04-17-2019, 12:59 PM | #1 |
Rep 716
Drives: F90 M5
Anyone have/know where to get 2-piece rear rotors
hey watsup guys, does anyone here, run or know where to get 2-piece rotors for the rear? i cant seem t find a 2 piece for the rear of the F22
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
04-17-2019, 05:14 PM | #2 |
Rep 2,214
Honestly, I've looked lol.
Unless you get one of the custom "made-to-order" companies like RacingBrake, you're not going to have much luck. I only ended up with mine because the BBK I bought came with them, otherwise I never intended on changing them. FWIW the M2**iR uses factory rear rotors/calipers with a PFC front BBK. Once you install the bigger fronts, dial the brake bias forward and you'll see how little the rear is actually doing. IIRC, you have a sweet BBK up front, already? Did you update the brake bias already? I only ask because I didn't at first, to see the difference, and it was night/day.
04-17-2019, 06:35 PM | #3 | |
Rep 716
Drives: F90 M5
haha yea man i was trying to avoid those made to order companies. And yea i already have the StopTech Trophy BBK up front and adjusted the bias at the time of install and your right the rears dont do a whole lot lmao. Maybe im getting to that point where im buying shit just to do it lmao.
Dylan861330.00 |
04-17-2019, 11:53 PM | #4 | |
Rep 63
https://www.autopartsway.ca/partdeta.../pagenum1/tabs |
Shayan55339.50 |
04-18-2019, 12:18 AM | #5 | |
Rep 3,506
Pilengas are not, however, two-piece rotors in the conventional sense of the term. That is because the hats cannot be reused. This Essex Parts M2 Competition two-piece rear rotor is an example of what a two-piece rotor looks like, with a reusable hat bolted to a replaceable ring:
04-18-2019, 12:16 PM | #6 |
Rep 294
Drives: 2019 M240i Coupe RWD
Is there any advantage to a reusable hub? I'd be concerned about the assembly process of the new rotor to a used hub and whether it's as robust as a factory made set like the Pilengas.
Thank you for the Pilenga link btw. With the factory like aluminum hubs, those look like the replacement rotors I would go for when it comes time to replace. |
04-18-2019, 02:12 PM | #7 | |
Rep 3,506
Two-piece rotors are much more a race part than they are a street part. I'm not sure I'd run one on the street if I used the car as a DD. I had them on a race car and used a shop to change the rings out when they were used up. About two-thirds of the way down in the following link you can read about how a two-piece rotor works. The entire page is well worth reading if performance braking systems are of interest to you. https://www.essexparts.com/essex-des...-m2competition
WolfGTI717.50 |
04-18-2019, 02:44 PM | #8 | |
Rep 2,214
^^ FYI I DD mine for 6 months/year with two piece floating configuration. It's super easy to swap rings, you just need confidence in yourself lol. The first time I did it, I took my sweet time on a bench with hand tools.
You can run a two piece "fixed" setup, which reduces all/any noise associated to a floating design. Mine don't make noise at all, like others report.. Quote:
What I might suggest is a pad out back that bites hard, like XP10's, can help balance things out if you're "nose diving" a bit too much up front. I had been driving a track prepped TTRS with a team of colleagues with stock brakes PFC-08 pads up front (endurance) and the XP10's in the rear, and after 4 combinations, that's what felt best on course for lengthy track sessions. It was nose diving really bad without the harder biting pads out back, it made a substantial difference. BTW, those rear TTRS calipers are single piston Golf R calipers, casted and all, the two piston Brembo's should do better for sure..
Shayan55339.50 |
04-19-2019, 12:54 PM | #9 | |
Rep 716
Drives: F90 M5
lmaoo i DD'd mine full race seats and all for like 6 months (recently got a jetta for the daily lmao) haha yea i know man, ive done just about everything on my car by myself lmaoo, and yea i feel that for sure, the best feeling combo for me has always been the ferodo DS2500 all around honestly (used to have StopTech SR34's up front and SR33's in the rear)
Dylan861330.00 |
05-09-2019, 08:43 PM | #10 | |
Rep 555
You can get the Pilenga drilled/slotted which are basically the M performance rotors for less than half of the BMW branded ones. I plan on pairing these up with EBC yellows.
09-01-2022, 03:23 PM | #11 |
Rep 447
I just found these units by Paragon Performance. Havent seen any reviews for our chassis yet, but they appear to be popular in the Corvette and GTR tracking community. $900 up front and $550 for replacement rotors. Quite a bit lighter too. Claimed ~3.5 lbs of weight savings per corner.
https://paragonbrakes.com/2-piece-ro...mance-m-sport/ https://paragonbrakes.com/2-piece-ro...mance-m-sport/ Last edited by 230iZTR; 09-01-2022 at 03:28 PM.. |
WolfGTI717.50 |
09-01-2022, 05:04 PM | #12 | |
Rep 3,506
09-08-2022, 12:53 PM | #13 |
Rep 447
I pulled the trigger on the Paragon units. Pricey, but a friend I trust who holds several FK8 Type-R track records around the West Coast has them and highly recommends them. Paired with EBC Blues and Ate200 should make for a killer setup. Ill provide a review after theyre on.
09-19-2022, 11:48 AM | #14 | |
Supreme Allied Commander
3893
Rep 54,603
Drives: F80 M3
Photo with rotors with the optional Mil-Spec hard coat. Standard anodizing is black. Last edited by HP Autosport; 09-19-2022 at 12:04 PM.. |
