11-12-2008, 04:32 PM | #2 |
Bored at work....
890
Rep 5,391
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
11-12-2008, 09:21 PM | #3 |
First Class Privates
Rep 147
I'd be careful though...as much as I love the V1, Virginia has been getting a lot of Spectre RDD's, and the newer V1's are VERY detectable, due to a manufacturing change from a couple years ago. If you are going to use an RDD, unfortunately the only stealth options are the Bel STI or STI-r (custom install) or the Escort 9500ci (custom install).
Here's hopin' V1 gets off their laurels and comes up with a solution to the Spectre...its been years now. |
11-12-2008, 10:52 PM | #5 |
Uber-Lee7 Member
47
Rep 1,440
virginia is no joke!
11-13-2008, 06:44 AM | #6 |
Rep 147
11-13-2008, 12:06 PM | #8 |
Rep 5,391
Drives: 08 JB E92 M3
11-13-2008, 02:14 PM | #10 | |
Rep 42
11-13-2008, 02:37 PM | #11 |
Rep 1,429
Check the link in my sig, that DIY leaves out a couple things.
11-26-2008, 10:20 PM | #12 |
Rep 1,508
I just hardwired my Valentine 1 using the fuse tap method. Worked like a charm. It is much simpler than I thought it would be.
I initially tried the DIY mentioned above but after trying to remove the damn light fixtures without success (and actually cutting my finger while trying to reach for the metal clip) and hearing about the possible issues with the sunroof operation, I decided to go the fuse tap route instead. Only part I had to buy was this one Let me know if anyone needs photos of the install and I will try take some. All and all, a simple install. Also it does not require any drilling contrary to a E90 DIY states.
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates Previous: 2009 E90 M3 |
01-03-2009, 10:18 AM | #13 |
Two Wheels or Four?
93
Rep 655
If you use the fuse tap method, do you still need to use this inline fuse connector included with the V1?
Current: '18 AW Performance Edition m240i Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci |
01-07-2009, 09:05 AM | #14 |
Two Wheels or Four?
93
Rep 655
I ended up using the fuse tap on slot 7, the homelink slot on my E90. I kept the inline glass fuse (1 Amp) and put a 5 Amp fuse in the piggyback adapter. Seems to work just fine.
