05-17-2017, 08:05 AM | #529 | |
Rep 8,942
05-17-2017, 01:40 PM | #530 | |
Rep 2,942
Also, this has been repeated so many times in other threads, the issue needs to pretty much die: 2 Series HK systems are not Logic7 systems controlled by a fiber-optic MOST interface. The 2 Series HK system is completely analog. You're welcome.
05-17-2017, 04:31 PM | #531 |
Rep 55
I appreciate the assessment of the JL Audio C1-400x (as a downgrade to the recommended C2-400x). And the suggestions on coding out the ASD make sense (I was planning to do a resonator delete for the exhaust system anyway on my upcoming M240). So I noted that a couple of owner comments mention choosing Morel Maximo Ultra 402 Coax speakers for the rear shelf. Based on price ($140/pair), they may be of equal or higher quality than the C2-400's but also have a higher sensitivity (87.5 dB) to better match the Etons in the front doors. They are 2 1/8" deep, however, and I don't know if there is a depth restriction in the rear shelf (the C2-400's are only 1 15/16" deep). Any shortcomings/assessments of the Morel's compared to the C2-400's? Is the sensitivity matching worth paying more for the speakers? Would the "warm" sound from the Morel's not work well with the Eton's? Viffermike: Can you offer an opinion on this? I am trying to make a rear-shelf speaker selection but don't know how important higher sensitivity is between the JL Audio C2's (84.5 dB) and the Morel Maximo Ultra 402's (87.5 dB). |
05-17-2017, 04:39 PM | #532 | |
Rep 2,942
Note that the sensitivity difference is 3dB between the two models. Relative Sound Pressure Level (SPL) -- known to most of us as volume -- doubles for every 3dB measured. That means that, with 1 watt feeding each speaker, the Morels will be twice as loud as the JL Audios at 1 meter away -- basically the distance between these speakers and your head in the 2 Series. They still won't be as loud as the OEM speakers, but the difference is not great. My bet is you'll love 'em. Morels are great speakers. As for depth: it's not a tremendous issue in the rear deck. There's at least 3.5 inches of clearance back there.
05-17-2017, 06:51 PM | #533 |
Rep 55
Viffermike:
Thanks! Appreciate your insight. |
Viffermike1753.00 |
05-22-2017, 02:40 PM | #534 |
Rep 7
Why not just use the Eton B100XN coaxial speakers for the rears? They would match the fronts perfectly and are meant to be drop-in replacements with no modifications needed.
05-23-2017, 05:22 PM | #535 | |
Rep 2,942
(Programming note: Etons are not available in the U.S. Those of us who have opted for them across the pond have ordered them from the EU, which takes time and some risk.)
05-25-2017, 09:44 AM | #536 |
Rep 7
Thanks. Very curious about the ASD changes in 2017 cars. I was going to import an ASD harness but may not bother if coding is sufficient. I've tried searching the forum but can't find further info on this, has anyone got a link or details?
06-21-2017, 01:42 PM | #537 | |
Rep 1,345
No one commented on what I thought to be the insanity of buying $700 4" 2 way speakers for this application! Even though Crutchfield does have them on sale for only $400! Seems like major overkill. However not many comments on the Focal PC 100s. At $280 a pair with 90 db sensitivity, these could be very good. I ran these in my Porsche with very good results. I think in a car application you need more high frequency energy to offset the road noise. I'm also curious about the use of the 3.5mm audio input. Compared to the usb port, in a Porsche the audio was horrible. You are taking analog output to a poor input. At least the usb port takes a line level input, perhaps not digital, but at least pre portable amp. Using any iPod with uncompressed audio yields very pleasing results. |
06-21-2017, 03:22 PM | #540 | |
Rep 2,942
The biggest mistake the poster made with this install was mixing the aramid/kevlar drivers of the K2 set with the aluminum/fiberglass drivers of the AC 100s. They just don't play well together. The PC 100s, though a better speaker, wouldn't be a good match, either because it, too, uses metal for its tweeter (which, IIRC, is a partially loaded design). A few posters have tried the Focal Integration BMW subs; the consensus is that they're great for what they are if you're OK with the relatively high cost -- they're basically the most expensive PnP underseat solution on the market. As for your comments on the Aux-in/USB: I'm confused by them. USB isn't an analog input, so there's no "line level" that applies to it. Are you talking about plugging in an iPod to the Aux in jack next to the USB post, perhaps?
06-21-2017, 09:41 PM | #541 |
Rep 1,345
Thanks, appreciate the response.
