12-29-2021, 04:49 PM | #4335 | |
Rep 2,212
12-30-2021, 11:12 AM | #4336 |
Rep 344
Before and after I wrapped the front bumper reflectors. Extremely close color match to the glacier silver metallic paint (really can't ask for a better match using vinyl). Beats paying for color match painted reflectors to!
12-30-2021, 12:40 PM | #4337 |
Rep 1,821
Hooked up the old dash cam today finally. Just an Aukey DR01, nice and cheap with no frills.
Tapped into the rain sensor power with a 12v to 5v converter hidden in the mirror housing. Can't see any wires due to top angled connection which is wedged between the headliner and glass. 2 Sided tape on the mirror to hopefully keep it from moving. Will run it for a bit and see if the battery drains or cam angle needs adjusting but it looks pretty clean at first glance. Edit: started getting the battery drain warning when it is -20C so I unplugged the cam for now. The rain sensor seems to run a couple minutes longer after the car is locked. Last edited by freakystyly; 01-26-2022 at 11:57 AM.. |
01-02-2022, 01:52 PM | #4338 |
Rep 54
Drives: 2017 M240i xDrive
I upgraded from a 2014 335i M Sport to a 2017 M240i.
So far I've installed black Sideview mirror caps with sequential turn signals. Tommy L Garage mud flaps. (Must have for F series cars!) MST intake. Next up is suspension. My 2 rear struts are leaking. Debating between new struts with Dinan Springs with ride quality kit or coilovers. Once the suspension is done I plan on doing MHD stage 1/2 and Remus exhaust. |
Tyresian69.00 |
01-04-2022, 05:41 PM | #4339 |
Rep 21
Added Apple CarPlay and upgraded My Idrive from ID4 to ID6 along with some other small things like enhanced Bluetooth, and M Animation startup! Thanks to kubax86, it was a easy as can be and took only an hour. Fantastic modern update!
qlaval52.50 christine119.50 |
01-04-2022, 09:30 PM | #4341 | |
Rep 344
Ron Jeffries388.00 |
01-05-2022, 06:55 PM | #4342 |
Rep 344
I wrapped my roof gloss black, looks great with the sunroof, didn't remove the shark fin to wrap since I'm getting a carbon fiber piece that fits directly over it.
freakystyly3053.50 qlaval52.50 |
01-06-2022, 09:55 AM | #4343 |
Rep 52
I'm considering this, but I was concerned how the rubber gasket trim would stand out with gloss back; it doesn't seem to be too bad. Did you wrap it yourself?
2016 M235i 6MT | VRSF Intercooler | Active Autowerke CP | VRSF Catless DP | M Performance Muffler | BM3 Tuned | 18" Alzor 030 Wheels | 8.8" Display & Apple CarPlay retrofit
F22leo245.00 |
01-06-2022, 10:04 AM | #4344 |
Rep 372
Installed an FTP charge pipe last week. Install went pretty smoothly, didn't need to remove the intercooler. Ended up having to cut the old CP out. The most difficult part was getting the new pipe onto the throttle body itself. I thought maybe the part wasn't made to spec. I lubed everything, cleaned the mating surfaces and it still took everything I had to get it seated so the C-clip would snap into place. Put about 400 miles on it and all is good.
01-06-2022, 10:05 AM | #4345 |
Rep 1,821
PO had wrapped the roof and it wasn't holding up too well near the windshield so I pulled it off when I bought it. It's easy enough to do on a nice day with a heat gun and some elbow grease if you ever tire of the look. I left the antenna wrapped, not sure why but it doesn't bother me.
F22leo245.00 |
01-06-2022, 01:09 PM | #4346 | |
Rep 344
01-06-2022, 03:12 PM | #4347 |
Rep 77
Washed it. Tried Bilt Hamber Auto Foam pre-wash. It did an amazing job!
PeanuKeeyes365.50 christine119.50 |
01-06-2022, 03:23 PM | #4348 | |
Rep 311
Careful with that thing! Car looks great.
E34 525iT 5 spd | 228i ZTR 6 spd [SOLD] | MX-5 NA 6 spd |
01-06-2022, 05:27 PM | #4349 |
Rep 1
Took This Photo...
New to the forum...have been a lurker for about a year as I was deciding on my next vehicle purchase. Well, it was an F22! Picked it up 2 months ago. What a fantastic little car! Just signed up to post this pic because I liked it alot! First snow this year.
01-07-2022, 11:28 AM | #4351 | |
Rep 160
You spray on, rinse, then proceed with your normal wash process?
[Build thread] Mineral White | Cognac | 6 speed | Moonroof deletion
01-07-2022, 09:40 PM | #4353 |
Rep 537
Just got the car back from the detail shop where they put Xpel PPF on the front bumper and hood. Should have done this a year ago when I first got the car. Had to use a Dr Color Chip kit on the biggest rock chip and got it pretty flush, can hardly see it under the Xpel film. Very happy with the results.
01-09-2022, 12:46 PM | #4354 |
Rep 35
a few things
My old driver's side mirror cap was broken and fell off, so yesterday I replaced both with an amazon CF pair for $100. Fitment was great and surprisingly its real carbon on top of an abs. I'm very pleased with it for the money, see if it holds up.. Lighting was bad so I had to use flash.
link to mirrors: https://www.amazon.com/dp/B08H7D9Q92...t_details&th=1 Couple of days before I installed some Amazon shift paddles to replace the stock ones ...Anddddd the day before I installed the shift paddles I put on a set of 19" BC Forged RZ05s!!! 19x8.5 45et up front and 19x9.5 50et in the rear, i think they fit perfectly. No pics of them yet because I'm on stock suspension, but you can get a peek of them in the mirror cap images. Thanks to Wahooooman for the wheels! |
Heitzer103.00 |
01-10-2022, 03:47 PM | #4355 |
Rep 208
Installed a VIOFO A119 V3 Dash Cam. Ran the cable between the windshield and the headliner and then in the rubber seal down the side to the ODB port as a power source. The ODB adapter has a switch that shuts off the power a few minutes after you turn off the engine. You can leave it on if you are running into a store, for example. No real visible wires and no hardwiring. I'm pretty happy with the install and so far no signs of battery issues.
christine119.50 |
01-14-2022, 12:14 PM | #4356 |
Rep 913
Started it up for the first time in 2022, drove to the inspection station to have it inspected for the first time (new cars in NJ have a 5 year inspection exemption), and drove away 10 minutes later with a new inspection sticker.
They did ask me to open the bonnet to visually verify it had a catalytic converter - the tech said the way it sounds he didn't think it had one.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
dradernh4462.50 |
