
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
10-27-2011, 03:16 PM | #12 |
Rep 1,339
OY! looks good
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
10-27-2011, 09:41 PM | #15 |
Rep 1,461
ha, I should of made a bet with you. excited to see what else you have in store....oh wait, I already know...won't spoil it for the rest...lol
10-27-2011, 10:03 PM | #16 |
Rep 922
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package '11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery) |
10-27-2011, 10:48 PM | #17 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
Off to a good start!
