M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      05-02-2017, 05:44 AM   #1
Phatcat
Drives: BMW M5, X5M
Oil drain plug washer
Questions guys, I just had oil changed today, and when I walked by to check on the car, I noticed there was a small washer and small o-ring left on the tool cart. I asked the mechanic why weren't they used, he said for F10 M5, they weren't needed, they were for the E60 M5 because it has two drain plugs.
So only the big o-ring and big washer was used on the F10, is this true?
      05-02-2017, 06:37 AM   #2
Phatcat
Drives: BMW M5, X5M
Searching around the net and looked under the car, I am pretty sure there is only one drain plug. So it's probably true the small washer and o-ring is not needed.
      08-04-2019, 05:05 PM   #3
naiza3k
Drives: 2013 M5 & 2019 x7 xdrive50i
Just curious, anyone have issues with the washer that comes with the Mahle filter to be too big for the oil drain plug?
2013 M5 Space Gray, Piano Black|Night Vision|Every option|6MT|RW Carbon front Lip|Vorsteiner Rear Diffuser|
2019 x7 50i White, Loaded | chrome delete | black grill |
Previous: 2015 X5 Graphite, |All options| - 2014 435i Xdrive Msport, |Fully Loaded|6MT|FBO|JB4|Front,side,rear lips/spoilers|- 2015 320i Xdrive, |Wife's beater| - 2008 535i Xdrive
      08-04-2019, 06:17 PM   #4
mrtt
Drives: E46/E60/E92/F10/E55
That's not the copper washer you want to use anyways. 12x18x1.5mm copper wash is what you want to use for your drain plug
Ickdeep5720.50
      08-07-2019, 10:09 PM   #5
naiza3k
Thanks!
      03-07-2020, 01:02 PM   #6
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
The small copper washer is the correct one to use for the drain plug. When you buy a change kit with the filter, it comes with all 4 rings. I only use the smaller copper and large rubber. Not sure what the other two are for
      05-20-2020, 09:10 AM   #7
2Live4
Drives: 2015 M5
https://www.fcpeuro.com/products/bmw...-07119963151-1
This is the washer I use.
2015 M5 CP - Alpine White - My joy ride
2013 LS 460 - Pearl White - Wife's
2007 M5 - Black Sapphire - sold
Flying Ace4984.50
      05-03-2023, 01:42 AM   #8
wavev
Drives: toyota yaris
Questions guys, I just had oil changed today, and when I walked by to check on the car, I noticed there was a small sump plug washer and small o-ring left on the tool cart. I asked the mechanic why weren't they used, he said for F10 M5, they weren't needed, they were for the E60 M5 because it has two drain plugs.
it is possible that different types of cars may require different types of washers and o-rings during an oil change.
Some cars, particularly those with multiple drain plugs, may require smaller washers and o-rings to ensure a proper seal. Other cars may only require a larger washer and o-ring. It's possible that the mechanic was correct in stating that the smaller washer and o-ring were not needed for your F10 M5, but it's always a good idea to double-check with the manufacturer's specifications or a trusted mechanic to ensure that the correct parts are being used during maintenance on your vehicle.
      05-03-2023, 09:07 AM   #9
M5Rick
General
M5Rick's Avatar
60092
Drives: M5 F10 DCT Gunmetal
Don't go by the oil filter kit confusing o rings, best to buy assorted copper crush washers and choose one that fits snugly around the drain plug thread and don't over-tighten.
      05-04-2023, 03:56 AM   #10
M5Rick
General
M5Rick's Avatar
60092
The drain plug itself is a real pain to get to, right at the back of the sump and behind, this is on a car not far from two tons so I now take car to dealer who does oil change and filter from the practicality of a ramp.
m5post
