BMW M3 Forum (E90 E92)
      04-10-2009, 10:37 PM   #1
kmarei
kmarei's Avatar
Egypt
688
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
Easy Corner delete for M3!!!
basically what we are doing
is getting the wire that goes to the bulb
and putting a relay in the middle
so when the turn signals are getting 2.5v, when they are turned on with DRL, the bulb is disconnected (i.e relay off, bulb not lit)
but when you use your turn signals, the 12v goes to the bulb (i.e relay on, bulb flashing orange)
Ok here goes!
Parts list (radio shack)
1) 2x item 275-248 (12VDC/125VAC 10A SPDT Mini Relay)
http://www.radioshack.com/product/in...ductId=2062482
2) 2x item 276-1144 (3-Amp Barrel Diodes)
http://www.radioshack.com/product/in...ductId=2062579
3) 1x Item 271-153 (2 pack of 1W 1K ohm Resistors)
http://www.radioshack.com/product/in...ductId=2062296
4) 4x 5.6 ohm 25W resistors
i got mine from ebay from this seller
http://cgi.ebay.com/5-6-ohm-25W-Powe...3286.m20.l1116
first step is to extract the wire going to the turn signal from inside the headlight (white wire on both sides headlights)
that goes to the red/yellow points in the diagram
the wire you just extracted goes to the white point in diagram
now follow this wiring guide
the 2 resistors are wired in parallel (meaning just twist the 2 wires from one side of each, then do the same for the other side)
1 diode and 1 resistor are wired in series.
with the diode, the striped line should be connected to the red point, then the 1K ohm resisor is connected to the black point.
so it goes like this
red point---[|diode]--[resistor]--black point
that is to protect the cars circuitry from voltage that is released by the coil when it de-energizes (don't ask me what that means, i am just saying what i read )
the yellow and red points are connected
because in this case, we are using the power coming from the car to both power on the relay, and to give power to the bulb
in the case of having your lights on
there is 2.5V coming to the red and yellow points
that's not enough to energize the relay
so the 2.5v goes to the blue point which is sent to the 2 5.6 ohm 25w resistors
(so the car senses the correct resistance and no bulb warning)
now when you use the turn signal
the red/yellow get 14V, that energizes the relay and the 12v goes to the white point which leads to the bulb
as for the orange LED
it gets it power from a seperate wire (black with blue stripe on the passenger side, and black with green line on driver side)
now those colours are from the headlight plug that goes into the headlight
inside the headlight the LED has a black wire, and the turn signal has a white wire for both sides)
the ghetto way to get rid of the LED is to cut that black wire from inside the headlight= no LED
what i am going to do is to connect the LED with the turn signal
so it only flashes with the turn signal
      04-10-2009, 10:55 PM   #2
kmarei
kmarei's Avatar
Egypt
688
now you can put the relay with resistors inside the headlight
but be careful that the resistors don't touch against any of the wiring as they get hot and may melt the wires
Plan B is to do all this wiring at the 2 boxes at the bottom of the windshield
like in this pic, at the top 2 corners of the pic
that's where the wires from each headlight go
so it would be much cleaner to do it there
i will take pics when i get a chance to do this sometime this weekend
      04-11-2009, 11:14 AM   #3
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
do you think you can take more pictures and do it step by step if you decide to do Plan B install ? I already have some stuff in my headlights so, Plan B would be perfect for me ...
Thanks.
      04-11-2009, 12:22 PM   #4
kmarei
kmarei's Avatar
Egypt
688
i'm dying to do plan b
but its raining right now and i am waiting for it to stop
i can take pics but all i have is the crappy iphone
the regular camera has chocolate all over the lens thanks to my son
      04-11-2009, 12:31 PM   #5
CatchM3
CatchM3's Avatar
Drives: 2020 X6M Competition DG
2008 E90 M3  [9.00]
+1 on step by step instructions
2020 X6M Competition // Donington Grey // Executive Package// Bower and Wilkins Sound System // Driver Assistance Package // CF Trim
      04-11-2009, 12:34 PM   #6
kmarei
kmarei's Avatar
Egypt
688
here is the link i was talking about
this is the area i want to work with
http://www.e90post.com/forums/showth...light=red+wire
just to the left of the thick red wire at the bottom is what i think, the headlight harness
as i see the black wire with blue stripe
time to whip out the mutli meter
      04-11-2009, 12:47 PM   #7
CatchM3
CatchM3's Avatar
2008 E90 M3  [9.00]
If you can confine the work in this space, it would make the job much easier.
      04-11-2009, 01:40 PM   #8
kmarei
kmarei's Avatar
Egypt
688
I'm sure I can
Because when I traced the headlight wiring loom
The left side led to the left box
And the right to the right box
      12-04-2009, 08:24 PM   #9
Bluesummer
Bluesummer's Avatar
Taiwan
588
Drives: slower than Ayrton Senna
2017 BMW X5M  [0.00]
2015 M4  [0.00]
2011 E82 135  [0.00]
2011 M3  [0.00]
2007 335  [0.00]
any update on this?
IG:d.violet.m3
      12-04-2009, 08:50 PM   #10
kmarei
kmarei's Avatar
Egypt
688
not really
i ended up cutting the 2 wires going to headlight
1 for the LED and one for the bulb
and attaching the wire that comes from the car to a relay
so when they are getting 2.5v they relay doesnt turn on
and the bulbs are off
when i use my turn signal they get 12v and the relay energises and both bulbs turn on
i also added a resistor that is only activated when the relay is off
so the car always sees the correct resistant
either from the resistor when the relay is off
or from the bulb when the relay is on
it was more complicated that i thought
but i did end up with a corner delete
      12-04-2009, 08:52 PM   #11
kmarei
kmarei's Avatar
Egypt
688
oh and the blue/black wire in the box in the front is not going to headlight
it turns on the engine fan
don't ask me how i know that
      12-05-2009, 02:47 AM   #12
Moxie
Moxie's Avatar
Drives: AW 328d Touring/SG 335d
If interested - Here's a corner delete for a 3 Series E90.
http://www.e90post.com/forums/showth...=corner+delete
      12-05-2009, 01:36 PM   #13
JCtx
Drives: No BMW yet
Never noticed anything other than the 'angel eyes' lighting up with the DRLs in the front (and tails on the rear, of course, but don't understand why) on my '08. Even if the orange ones are lighted, they're not conspicuous enough to warrant messing with factory wiring, but each of us is anal in a different way .
      12-11-2009, 10:34 AM   #14
ersin
ersin's Avatar
Drives: 17 YMB F80 M3
Originally Posted by elp_jc View Post
... but each of us is anal in a different way .
Great quote!
2017 F80 YMB.
      12-24-2009, 06:32 AM   #15
alex310
Drives: 335I Coupe/M3 Sedan
I did this years ago, the best thing to do is, cut the LED wire, then cut and run the wire that goes to the running/signal light for the headlight and run it to a resistor to take the load (25watt load.) After that you tap into the fender side signal wire and run the wire back to the headlights running/signal light wire. No errors, and will signal correctly.
Here is my old thread, works for all E92/E93s, and all E90/E92/E93 M3s...
http://www.e90post.com/forums/showthread.php?t=64702
m3post
