2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Dr. Strangelove, or How I Learned to Stop Worrying & Live w the Harmon Kardon System
      03-11-2016, 03:57 PM   #1
selmeralto
selmeralto's Avatar
227
Drives: 2021 M2 Competition
(With apologies to Stanley Kubrick.)
What follows is a relatively low-cost way to make the Harmon Kardon audio system sound good.
The original post is in black. My updates are in red. There have been many comments and updates to this thread. I edit this initial post (#1) to keep it current but subscribers to this thread don't get notifications of edits so if you're interested in the audio upgrade solution recommended here I suggest you read all the posts that follow and return to #1 from time to time to keep current.
WORRYING.
I was angry and disappointed with the Harmon Kardon system for 7 reasons:
1. The HK system sounds awful: it is harsh, especially toward the upper end, fatiguing, and uneven across the audio spectrum. The bass has no solidity.
2. The HK system has a poor soundstage: instruments and voices lack clear spatial definition.
3. The HK system has very little capacity to customize the sound: just treble and bass tone controls that, sadly, boost their respective spectrums unevenly. No mid-range adjustment. No EQ.
4. The HK system is integrated so tightly with the car’s electronics that replacing components is a challenge.
5. The HK system is noisy: from the factory there’s an annoying upper frequency hiss that apparently comes from the Active Sound Design (ASD) module linked to the HK amp.
The HK sound is also muddied by the fake engine noise that ASD puts through the speakers.
6. The HK system is expensive, especially for what you get.
Depressing reality checks: The Sony system on the Ford hybrid C-Max SUV (MSRP $24,170) costs $275 less than the HK and has a mid-range adjustment. The Sony sounds better than the HK. I rented a run-of-the-mill Nissan Altima. It had a 3-band equalizer. The $5.99 Neutron music player app on my Galaxy phone has a 4-band equalizer.
I was particularly annoyed that my immediate impression after listening to the system for the first time was that, after springing for the “premium” system, I was facing the proposition of spending even more money to upgrade the “upgraded” system. I expect more of a $50K car. The poor quality of this "premium" option diminishes the luster of the BMW brand.
7. I add a quirk reported by some members that the HK subwoofers may unexpectedly go offline, usually coming back after a car restart. This may be caused by the amp overheating under load, especially prolonged heavy bass draws. This is an annoyance but it happens infrequently and isn't a big deal.
NOT WORRYING. LIVING.
I have however arrived at a compromise that doesn’t involve too much more money and that makes the system sound good. I’ve concentrated on reducing noise and making modest equipment improvements, primarily to the speakers, to improve the audio. This solution avoids having to interfere with the complicated computerized electronics of the car. None of the modifications requires any specialized skill or equipment. For the record, I’m a lifelong audiophile with preferences toward natural, clean and dynamic sound. I am not so much interested in high-thud sound but I do appreciate clear, solid, well defined bass. I listen to all kinds of music.
Here’s what I've done, with money and time outlays listed. Thanks to all the people on the forum who made various suggestions about these changes.
1. Disconnected the center channel speakers.
Results: better soundstage and a little cleaner sound. You’ll need a small Torx ratchet set.
Time: Under an hour.
Cost: $0.
This procedure has no effect on the navigation voice, which comes through loud and clear through the rest of the speaker system.
2. Installed the Technic Active Sound removal harness.
Results: (1) eliminates the fake motor/exhaust sound fed through the speakers and (2) reduces if not eliminates the hiss that interferes with the music from the audio system and was giving me headaches. Not only is the sound system improved but the car is noticeably quieter. Zooks527 has a terrific installation tutorial on the forum: http://www.2addicts.com/forums/showthread.php?t=1202389 .
Time: about 2 hours.
Cost: $65.
[CAUTION: I had a problem with the BMW SOS emergency button after my audio mods. It seemed at first that the harness might be incompatible with the BMW SOS emergency button, rendering the SOS service inoperable. It turned out, however, after investigation that the harness is safe. The SOS problem was due to a defect in the BMW telematics control unit, which operates independently of the ASD and the harness. No need to worry.]
Installation of the original version of the harness results in a reduction in bass response and some other audible issues. Forum member Silver6spd discovered that an incorrect wiring setup in the harness was causing the problem which was itself the result of a mistake in BMW's original OEM schematic regarding the polarity of the left front speaker.
The fix is easy:
1. Among the looping wires in the harness you'll find a white wire and a white/black wire.
2. Cut each of these two wires at the center.
3. Connect the wires crosswise so that each wire consists of a white-connected-to-a-white/black wire.
4. Put a wire connector or a wire nut or electrical tape on each. Make sure you don't over-tighten the wire nut and break one of the connections - or you'll lose sound to a speaker. Test for sound and you're all done.
