Autotalent
Go Back   BMW M3 and BMW M4 Forum > Classifieds > Members Classifieds > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar
      08-03-2015, 11:13 PM   #1
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
Direct fit Jehnert XE200 Midbass/woofers for sale
Shipping Costs Included
Hi guys,
I replaced my underseat woofers with a set of Jehnert XE200 Flatline woofers. These are designed as midbass speakers and have a great deal of musicality and sound great. Ideally they'd be used with a trunk mounted subwoofer. They are 4ohm and therefore you should run an amp with them - some people have run the stock amp with them and have been ok but you're working with a much lower impedance than stock (stock is 7 ohm vs the Jehnerts at 4 ohm) which will make the amp work harder and the stock amp is an expensive piece to replace.
I have the Bimmertech amp and DSP which is awesome and the Jehnerts are a great set of speakers at doing what they are supposed to do - just don't expect earth shattering rumble with them, expect a much more musical thump and slap. Like I said, my original plan was to use them with a trunk sub and that would really be the best plan ideally.
I paid $459 shipped, with the adapter rings that space them out more. I made simple plug and play wiring harnesses so you don't have to cut the factory harnesses. Includes replacement screws too, since you'll need longer ones with the adapter rings. They are basically brand new, installed and swapped for the Earthquakes after about 30 minutes of play time and a couple days of being installed.
Worked great in my F82 and will fit many other BMWs.
Your's for $400 shipped.
price drop to $325 shipped in the CONUS Sold!!!
DSC_3369 by Kit W, on Flickr
      08-04-2015, 07:20 AM   #2
tonydt1g3r
Drives: F83
do the earthquakes hit harder?
      08-08-2015, 04:37 PM   #3
kitw
kitw's Avatar
471
Depends on what kind of music you like - the earthquakes are 2 ohm and pull more power out of the amp but it works harder. I am not going to do a trunk sub and I was ok with the mid-bass hole with the earthquakes. Neither hit like a 12" in the trunk
f80post
