12-20-2009, 01:31 PM | #1 |
Rep 12
Lux H8 install question?
The space on the right side is very limited for the H8 install.
Short of removing alot of the surrounding plastics,does anyone have any suggestions? Thanks |
12-20-2009, 01:48 PM | #2 |
Rep 1,895
I dropped the wide part down first and them reached in & guided it up pulling the wires with one hand & my fingers pushing the bulb into the opening. I marked the metal part with a grease pencil so I knew where it lined up. Once in the opening, I got a couple fingers in to turn it tight. GL -
12-20-2009, 08:17 PM | #3 | |
Naval Aviator
599
Rep 676
So... I looked around the garage for possible alternative tools to assist. Actually, I used a small padded pipe wrench to securely hold the light unit while supporting the rear with a flat, slightly curved tool called a spanner (used to adjust motorcycle suspension settings). Using these in combination allowed line-up and alignment of the notches and a means to securely turn the unit until tight. A neighbor stopped by and said it looked like surgery. ...it definitely takes some patience.
e92 M3 - Interlagos Blue | Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II E85; SuperSprint F1s; Cat-less Bomiz X-Pipe; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK |
01-07-2010, 03:34 AM | #4 |
Rep 1
well yes it requires some patience....
01-07-2010, 03:30 PM | #6 |
Sauce
75
Rep 2,023
The drivers side I did ok, in about 5 minutes or so. The passanegr side was a total fucking bitch and I cut up my hand pretty bad. There is no trick, just play with it, you'll get it in.
2009 E90 M3 | Silverstone II | Black Novillo | HRE P40's | Akrapovic Exhaust | Eibach Pro Kit | Jet Black Kidney Grilles | SSII Side Reflectors | SSII Side Gills | LUX H8 Angel Eyes | Macht Schnell Filter | Tecnocraft Envy Charge Pipe
"M3 drivers have no friends." - Jeremy Clarkson |
01-07-2010, 06:02 PM | #7 |
Rep 2,339
Is this something that could be made easier by just removing the entire light housing from the car or is the problem within the housing itself?
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
01-07-2010, 08:44 PM | #8 |
Rep 5,842
Drives: 2006 325xi
Nope - taking the headlight out of the car would require 2-3 hours of work. It really will only take about 5 minutes to get it in place. you just need a bit of patience