Thanks to Silver6spd for recognizing the problem and tracking down a solution. Future versions of the Technic harness will have the correct wiring. Thanks also to Technic for working to correct the issue. Pictures of the simple fix at are posts #252 and 253, below.
A cleaner solution involving a little more time and effort changing the pins rather than splicing the wires has been suggested by mdputnam: http://www.2addicts.com/forums/showt...9#post20512019.
Use the approach with which you're more comfortable: there's no difference electronically or sonically. The fix is well worth making since the harness results in a noticeable improvement of the sound of the system.
3. I'll be installing the BMW weather-stripping on the front doors.
Results: reduces- engine and road noise for an even quieter cabin.
Time: 20 minutes.
Cost: $30.
I've now installed the weather-stripping. Quieter as advertised.
For information on ordering the weather-stripping, see posts #171-3, below.
Note that the correct part numbers are 51487300693 and 51487300694.
A thread on installing the weather-stripping is at http://www.2addicts.com/forums/showt...atherstripping .
4. Replaced the HK stock speakers in the front doors with Eton B100W component speakers (mid-range + tweeter for each door).
Results: tighter and cleaner sound with a smooth, more natural sound across the spectrum and a punchier mid-low. The harshness of the mid-upper and upper end of the HK system is gone. Eton speakers are highly regarded in Germany and on the Continent but are not very well known in North America. These are very fine and reasonably-priced speakers. They can be ordered from Germany via Amazon or the Extreme Audio website. Mine arrived in a week, delivered to the door by FedEx. Many forum members in the U.S. have ordered the speakers from Germany with no problems.
The speakers are an easy installation, assuming you’re not squeamish about taking the door panels off. The speakers are an exact fit with no additional adapters or connectors needed. Though you do need to be careful: one member accidentally drilled through a wire connected to the airbag system. Just work slowly and you'll be alright.
Bonus: opportunity to add sound deadening material – I used Dynamat Extreme – to the door frame around the mid-range and to the door panel. Eton makes different versions of the speaker. It’s important that you order the “B100W” version. Grave has posted an excellent installation tutorial on the forum. He has good pictures accompanied by instructions in French. See his post at http://bmw-one.com/phpbb3/viewtopic.php?f=21&t=34196 . I've written up a (very poor) English translation of his instructions that I can PM. For further help on the installation see also Solarphil's excellent guide at http://www.2addicts.com/forums/showthread.php?t=1258290 .
Time: about 4 hours but I really took my time, trying not to put a screwdriver through a cone. That includes Dynamatting the doors and panels. A less cautious amateur could probably do the job in a couple of hours, a pro in an hour. If you have a pro do it, you shouldn't have to pay much since no special fittings are required: it's plug and play after the panels come off.
It's well worth it to make this investment since most of the sound comes from the front speakers.
Cost: about $250, including shipping.
The total cost to make the HK system sound good (Technics harness, Eton speakers for the front doors, weatherstripping, some Dynamat) was just under $350, which is about as much money as I care to spend on the audio system right now, having already parted with $875 for the HK.
JL Audio speakers for the rear deck add another $75-100. See below.
Is the system all I wanted?
No. But it’s a damned sight better than the factory HK setup. The sound is tighter, cleaner, more natural sounding, and much easier to listen to at volume. The hiss seems to be gone. The cabin is much quieter. The HK woofers are OK.
If I’m overcome with a burning urge to relieve myself of more money on the audio system and I have time on my hands I’d probably, in order,
(5) Replace the rear speakers JL Audio C2-400x coaxes, as per Viffermike’s suggestion.
I broke down, bought, and installed these.
Result: Much more natural sound, huge difference in lower and mid-bass. The treble is also improved. Sure glad I did this.
Time: under an hour.
Cost: $75-$100.
The installation is extremely simple. Two of the three JL screw holes align exactly over two of the holes in the car. You can easily secure the third mounting tab by using a wide washer or similar item and the original BMW screw. Adding speakers to the rear of a convertible takes more work than in the hardtop and might require the help of a pro. See posts #222 & 224 in this thread and the "M235i Vert" thread.
Installation note: the original connectors are locking connectors. Use a very small screwdriver or an awl to release the lock. Don't just pull.
The increased and tighter bass may cause a bit of a rattle from the rear, even if you install the dynamat as recommended in this thread. The rattle comes from the child lock latches. An easy solution suggested by clemsonkev: pack the lock with a few packing foam peanuts and close the latch. Problem solved.
(-) Replace the HK underseat woofers. Time: a few hours. Cost: depends on choice but plan on around $500 for the pair.
Not necessary with the addition of the Eton and JL Audio speakers. Even doing one set of speakers improves the bass, especially the JL's in the back. One or two members have replaced the under-seat woofers with Bavtech and other speakers, leaving the original HK head unit. What change there was was unremarkable.
