BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      11-01-2008, 10:35 PM   #1
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Arrow DIY: Aftermarket Spring Install
The process is very similar (with some simplifications) to regular 3 Series' install: http://www.e90post.com/forums/showthread.php?t=15397
All the bolts and nuts that need to be removed are circled in red. BMW recommends replacing all nuts and bolts.
Torque specs: http://www.m3post.com/forums/showthread.php?t=183005
I've done this so many times since when this thread was written. Now updated for 2010
Best Practices:
Front Axle:
1. When removing the front springs: use a jack and push up the front suspension to compress the spring, and then put on the spring compressor. This will save you a lot of time.
2. The strut piston rod can be pushed into the shock with hands.
Rear Axle:
1. When loosening the bolts: loosen the shock bolt first, the camber arm/wheel carrier bolt second.
2. When tightening the bolts: tighten the camber arm/wheel carrier bolt first, the shock bolt second.
3. It may be very tough to align the wheel carrier with the camber arm. Try jacking up the camber arm, and use a wrench as a level to position the parts.
4. When aligned correctly, you should be able to push the outer bolt completely through the camber arm, without any turning. This bolt is tightened by the nut.
nyfg56100.00
      11-01-2008, 11:05 PM   #2
BMWguy206
BMWguy206's Avatar
Drives: '93 400E
So you removed and replace the spring without removing the entire front strut assembly?
'95 M3 Coupe Alpine White
      11-01-2008, 11:09 PM   #3
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Yup, as said, all bolts needed to be removed are circled.
      11-06-2008, 08:50 PM   #4
camaross305
camaross305's Avatar
135
Drives: 2008 M3
cool nice write up
      11-06-2008, 08:55 PM   #5
MDCTFTW
Drives: E92 DCT
SWEET! Any shots of the rear install? I know it's probably exactly the same as a normal 3 series.
MDCT ... so you can drive and eat a hamburger at the same time.
      11-06-2008, 09:12 PM   #6
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
dude... you gotta a little better. The first picture is the rear install.
      11-06-2008, 10:23 PM   #7
MDCTFTW
Drives: E92 DCT
Holy shit, I fail. My bad! Thanks again for the specs and pics. Time to order my springs.
      12-19-2008, 05:14 PM   #8
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
How difficult was it using the spring compressor? I have done tons of coil-over installs before on my various cars including two e46 M3's, but have never installed drop springs. I recently ordered some H&R springs and plan on doing the install myself. Am a little worried about using the spring compressor in fear that it will slip or fail and the spring will shoot out and hurt someone, the car, or something else. Is it straight forward using the compressor and is it pretty sturdy? Would love some input on this. TIA.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia
2020 BMW X7| Mineral White
2024 718 GT4 RS | Arctic Grey
      12-19-2008, 07:17 PM   #9
camaross305
135
Drives: 2008 M3
They are extremely sturdy. They have little safety pins to push to keep the springs from popping out. It really easy and straight forward.
The original Hid angel eyes for sale now on ebay
User name lmims526894rou
Or contact me at chrism9551@aol.com
      12-19-2008, 09:59 PM   #10
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
Cool thanks. Is one of these designs better than the other:
http://shop.oreillyauto.com/ProductD...egoryCode=3492
http://www.sears.com/shc/s/p_10153_1...0070515x00001c
      12-20-2008, 11:01 AM   #11
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
FYI you can rent spring compressors for free at autozone.
      12-20-2008, 03:26 PM   #12
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
That's good to know!
      12-21-2008, 02:14 PM   #13
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
i didnt know that ... $6/day at kragen
      12-22-2008, 03:09 AM   #14
camaross305
135
Drives: 2008 M3
yep thats where i always get them from or advanced
      02-18-2009, 12:56 PM   #15
schnell325
Bored at work....
schnell325's Avatar
Drives: 2016 F82 M4 GTS//2022 M235iGC
Bump so I can find this thread in the spring too.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      02-18-2009, 01:48 PM   #16
TonyTone
TonyTone's Avatar
Drives: M3 VERT
Great rightup!
      02-19-2009, 07:44 PM   #17
MrAdams
do a wheelie!!!
MrAdams's Avatar
Mexico
156
Drives: E46 M3 - '72 2002 - '65 Impala
how long did it take?
~Adam
      02-19-2009, 10:00 PM   #18
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      02-20-2009, 11:48 AM   #19
MrAdams
do a wheelie!!!
MrAdams's Avatar
Mexico
156
Originally Posted by GregW / Oregon View Post
my bad, just trippin cause I'm doing mine tomorrow!
~Adam
      02-23-2009, 11:55 AM   #20
MrAdams
do a wheelie!!!
MrAdams's Avatar
Mexico
156
DID IT!!! took me and a friend about 2.5 hours. It was super easy. we had planned a 6 hour install like the thread said. Thanks rzm3 for the DIY helped out a lot. and thnks for all the torque specs too looks great now
~Adam
      02-23-2009, 01:41 PM   #21
JuniorDee
JuniorDee's Avatar
74
Drives: the speed limit
if an alignment is not done, what kind of tire wear would we see?
EDC.....viagra for your car
      02-23-2009, 03:19 PM   #22
schnell325
Bored at work....
schnell325's Avatar
Nice to hear!!
m3post
