BMW M3 Forum (E90 E92)
BPM
      04-29-2008, 12:12 PM   #1
R68
Maverick-y
R68's Avatar
17
Drives: M Uber Alles
I saw a good radar install DIY but can't find it now. Help!
the post had pics, etc. approx. a week or so ago.
      04-29-2008, 12:25 PM   #2
R68
Maverick-y
R68's Avatar
17
thanks, that's it, although I didn't see the part about the sunroof restarting the V1. Guess I need to find another method.
      04-29-2008, 02:09 PM   #3
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
there are several wires in there. you have to find the right one. havent done it yet but planning on soon.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      04-29-2008, 02:21 PM   #4
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
You are correct...there are two plugs that both contain a green wire with a white stripe. Only one of them works. Hardest part was getting the sunroof section unbuckled (I was nervous that I was going to screw up my headliner). I actually had a custom mute button made that runs over to the left A pillar about eye level. You can take electrical tape and wrap around in a couple of spots that bulk up that area so that it will stay tucked behind the headliner. I'm still wrestling with whether or not above the rear view mirrow or the top left corner is the best place for my detector.
In my 535i, it seems like the embedded tint strip was twice as light as it is on the M. It hides my suction cups pretty well. The STi was my only option as I'm in Va.
      04-30-2008, 05:48 AM   #5
SS32
SS32's Avatar
156
Drives: 2008 M3
see the link in my sig
      05-02-2008, 04:52 PM   #6
sayemthree
sayemthree's Avatar
597
just hardwired my wifes 535ixT. I used the green wire with yellow stripe that goes to the mirror (universal remote?). and it works fine.
      05-03-2008, 08:44 PM   #7
Paladin906
Paladin906's Avatar
Drives: BMW 330i
I'm horrible at stuff like this. Can you hire people to do this for you. The stealth display on the audi is awesome is something like this available to us?
      05-04-2008, 02:39 PM   #8
sayemthree
sayemthree's Avatar
597
probably a good car stereo shop can do it.
      05-06-2008, 12:38 AM   #9
Paladin906
Paladin906's Avatar
Drives: BMW 330i
Thanks three----I will try that as soon as my car gets here.
      05-07-2008, 12:34 AM   #10
M3Kevin
M3Kevin's Avatar
Drives: Alpine White 2008 M3
2004 Corvette Z06  [0.00]
2004 GT3  [0.00]
2008 M3  [0.00]
It is a whole LOT easier if you remove the drivers side sun visor mount and clip (left and right mount points) and then the passenger side sun visor clip. the whole top then drops down and allows you to easily access the retiaining clips for the center console. Which then gives you access to all that you need to get power and ground for your Radar mount.
Kev
A happy tire is a squeeling tire.
Happiness isn't around the corner - it IS the corner!
      10-16-2008, 09:16 AM   #11
335ICoupe
335ICoupe's Avatar
Drives: 2008 M3
Just purchased an M3 I do not have a sunroof, not sure if i will have te screw up there. Is there a good ground WIRE I can tap into?
      11-03-2008, 12:03 AM   #12
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
there are two holes that you can use ... just get the right size small screw and it will be your ground ... use the green/white wire in the second connector from the left i believe to tap in ...
m3post