(-) Install a Bimmertech amp. Time: a few hours. Cost: $849.
Not necessary.
Another speaker option to consider is Bavsound. Their front door package (mid + tweeter) is about $100 more than the Etons. The Bavsound rear shelf speaker set is about $200 more than the JL Audio. They also offer a center channel speaker for $100 and a center channel tweeter for $100. Bavsound has announced that the package will rise by $100-200 on June 1st. There are other speaker options that are more expensive.
6. I will install more Dynamat as I work on the car.
I added Dynamat Extreme to most of the bare metal in the trunk. You can see a few photos of the Dynamatting in posts #126 & 148, below. My goal was to make the listening environment sepulchral. The car is now like a tomb and the sound is considerably improved, especially with respect to solidity and delineation of musical sources in the soundstage. I should add that road noise is considerably reduced, so adding Dynamat is not just an audio issue.
My choices reflect my prior conviction that it makes sense to improve the speakers before the electronics and my resistance to dumping tons of money on a system that, in the end, is still limited by the capabilities and limitations of the HK headunit/amp. I would much rather have had control of the audio from beginning to end, in which case I might have ordered the base sound unit and put the money in on a good, complete aftermarket system. I realize that there’s room to disagree on these points. But an important question is whether the HK head unit/amp is superior to the base HiFi unit. It probably is, in which case it probably makes sense to spring for the HK system, knowing that further expenditures are in your future.
I'm now done fooling around with the audio. The system is pretty good.
I hope this post is helpful to other HK owners similarly afflicted and to other 2-series potential buyers thinking of what options to include and exclude.
Reflections on Eton/JLAudio v. Bavsound/Bimmertech
The current price for Bavsound Stage One package upgrade (front and rear, including center channel, but excluding the subwoofers) is $797, with a possible price increase of $100-200 in summer 2016. Adding the Bimmertech amp ($849) puts the Bavsound/Bimmertech combo at between $1746-$1846. The Eton/JLAudio speaker combination is $350.
Is the nearly $1400-$1500 difference between Bavsound/Bimmertech and Eton/JLAudio worth it?
The Bimmertech amp is tunable (though not through a simple EQ array on the car's display) whereas the Eton/JLAudio fix relies on the HK tone controls. The ability to fine-tune the Bimmertech amp allows for more customization than the HK tone controls. Tuning the Bimmertech involves downloading and installing a tuning file with a laptop and a USB cable. You can then fine-tune the tuning manually with a laptop and cable. Installing and adjusting the tuning on the Bimmertech will be fun for some, a pain for others, since there no such thing as single standard or optimal tune that will satisfy all listeners. See http://www.2addicts.com/forums/showthread.php?t=1232178 for what's involved. In any event, installing a tune is not something that can be done on the fly if you want to alter the sound while driving or in a hurry, as you can do with conventional tone controls.
As for a judgment on the sound itself - which is, after all, the prize - it would be good to have the two systems side by side for an A/B comparison but the likelihood of that happening is very low.
But watch this space: an A/B comparison is coming soon.
After living with the upgrades listed here for quite some time, I personally don't feel the need for extra power or superior electronics in the car: the system sounds good and has all the power I need even at high revs and speed, especially since so much noise has been eliminated from the environment.
To this I would also note some difficulties forum members have had with Bavsound and Bimmertech.
First, several forums members have reported issues with Bavsound distribution, production line delays, missing parts, and speaker quality control.
Second, as reported by Zooks527, there is a potential problem that the Bimmertech 3rd party amp may cause routine dealer ECU flashes to abort and immobilize the car(!). The flash may be looking for a response from the audio that it doesn't get because of the 3rd party amp. Not seeing the response, the flash fails and the car turns into a brick.
When this happens the 3rd party amp has to be uninstalled and the stock amp reinstalled while the car is in the shop. The car can then be reflashed by the dealer. The 3rd party amp can be reinstalled after the flash in the shop or at home. If your car is immobilized in the shop you will have to tell the dealer the probable cause since the dealer may not be aware of the incompatibility of the amp with the flash procedure.
Note: The bricking problem appears to be caused by the 3rd party amp, not the Technics ASD bypass harness.
I am not aware of any dealer who has charged an owner for time and labor on reflashing the car and getting it to start, on the grounds that the owner's installation caused the problem. Nor have I heard of a dealer who has tried to void the warranty because of an amp installation. But these are possibilities. At best the problem is an unpleasant inconvenience - it's not exactly a barrel of fun to rip out the trunk liner and reinstall it, reseating it under the rubber trunk seal. And at worst the uninstallation and reinstallation could result in damage to the components, liner, and/or rubber seal, extra time at the dealer's, and perhaps even repair charges. There are other amps (for example, the JL 600/6) that cost less than the Bimmertech and amps that cost more but until we hear from owners of such amps who have actually had ECU flashes we have to assume the same risk applies. Now it should be pointed out that ECU flashes are only infrequently installed by dealers. That said, in order to be safe, owners with 3rd party amps need either to be sure to uninstall the amp before every visit to the dealership - which may not be possible in the case of unplanned or sudden visits - or ask the dealer not to flash the car - which is not a good policy. Ignoring this issue could leave you with an immobilized BMW on the shop floor. I should point out, though, that some members have reported having an ECU flash on cars with aftermarket amps installed, with no adverse results. So the jury is out on this one.
