03-19-2009, 11:25 PM | #1 |
Rep 6,107
DIY: BMW Performance Steering Wheel
Hey guys,
Here is DIY on how to install BMW Performance Steering Wheel. It is not very difficult you just need to take your time and pay attention to what you are doing. Tools: 1. Not very big Flathead Screwdriver 2. 16mm or 5/8 socket with wrench and extensions 3. T25 torx socket ( i think it is T25 but I might be wrong) 4. Very small flathead screwdriver 5. 10mm socket If you are local ( Bay Area ) I can install it for you This DIY is for you just to look/read and get an idea on how it can be done. I am not encouraging you to do this installation. I will not be responsible for anything that might happen to you, your vehicle, or anybody who might be helping you, or anything else. Before you start taking everything apart you need to read PDF Instructions in the Post#3 at the bottom and get familiar with it. Make sure you understand what goes where. After you did that, I would recommend to label supplied BMW harness with A1,A2,A3,A4,A5,A6, and A7 tags. It will be easier to figure out what goes where. 1. Disconnect your Battery and make sure your (-) Negative terminal will not be touching battery 2. Remove lower plastic panels on both sides (passenger/driver). I just have picture of the passenger side Driver side 3. Read PDF instruction and unplug Blue connector 4. Release the side tabs and pop off the Black/Grey connector that is inside the Blue one. 5. Read PDF installation and remove Blue/Red wire from Pin1 and Red from Pin2. Insert A3 into Pin1 and A4 into Pin2. Now install wires that you removed from Pin1 and Pin2 into Connector E Pulling out wires from Pin1 and Pin2 Connector E Wires from Pin1 and Pin2 inserted into Connector E Wires A3 and A4 inserted into big Black connector into Pin1 and Pin2 and Connector E connecter to A5 6. Now you can install Control Module B and connect A6 to the module Last edited by doba_s; 11-01-2009 at 01:57 PM.. |
03-19-2009, 11:25 PM | #2 |
Rep 6,107
7. Attach module B to the harness using zip-tie like i did or somewhere else ... it is not the best spot because it make a bit hard to install plastic cover at the end.
8. Install the Black connector into Blue connector and then reinstall Blue connector. I used zip-tie to get all those wires together ... 9. Now you need to remove your Airbag. Make sure you have no power going to your car or it can be very bad and dangerous ! Use medium size flathead screwdriver and insert it into very little openings (one on each side) Insert screwdriver like this Not like that Push on it with the moderate force and pull that side of the airbag gently Then do the other side Now you can open Green and Black clips/locks with a flathead screwdriver. Take it easy and don't break them 10. Disconnect the connector from the Coil spring cartridge (Grey/Yellow and Black) 11. Now you can remove your old steering wheel by using 16mm or 5/8 socket 12. Now we need to remove upper/lower steering column trim. Pull the upper part first. Pull it up and do one side at a time. You can use a medium size flathead screwdriver and push it up from the inside, but be very careful and don't punch yourself ... it hurts like a B... trust me Tape the upper part to the dash 13. Remove the lower part by pressing on the tabs (one on each side) 14. Now remove Coil spring cartridge with T15 torx. Unplug Black small connector on the RT side. Make sure not to pull the whole assembly out of the column. Very Important. Unclip all the clips and remove just the Coil spring cartridge and nothing else. These are the clips that are holding it on the side, so make sure to unclip them 15. Install the new Coil spring cartridge that came with you new PSW. Don NOT connect the Black connector just yet. 16. Now you need to remove the center console to rout the harness to the steering column. I did it this way but you might decide to do it differently. 17. This is how I routed A7 18. Read PDF instruction and remove wires from the Black connector ( the one I told you not to connect to your new Coil spring cartridge) and insert them into A7 white connector. They are numbered 1-6 and you need to insert them the same way ... #1 from Black connector goes to #1 in A7 White connector and so on ... Now you CAN connect A7 White connector into you new Coil spring cartridge 19. Zip-tie the wires together and put back steering wheel column trim. 20. Transfer everything from your old wheel to your new PSW and install everything back. Read the PDF file. Connect black connector from the new Coil spring cartridge to the Green connector on you new PSW. The rest is the same. In PDF file it says to connect Black connector to Black but it is actually Green and not Black. Just FIY. It should look like this Last edited by doba_s; 03-20-2009 at 12:50 AM.. |
Vedubin01942.50 |
03-19-2009, 11:26 PM | #3 |
Rep 6,107
21. Since OBDII port doesn't have two needed wire to connect A1 and A2 I decided to use cigaret lighter as the power source. I have something else taped into this power source so don't pay attention to the Red and Black wires. You need to tap A2 Braun wire in to thick Braun wire and A1 Green/Braun into thick Red/Black wire on your cigaret lighter connector.
22. Now you can put everything back together. Connect your battery after you are done with everything, start your car and you should get this Read the Manual that came with your new PSW to set it the way you like ! I hope this will help PDF FILE HERE Last edited by doba_s; 03-20-2009 at 12:54 AM.. |
cloumeM165.50 |
03-20-2009, 01:47 AM | #6 |
I like cars
329
Rep 5,052
You should really use a torque wrench to tighten the bolt the secures the wheel to the column.
My photostream: http://www.flickr.com/photos/racelap/
03-20-2009, 01:56 AM | #8 |
Rep 6,107
yes you can ... mine is too big and I couldn't use it ... I'll recheck it in a week or so, but there is no way it will get loose ... plus don't remember reading in PDF file anything about using torque wrench to tighten it.
03-20-2009, 02:24 AM | #9 | |
I like cars
329
Rep 5,052
The perf wheel looks good, btw. I just wish it had M stitching.
03-20-2009, 02:37 AM | #10 |
BimmerPost Supporting Vendor
8224
Rep 18,823
Drives: BMW
Awesome DIY - thanks for taking the time to post.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
03-20-2009, 04:30 AM | #11 |
///M-Flight VP
77
Rep 669
Drives: '13 Frozen Red Edition E92 M3
I got my steering wheel installed this weekend...good DIY...but not too technically/mechanically incline so I got BMW here in Bamberg, Germany (Autohaus Sperber) to do the install and programming for me...next project Alcantara my headliner, A pillar and B pillars
03-20-2009, 09:46 AM | #12 |
190
Rep 1,497
Awesome DIY Aleks!!!!
I wish I could join installation, and this makes me can't wait mine get installed!! How long did it take? I might try to install mine today once I get back to SF tonight.. Good Job!! |
03-20-2009, 10:06 AM | #13 |
Rep 6,107
it took me about 2-3h ... i was trying not to f...k it up haha ...
03-20-2009, 10:07 AM | #14 | |
Rep 6,107
SaNGRia986.00 |
03-20-2009, 10:08 AM | #15 |
Rep 6,107
03-20-2009, 10:44 AM | #16 | |
E90 - the Ultimate family hauler
22
Rep 578
Every time I see a Performance Steering Whell my reaction is first then . So you're saying that after you installed the wheel all the functions worked? You did not have to take it in to the dealer for programming or coding to your car?
2008 AW E90 M3 - current
2002 TIAG E46 M3 - gone 1991 DiamondSchwartz E30 M3 - gone but not forgotten |
03-20-2009, 10:56 AM | #17 | |
Rep 6,107
03-20-2009, 12:32 PM | #20 |
Rep 387
I really like the thickness of the OEM steering wheel.
Is the performance steering wheel similar in thickness ? If it is I'm buying one today lol. |
03-20-2009, 12:51 PM | #22 |
///M-Flight VP
77
Rep 669
