BMW M3 Forum (E90 E92)
      07-12-2010, 02:30 AM   #1
ducman
Drives: E92 M3
DIY: No Holes Front License Plate (no tow hook)
I didn't come up with this clean, cheap, yet very effective solution to a front license plate with no holes. Since it took a while to search and find these posts, I'm going to link them all here.
The original post by khaye1: http://www.e90post.com/forums/showthread.php?t=374893
Here's a pic of my fake plate (still waiting for the real one).
What you need?
1. Bell / adjustable license plate mounting bracket from Autozone...$8.99
2. Two (big yet small hole) washers from Home Depot...$0.40
3. Might need some padding on the back of your license plate so that they don't scratch the bumper (I haven't got to this part yet since I have fake 'plastic' plate).
I was able to pop off part of the bottom grill but it was still too much trouble to put on the washer. So I had to take off the bumper which was a pain in the ass to put back on but it was so worth for a noob like me. You might need a 2nd pair of hands for this. Here's the DIY for the front bumper removal: http://www.m3post.com/forums/showpos...69&postcount=3
You do not have to take off the full bumper. I recommend taking off the passenger or driver side part of the bumper to place your arms behind it. It's pretty easy from their on.
If you don't want to take the bumper off, then you can drill the bottom of it like frankie did in his post: http://www.e90post.com/forums/showthread.php?t=378549
      07-29-2010, 08:23 AM   #2
Frozen grey
CEO
Frozen grey's Avatar
Drives: 2011 frozen grey M3
Here's a easy fix what I did not havin to mess with takin things apart.
Just take the nut and washer & solder them together with acid core solder & small torch, than solder small wire , I used baling wire to the washer bend wire to feed throught back side of grill attach bolt from front and than trim wire & bend out of sight and there u go easy hope this helps!
Mark B.
      05-20-2011, 07:23 AM   #3
MDyDinanM
OIF Veteran
MDyDinanM's Avatar
Drives: ///M
2008 BMW M5  [6.88]
if you really wanted to be extreme, you could take off your front bumper, put magnets on the back side where the license plate would be. Then put magnets on the license plate.
This way you have a magnet plate mount, and can remove the license plate anytime you want.
Retired: '06 BMW E46 ///M3
Current: '08 BMW E60 DINAN ///M5, Interlagos Blue, SMG
DINAN Stage 2 Suspension, Exhaust, Stage III Software, Front strut braces,
Intakes, 13% Underdrive pulley, 3.91 Differential, RPI Scoops.
      05-21-2011, 12:15 AM   #4
JCtx
Drives: No BMW yet
Just use the original bracket people. It's secured with 2 bolts under the bumper, completely invisible. And rather than drilling the bumper for the upper 2 bolts, just put double-sided tape behind the bracket and it won't go anywhere. Or bang anywhere. And it already comes body-colored .
      06-05-2011, 06:31 PM   #5
Brucewonder
Brucewonder's Avatar
33
Drives: 2011 E92 M3 yea boi
i just use double sided tape on my previous car for fix-it tickets and euro plates back then
      08-07-2012, 02:00 PM   #6
Ohh_5H1T
Ohh_5H1T's Avatar
58
Drives: Backwards
What you need?
Really helpful! i like all these options! thank you!
      08-07-2012, 02:01 PM   #7
Ohh_5H1T
Ohh_5H1T's Avatar
58
Drives: Backwards
Someone had suggested this but i didnt want to go through removing that bumper again. Its a pain in the ass. (had to remove it to wrap it).
      08-07-2012, 02:26 PM   #8
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
This will be the method I use, if I have to succumb to a front plate. It's required here, but I'm not running one right now. How do these under-bumper bolts typically secure to the bumper? Self-tapping screws? I have the front bracket, but I don't think any screws.
      05-21-2013, 06:37 PM   #9
jwaggen
jwaggen's Avatar
Drives: E92 M3 6MT ZCP
Anyone know whether removing the front kidney grille(s) will allow for a hand to go reach down and position the rear washer/nuts?
E92 M3 6MT ZCP
      05-22-2013, 07:38 PM   #10
crunchy_frog
crunchy_frog's Avatar
Drives: 2008 E92 M3
i think it would be easier to use spring toggle wing bolts and insert them thru the holes in the mesh instead of taking apart the grill or bumper.
https://www.google.ca/search?q=Sprin...-a&channel=rcs
      05-22-2013, 07:46 PM   #11
jwaggen
jwaggen's Avatar
Great idea! I hope this works without too much wobbling...
E92 M3 6MT ZCP
      05-23-2013, 07:35 AM   #12
hdoc2005
hdoc2005's Avatar
Drives: Grey '11 E90 M3
nicely done! thanks for sharing
m3post
