BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      01-07-2009, 03:13 PM   #1
JuniorDee
JuniorDee's Avatar
74
Drives: the speed limit
A/C delete
Using the attached photo, please tell me if my pully labeling is not correct:
1. A/C Compressor Pully
2. Power Steering Pump Pully
3. Adjusting Pully
4. Deflection Pully
5. Water Pump Pully
6. Crank Pully
7. Adjusting Pully
8. Alternator Pully
If you wanted to delete the A/C compressor you could remove 1, the compressor, 4, and get a shorter belt? Is that correct.
This is hypothetical, I am not performing this.
Credit for the photo goes to the guys getting the stroker kit.
EDC.....viagra for your car
      01-08-2009, 02:11 PM   #2
Oakleyguy
Resident Engineer
Oakleyguy's Avatar
Drives: Land Cruiser
2014 Toyota URJ200  [0.00]
2017 BMW M2  [0.00]
2015 BMW M4  [10.00]
2005 Toyota UZJ100  [0.00]
Hypothetically yes.
Trying to make a track only car?
      01-08-2009, 04:43 PM   #3
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
dude if this is DIY then you need to buy a mechanic shop to perform it ...
      01-11-2009, 08:08 PM   #4
kmax1980
Drives: 08 E93 M3 Jerez Black/Fox Red
this looks like a job you could do on your driveway with a couple tools from pep boys and a 6 pack of beer
3. Adjusting Pully
4. Deflection Pully
5. Water Pump Pully
6. Crank Pully
7. Adjusting Pully
8. Alternator Pully
      01-12-2009, 11:18 AM   #5
JuniorDee
JuniorDee's Avatar
74
I am thinking about trading my car in for a stripped m3 and then doing some of these dietary things to it.
I dont see the point in stripping a car that has all the options that I put on mine.
      01-22-2009, 06:48 PM   #6
Sam12345
Sam12345's Avatar
106
Drives: jet black 335i coupe
2008 335i Coupe  [0.00]
how much weight would this save?
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      01-22-2009, 07:31 PM   #7
gthirtyfizle
gthirtyfizle's Avatar
191
Drives: E92 M3 AW
Dont do it man!
      01-22-2009, 07:32 PM   #8
M2381
M2381's Avatar
Drives: E92 M3, GTI
I honestly would not be suprised if its 100 pounds
      01-23-2009, 12:10 AM   #9
JuniorDee
JuniorDee's Avatar
74
its 10.89 lbs
IanMan384.00
      06-16-2016, 03:31 AM   #10
maicol76
Drives: E92 M3
Did you take off a/c?
If you did, plz let me know the mothod.
      11-08-2017, 06:52 PM   #11
maicol76
Drives: E92 M3
I did it~!!
2011 LCI W/DCT / K&N drop in filter / CSF radiator / do88 oil cooler / do88 DCT cooler / Akra Evo / Moton CS 2 way coilover / Wiechers strut bar(F) / ARC strut bar(R) / Alcon Superkit BBK / Tarox rotor / Geoff steel EHPS / Sard carbon-Kevlar GT wing / GT4 carnard / Aim Evo4+G-dash+GT Steering+S/C GP HD / Bride Zeta3 / etc.
      04-05-2018, 07:30 AM   #12
magus4286
magus4286's Avatar
Drives: '08 E90 M3 6MT
Originally Posted by maicol76 View Post
I did it~!!
What belt did you use and what is your car's manufacture date? Thanks!
E90 ///M3 ('08) Racecar build | Fire Orange | 6MT | MCS 3W w/ rear coilover | Alcon BBK | Akrapovic Ti + BW Racing X-Pipe | do88 cooling | All the aero | Solid almost everything | CF Roof | TA16 and SM-10 wheels | AiM PDM32
      04-05-2018, 08:37 AM   #13
doogee
doogee's Avatar
748
Drives: '08 M3, '09 328xi Sport Wagon
What? AC systems really don't weight much.
I would guess around 10 lbs total.
      01-08-2019, 07:17 PM   #14
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
I remove the ac from an e46 m3 before and it was 37lbs.
I think e92 is about the same 37-40lbs
Thinking of doing this as well to my e92 m3
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
      12-06-2019, 10:48 AM   #15
racemotivem3
Drives: BMW M3 E92
S65 AC Delete
I did it~!!
Hy Guys, iīm new to here. But actual building a dedicated BMW E92 M3 Stagerally car, so i really donīt need AC... My plan was to remove the AC Comp and find a shorter belt. (and of course all the ac lines, radiator and so on) Has anyone done it like this and can tell me if everthing works properly?
Some pics of it - this week engine - gearbox - fuel system - suspension and so on comes in...
      12-06-2019, 10:58 AM   #16
magus4286
magus4286's Avatar
The belt depends on the date of manufacture of the car, since the design changed around 4/2008 (IIRC). I've done it with no problems on an early build car (1/2008). A 6PK815 belt ended up being just right for that application after some trial and error. Two seasons (~45+ track days) and no problems.
tlrid3r513.50
      12-06-2019, 11:38 AM   #17
racemotivem3
Drives: BMW M3 E92
Thanks! Did you use both of the tensioner pulleys or just one?
      12-06-2019, 11:40 AM   #18
magus4286
magus4286's Avatar
Kept both in place.
      01-14-2020, 11:19 AM   #19
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
Originally Posted by magus4286 View Post
Kept both in place.
How did you find the belt I can seem to find it. no auto parts store has it
      01-14-2020, 11:29 AM   #20
magus4286
magus4286's Avatar
Had to order it online, from overseas, Amazon UK in fact. Was made by Gates. (Just checked and the specific one i ordered is unavailable).
      01-14-2020, 11:43 AM   #21
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
thanks
      01-22-2020, 08:50 AM   #22
Helmsman
Helmsman's Avatar
Sweden
4470
Drives: 2011 AW E90 M3 ZCP
Wow, haven't seen this post before. Any updated on progress man??
tlrid3r513.50
m3post