I know they are separates, not coaxials. Still an insane amount for a 4" speaker unless you are building a super high end system. The 2 series hardly seems worthy. Especially without decent bass drivers other than the subwoofers. This system seems really compromised unless one does a major custom job to add 8" speakers somehow. The dedicated Focal ifbmw-c speakers look very nice, but seem to have identical specs to the PC100s. Not exactly a value proposition. I had very good results with a predecessor to the PC100, maybe CVX 100 if I recall correctly. Also, they have directable tweeters, so they could be angled towards the listener from locations in the 2 like the rear shelf and down on the doors. Problem with the factory speakers is they are very glaring, without real highs. You need to turn up the treble to get reasonable highs out of them, but you don't get any real crisp highs. Of course, they can't be too "crisp" or they will simply be fatiguing. Since we need to rely on the subs for not only deep bass, but mid bass, what are good recommendations on the value end? The Focals are over $500. Are cheaper alternatives worthwhile? Since "bass" is coming out of 4" speakers otherwise, the subs seem like a key item to focus on. Even the better 4" Focals only go down to 70 Hz. The PC100s are speced to only 90 Hz. Do these subs add punch? Are they crisp? Or are they just another muddy set of subwoofers that try to rattle things? I'm very leery of subs and greatly prefer a good solid bass driver. Really not an option here as mentioned. Ah, on the inputs. I believe the USB IS an analog input. It COULD be a digital input if you read data from it like from a thumb drive. Then you rely on the DAC in the car system. I've found that plugging in an iPod into the USB port is taking line level analog output into the audio system. I think I would prefer the iPod DAC to the DAC in the car stereo. I don't know that much about the BMW system, so happily corrected here. In a Porsche, the aux jack was an incredibly poor input. Connecting any player (Fiio, whatever) resulted in MUCH poorer sound quality than using an iPod through the dedicated iPod connection. |
06-22-2017, 10:03 AM | #542 | |||||
Rep 2,942
But going along with your point: If the K2 Power set ($749 retail) is 'insane', then these Morel speakers are just as insane (and these are Morel's fourth-level set: the Elate Titaniums start at more than $2k), and an equivalent set by, say, Dynaudio is even more. It's all relative, and basically subjective ... ... BUT: If you think about the system you want and match things properly, you don't have to spend that much. For instance: Would I consider running Morel Tempo components in a Porsche? I absolutely would -- and, actually, I am (I have a 718 Cayman on order). Quote:
I personally use a FiiO X3v2 loaded with either AIFF or FLAC files through the Aux In most of the time. It sounds incredible.
06-22-2017, 10:29 PM | #543 |
Rep 1,345
Thanks much for the info. In terms of cost, there are plenty of ways to spend money, no question about it. I'm also into high end audio. I only question spending a lot of money on 4" speakers as part of a kit that only has 4" speakers! Spend what you like physics here are incredibly limiting.
Curious about the aux input. In my Porsche, the sound was horrible. I ran a Fiio through it and got rid of it. I run lossless on the last model iPod classic and get pretty good quality with the benefit of music on the display (something you completely lose with the aux input). Another element to keep in mind. Thanks for the links! |
06-22-2017, 10:34 PM | #544 |
Rep 1,345
The Bavsound ghosts versus the Focals, which is better? I would bet on the Focals, but without experience, just on the brand. The Focals really don't cost much more.
06-23-2017, 07:54 PM | #545 |
Rep 121
Ryem3 I went with the Focal K2 and Focal under seat subs. Mike what are you thoughts on that arc amp vs 70.6? What would you consider sound quality amps?
06-23-2017, 10:33 PM | #546 |
Rep 1,345
06-23-2017, 10:37 PM | #547 | |
Rep 1,345
06-23-2017, 11:04 PM | #548 | ||
Rep 2,942
USB = Universal Serial Bus. It is a data bus designed primarily to supply digital information from computers to peripherals. As such, it requires a driver both upstream and downstream. It became the data bus standard primarily because it was the first widely used bus protocol to also have power supply capability. It has zero analog signal transfer capability. To wit: the Lightning-to-3.5mm adapter that comes packaged with all iPhone 7s has a DAC built into the USB-side housing. Also to wit: If USB could transfer analog audio, why haven't we seen any USB headphones on the market? There is NO current bus technology that carries analog audio: Not USB/USB-C, not HDMI, not FireWire, not Lightning, not Thunderbolt. It's all 1s and 0s, and it all requires a DAC of some sort to convert it to audio.
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> Last edited by Viffermike; 06-27-2017 at 10:55 AM.. |
06-26-2017, 07:53 PM | #550 |
Rep 465
I'm a little puzzled that you posted this particular video as you did. Some of your comments are helpful in identifying shortcomings of the HK system but you ask for comments. You are post #549. Have you read any of the previous 548 posts?
Bavarienne6.00 |
