M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      01-17-2017, 08:09 PM   #1
cali_m5
cali_m5's Avatar
27
Drives: 2021 BMW M5 LCI
Recommended oil?
I have a 2016 M5 and I push her pretty hard performance wise and was wondering if anyone had any recommendations? Thanks
      01-17-2017, 08:56 PM   #2
momos750
momos750's Avatar
143
Drives: 2015 M5, 2011 750Li
Your car is new and has BMW maintenance included.
They use rebranded Pennzoil which is produced by Shell.
If you are changing between oil change intervals just make sure it meets BMW spec requirements so you are covered for warranty purposes.
2015 M5 - Singapore Grey Metallic - Silverstone Full Merino Interior - Executive Pack - Drivers Assist Pack -Comp Pack -
cali_m527.00
      01-20-2017, 12:43 AM   #3
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Just as above said BMW approved Synthetic. I think BMW uses Castrol these days.
More importantly don't let a quick change location (jiffy lube, etc) do the oil change.
The Oil Cooler won't completely drain, but if you let it sit and drain for an hour...yes an hour, you'll notice that you'll drain an additional quart. Most quick lubes let it drain for 10 minutes or so.
cali_m527.00
      01-20-2017, 03:05 AM   #4
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Drives: 2013 BMW M5 | MSR Stage 3
You should have dealer maintenance included. Have the dealer change it out for you. They also do top off for free.
Personally, I changed it or topped it off when the system told me to. The intervals and mileage will change based on how you drive.
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
cali_m527.00
2016-M535.00
      01-20-2017, 01:31 PM   #5
E90Fleet
South Africa
1312
Drives: BMW
Shell oil since January 2015
BMW if you are reading, I need a job, Please.
cali_m527.00
      03-28-2017, 03:02 PM   #6
Warrior75
Drives: 2013 m6 convertible
My car is out of warranty, what do you guys suggest for oil changes? Should I bring it to a BMW dealership still?
      03-28-2017, 05:17 PM   #7
ConsumerFanatics
Drives: 2013 M5
I personally hate dealerships. They will undersell a service if you're covered under the maintenance plan or oversell it when you're out. Find a reputable third-party shop that has experience with the F10 M5.
      03-30-2017, 12:31 PM   #8
VoytekM5
Drives: 2013 M5
Find a local shop that specializes in German cars.
      04-23-2017, 09:06 PM   #9
HXS
Licensed Drug Dealer
HXS's Avatar
Drives: F10 M5
I use Liqui Moly Special Tec LL. It needs less top offs than the conventional BMW synthetic oil
cali_m527.00
      04-23-2017, 09:09 PM   #10
cali_m5
cali_m5's Avatar
27
Hmm interesting I gotta give it a try thanks brotha!
      05-07-2017, 11:12 AM   #11
wheelpro
wheelpro's Avatar
Egypt
176
Drives: M5,F10,JB4,DP,CP,METH,SSP
I use loqui moly too, 5w30
best oil
      05-07-2017, 11:36 AM   #12
alienstudio
alienstudio's Avatar
31
Drives: F10 M5 CP | G05 X5 40i
is this a full synthetic ?
2014 F10 M5 CP | Black Sapphire Metallic | Sakhire Orange Interior | 343M Wheels | Afe CF Air Scoop | Charcoal Filter Delete | AutoTecknic CF Steering Wheel Trim
      05-07-2017, 02:34 PM   #13
HXS
HXS's Avatar
Drives: F10 M5
That's a good question. I did some research on the Liqui Moly website and it really doesn't say. It's one of the recommended oils listed for our engines though.
http://f10.m5post.com/forums/attachm...1&d=1351958337
      05-11-2017, 07:54 AM   #14
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
I use liquimoly 5w40 since out of warranty. Took it to a local shop that deals with German and came highly recommended by other M owners.
      05-11-2017, 09:14 AM   #15
HXS
HXS's Avatar
Drives: F10 M5
What made you decide on the 5w40 versus the 5w30?
      05-11-2017, 10:00 AM   #16
TheHouseWon
644
Drives: 2013 M5
That's what the shop had in stock and they recommended it. Is there a difference between big 5w30 and w40?
      05-11-2017, 11:23 AM   #17
ARC550
Drives: M3, X5, 720s, X5, 750xi
5w40 better for high performance engines "M" for heat
He 5w30 is standard
      06-19-2017, 02:52 PM   #18
lanab
Drives: M5 F10 MY12
Motul 8100 X-Max 0W/40
      06-24-2017, 08:32 AM   #19
123Britt
Drives: 15 M235i AT
Bmw / Shell / Pennzoil
M5 (S63 - F10) (5 Series) (G) (2015)
Application
Recommendation
Capacity (gal)
Data Sheets
Engine (G) (S63)
Premium
Pennzoil Platinum Euro 5W-40 Full Synthetic (a)
2.25
Standard
Pennzoil Platinum Euro 5W-30 Full Synthetic
m5post
