M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      01-19-2015, 12:49 PM   #1
rocky
rocky's Avatar
41
Drives: 2015 M5
Just had 1200 mile break in service - results
Dropped off the beast for it's 1200 mile break in service this morning. Ive had the car for 5 weeks and it had 1240 miles on the odometer. They changed the oil with 5-30. Service advisor said all M5s get the 5-30 grade oil. They also changed the transmission fluid and ran a computer check to make sure all is OK. Everything went well and per my instructions they did not wash the car or take it out for a test drive. But i did notice there was 4 tenths of a mile more on the odometer when i picked it up 2 hours later. Thats the distance from drop off to the service area and back to drop off. I was told they cleared all performance restrictions and the vehicle is ready for full performance. Thats what i wanted to hear! He said i might notice a bit more power after this break in service.... anybody experience that?
      01-19-2015, 01:21 PM   #2
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Definitely there is no more power, but you feel car is faster because you can redline it (if you didn't sofar because of manual instruction) . The restriction for Launch Control is removed and now you have access to this damn fun feature, but just be careful! Drive safe and enjoy your beast
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT
Gone : 2016 F82 Austin Yellow M4 - 6MT
Gone : 2013 F13 Sakhir Orange M6 -7DCT
Gone: 2013 F13 Alpine White 650i -ZF8
      01-19-2015, 01:25 PM   #3
David 12
David 12's Avatar
127
Drives: 2019 BMW X5 50i BSM, M Sport
I have about 3,800 miles in my 2014 and did not feel any increase in power after the 1,200 mile service. I remember a thread pertaining to this a few months ago and I don't believe anything is done to the car to impart more power.
Now, some folks may drive more aggressively!
Dave
You beat me to the answer M6!
      01-19-2015, 01:44 PM   #4
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
There's been a ton of posts about this topic. I believe the consensus is that there is NO additional power 'released' at the 1200 break in service.
But who friggin knows.......
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center
      01-19-2015, 02:21 PM   #5
gmfive
gmfive's Avatar
Drives: 2014 F10 M5 AW
2014 M5  [0.00]
It's in the mind please be careful and safe, this machine is deceptively fast.
2014 AW F10 M5, mostly stock
      01-19-2015, 04:30 PM   #6
MCarsFan
MCarsFan's Avatar
Drives: 2014 BMW M5 F10 CP
2014 BMW F10 M5  [10.00]
Almost certain there was a power increase after the run in service. That said I never redlined the car during the run in period either. Speaking to my BMW technician at the run in, he did mention that on the early M's the run in service was purely to make sure that the cars were running well, but that the new M cars have their power slightly restricted during the run in. Also different oil used during the run in.
      01-19-2015, 06:11 PM   #7
bronch
Waiting for the sun
bronch's Avatar
66
Drives: 2018 M240ix
I thought they were supposed to replace the oil drain plug too? Or is that other Ms?
2012 E92 M3- Miss her.
2015 F10 M5- Land yacht, but miss her too!
2016 991.1 GT3- Woohoo!
2018 M240ix- Daily driver. Still Woohoo!
      01-19-2015, 08:07 PM   #8
Bibendum
Drives: 2013 M5
I certainly hope they unlock something because my 15 CP feels like a pig compared to my 13 pre-LCI and no CP!!!
      01-19-2015, 08:26 PM   #9
MCarsFan
MCarsFan's Avatar
Got the same impression running in my 13 M5 vs my 14 M5 CP..
      01-19-2015, 08:34 PM   #10
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
There is definitely no increase in power. Like others have mentioned this is a very old topic. There was a consensus a while back that at the most, what there probably is, is some sort of ECU damping to restrict power during the Break-In period, just like owners of the new C7 Z06 are finding out. Also, just be warned that the ECU records how many times the Launch Control has been used and if something were to go wrong with the engine, some dealers have had the propensity to blame whatever went wrong with your car on the prodigious use of Launch Control and blame you for the problem. Some dealers, not all, but it has been known to happen with lame dealerships.
      01-19-2015, 09:01 PM   #11
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Originally Posted by RPiM5 View Post
... Also, just be warned that the ECU records how many times the Launch Control has been used and if something were to go wrong with the engine, some dealers have had the propensity to blame whatever went wrong with your car on the prodigious use of Launch Control and blame you for the problem. Some dealers, not all, but it has been known to happen with lame dealerships.
This is correct statement; however basically they cannot blame or void warranty since there is no specific and clear statement about number of LC in user's manual. All is said is that " Don't use Launch Control too often".
There is no doubt that Launch Control or hard acceleration with DSF OFF will put lots of stress on clutch and transmission, but this is an M car not TOYOTA
I have asked my SA several times about the number of times we are allowed to use LC and each time his answer is: Let me figure it out...I will get back to you
      01-19-2015, 09:06 PM   #12
Bibendum
Drives: 2013 M5
What do you mean be damping? Isn't that a reduction?
Or are you saying the engine still produces the same HP at each specific RPM, but it takes longer to spool up? But wouldn't that also be a reduction?
If the engine is de-rated in any way during break in and then you get the full beans after the service, isn't that an increase?
Either way, my 15 CP drives like a pig. I wish I never turned in my 13. It's that bad.
      01-19-2015, 09:09 PM   #13
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
That's all placebo man, unless you have recorded some hard metrics. The Comp Pack M5 has been proven time and again to be faster than an Non-Comp Pack M5. Have you done Break-In Service yet?
      01-19-2015, 09:14 PM   #14
bronch
Waiting for the sun
bronch's Avatar
66
Drives: 2018 M240ix
...Either way, my 15 CP drives like a pig. I wish I never turned in my 13. It's that bad.
I haven't heard that comparison yet. It's the same drivetrain +15HP, no? Sounds like something may be wrong, as it's hard to believe BMW would BS the numbers or detune later model releases.
      01-19-2015, 10:04 PM   #15
Bibendum
Drives: 2013 M5
Haven't done break in service yet. Only have a couple of hundred miles. Need to reserve final judgment until then.
Never doubting the numbers. Just butt Dyno.
      01-19-2015, 10:13 PM   #16
MCarsFan
MCarsFan's Avatar
That said it's purely academic now as very happy with the 14 M5!
2014 BMW F10 M5 ZCP | SSII / Black | MSR Stage III | MSR Intakes | RPi GTM Exhaust | RPi Catless Downpipes |RW Carbon Front Lip | RW Carbon Diffuser | RW Carbon Trunk Spoiler |
      01-20-2015, 07:41 AM   #17
richard in NC
Drives: 2009 Z4 35i
Could it be either the new car hasn't adapted to your driving style yet?
Or it simply is still a very tight motor. Most engines do perform and rev better with a few miles on them.
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims
Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i
      01-20-2015, 09:15 AM   #18
Bibendum
Drives: 2013 M5
Car definitely needs to loosen up a bit. Will take some miles.
m5post
