BMW M3 Forum (E90 E92)
      11-12-2008, 10:12 PM   #1
JonM
Drives: E90 M3 Sedan
Arrow DIY: Let's Change the Engine Oil
Saw a request for this. I let the dealer do the 1200 mile service because of the power requirement for transmission fluid change, so I have not changed my own oil yet. I am planning on it at 5000 miles, along with a Blackstone oil analysis. The handwritten notes shown include torque values. Oil filter kit part number is 11 42 7 837 997. This includes the O-ring for the filter cover and all crush washers.
Update 8 years later:
Use 25 Nm for the drain plug. The other torque values I have handwritten in my notes are for the oil filter housing and other projects. I am tired of reading about confusion. Hopefully this helps. Also, BMW changes torque values all the time, that's why they always refer you to a torque table instead of putting the torues in the repair documents. Do your research before you take your car apart.
Jon Maddux
coupenut.blogspot.com
x5nut.blogspot.com
16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe
13Ghost40.50
LMBE9263.50
      11-12-2008, 10:26 PM   #2
BMWguy206
BMWguy206's Avatar
Drives: '93 400E
Does anyone know the exact amount of how many liters of 10w-60 are needed? I read on an invoice it's 9 liters but just want to make sure. I've heard parts guys giving the techs a liter more than what's really needed.
'95 M3 Coupe Alpine White
      11-12-2008, 10:43 PM   #3
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
this is very much appreciated
      11-13-2008, 06:56 AM   #4
aussiem3
aussiem3's Avatar
Australia
274
Drives: Goggomobil
All BMW V8, V10 and V12 take 7.5 litres of oil.
F86 X6///
      11-13-2008, 08:06 AM   #5
Big Windy
Big Windy's Avatar
Drives: None
nope. 9 litres are required for 1200 mile service, so i think that the capacity is around 8.8 or 8.9 litres.
      11-13-2008, 08:17 AM   #6
JonM
The owner's manual quote the numbers for with and without filter change. I will post it if I can bust out of work to get my manual, unless someone beats me to it.
Jon Maddux
x5nut.blogspot.com
      11-13-2008, 03:20 PM   #7
JonM
Well, I can't find the oil capacity in my manual. Hard to believe. I think I read it in BMWTIS.com, but I didn't print it. Next time I drop $30 for a subscription I will print it out and post.
Jon Maddux
x5nut.blogspot.com
      11-13-2008, 03:28 PM   #8
BMWguy206
BMWguy206's Avatar
Drives: '93 400E
TIS says 8.8L with oil filter.
      11-13-2008, 10:43 PM   #9
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
That sound right, though my 1,200 service invoice only lists 8L.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      12-12-2008, 01:16 PM   #10
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
I just changed my oil myself and it took a total of around 8.4L to fill. The oil level marker is right at the top arrow, so I would say 8.25 should do you just fine. I did let the oil drain for a while so it may take less if you do not let the oil drain completely from the openings in the oil pan.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia
2020 BMW X7| Mineral White
2024 718 GT4 RS | Arctic Grey
      12-13-2008, 12:11 AM   #11
rmashman
Drives: 2008 M3
The oil amount with filter change as noted on BMWtechinfo.com is 8.8 liters or 9.3 quarts.
      12-14-2008, 05:42 PM   #12
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
Use that if you want, but that does not account for the little bit of oil that gets left in the motor. When I changed the oil myself and put it in it took less than 8.5L to get the oil level marker to the top arrow (and this was with allowing the oil to drain for a while until it was slowly dripping out at the end). I think if you out in the full 8.8L you will overfill which can cause serious engine problems. For anyone changing the oil I suggest putting in 8L and then checking your oil level indicator afterward. If it is on the low side I recommend putting in only 0.25L at a time and rechecking the level...
      12-28-2008, 06:22 PM   #13
JuniorDee
JuniorDee's Avatar
74
Drives: the speed limit
the oil filter cap requires a 36mm socket. just bought one so i know
EDC.....viagra for your car
      12-28-2008, 06:31 PM   #14
GregW / Oregon
Commander-In-Chief
2122
36 mm socket
I think that's the same size as used for the axle nut for changing wheel bearings, at least it was on the 2002.
      01-02-2009, 03:39 PM   #15
GregW / Oregon
Commander-In-Chief
2122
Oil change tips
I changed mine today at 8k miles (in 8 1/2 months) -- Service Indicator is showing 8k to service.
I used ramps at the rear, and jacked the front fromt the central jack point and supported the front on jack stands at the suspension arm pivot points. I noticed when the filter is removed there is about 1/10 liter of oil in the bottom of the housing. I used my MityVac to suck it out, though you could use an old turkey baster. I poured about the same amount of fresh oil into the bottom before reinstalling the filter.
I put in 8 1/4 liters before restarting the car. It took quite a while to get a reading, and was then showing near the bottom of ths scale with a "+1" notation. I added another 1/2 liter, but was unable to get a different reading in the garage. I'll check it again after driving.
The car always seems to run better after an oil change--pyscholocical, I know, but it makes you feel good.
Edit: The electronic oil monitoring system and lack of a dipstick continue to frustrate me. If the system were secondary, that's fine, but why do away with the dipstick? After putting in 8.75 liters (stated capacity is 8.8) and driving a couple times, the system is still telling me to add 1 quart -- would you trust it? If it had a disptick there would be no question. Just really stupid!
      01-02-2009, 09:05 PM   #16
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
Nice pics Greg.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      01-02-2009, 09:19 PM   #17
alpineweissM3
I love my beautiful wife!
22
Drives: e90 ///M
Greg - Thanks for posting..couple questions for you:
1. What size socket is needed to remove the drain plugs?
2. Did you pay $17 for the oil filter kit? That seems really high, but that's the cheapest I could find it.
3. Where exactly is the central jacking point in the front?
      01-02-2009, 10:29 PM   #18
GregW / Oregon
Commander-In-Chief
2122
Oil change
Answers:
1. It's not a socket, but a 6mm hex.
2. List is $17.77; I paid $15.99 with club discount.
3. It's that plastic knob in the second photo, midway between the front and rear sumps.
Cheers, Greg
      01-03-2009, 06:06 PM   #19
alpineweissM3
22
Drives: e90 ///M
Excellent...thanks again for the awesome pics!
      01-03-2009, 07:27 PM   #20
rfedele
rfedele's Avatar
Drives: 08 M3 Sedan
Would you mind indicating on a photo the 2 drain plugs? I recall someone commenting that there was "another" similar looking plug in the area. Thanks
"Accept the advice of others only in the rarest of circumstances." Beethoven
present: 08 E90 M3 / past: 2007 997 C2, 2005 997 C2S, 2005 Audi S4, 2004 Volvo S60R
      01-03-2009, 10:15 PM   #21
GregW / Oregon
Commander-In-Chief
2122
Here are the drain plugs for the front and rear sumps (I have pointed them out in the second photo of the original post):
      01-03-2009, 11:15 PM   #22
rfedele
rfedele's Avatar
Drives: 08 M3 Sedan
Thanks Greg.
m3post