Forum member djarchow has reported that the Bimmertech amp may cut out when stepping on the brake and turning the headlights on. The culprit may be low level electrical noise in the car that causes the amp to shift to switch to AUX inputs, muting the main inputs.
All this gets back to the problem of the system's close integration with the car's computer systems. For a discussion of the risks of installing after-market electronics in this car, see this thread: http://www.2addicts.com/forums/showt...4#post20053574
I won't pursue the possibility, made in another thread, of installing a MusicarNW Stage 3 system at upwards of $5,000. This is way beyond what I could personally justify spending on an automotive sound system, especially considering how good the system can sound with the modest changes suggested above. For the record, I understand the irony of someone who has spent $50K on an automobile complaining about the extravagance of spending $5K on a sound upgrade.
Forum member fancyfl1ght has reported static white noise problems with the JL Audio xd800/8v2 amplifier.
There is some ongoing discussion about other possible polarity issues with the HK system but at the moment it's not clear that there actually are such problems. Moreover, as djarchow has argued in another thread, what might seem to be a simple issue with the polarity of a speaker can actually involve many other variables in the system. If we get confirmation that there actually is a specific problem with polarity (apart from the driver's side rear speaker), I'll provide an update to this thread. Until then best not to rush into changes.
Finally, a gentle reminder. When making electrical connections be sure that the connections stay secure. If you use wire nuts don't over tighten them or the wire may come out of the metal connector inside. Same for electrical tape: be sure as you wrap the tape that you don't undo the connection inside. I know this is Basic Working With Electricity 101 but at least two members (not naming names ) have inadvertently disconnected wires and have lost sound.
Conclusion: All in all, the simple speaker swap with sound deadening and noise reduction seems to me the way to go from the standpoints of sound, convenience, price, and risk. People can choose which of the improvements to make on an incremental basis. If you have the inclination, though, I really do recommend carrying out the full installation.
I'd welcome others' views.
These reflections do not take into account the possibility of replacing the underseat woofers which, for reasons noted (posts #27 & #159, below), I'm not inclined to do at this point. The space limitations for the enclosures make it pretty unlikely that just replacing the speakers will make a significant difference at the lower end. As I said earlier I was trying to keep costs down to what I considered to be reasonable after spending for the "premium" HK upgrade. Philosophical reflections on how much money to spend on the underseat woofers are sprinkled through the discussion but see especially post #537 and following.
Appreciate 21
      03-11-2016, 04:04 PM   #2
Beartato
Beartato's Avatar
882
Result: reduced engine and road noise for an even quieter cabin.
Time: 20 minutes.
Cost: $30.
Could you elaborate? What in addition of the stock weather stripping helps?
Nice title BTW.
      03-11-2016, 05:19 PM   #3
Xenny
Drives: m235i
is disconnecting the center channel speaker worth it even if I don't plan on upgrading any other components?
      03-11-2016, 05:29 PM   #4
selmeralto
selmeralto's Avatar
227
Nice title BTW.
There's been a discussion at http://www.2addicts.com/forums/showt...hlight=weather about some weatherstripping that, apparently, has appeared on some but not all M235i's. It's a very cheap and easily installed option that's supposed to stop wind and some engine noise. I haven't done it yet but I will.
Thanks for the comment on the title. I hope I don't suffer the same fate as Major "King" Kong.
      03-11-2016, 05:38 PM   #5
selmeralto
selmeralto's Avatar
227
Yes. That's the first thing I did. It takes very little time and costs nothing.
The center channel isn't necessary for music reproduction and actually on the HK system the center channel messes with the soundstage using substandard speakers. It makes the sound very diffuse. By disconnecting the center channel you get a spatial sound array with more definition and a cleaner sound with more bite.
It's a small but noticeable difference. And if you want to make incremental changes as I did, as opposed to dropping $1K - $3K on the sound system, it's a good place to start.
Appreciate 4
      03-16-2016, 08:35 PM   #6
Beartato
Beartato's Avatar
882
Nuuuu I don't have that weather stripping. Thanks for the heads up.
I can vouch for the center speaker thing, disconnected mine this weekend and the soundscape is significantly better.
      03-25-2016, 04:29 PM   #7
selmeralto
selmeralto's Avatar
227
I've updated my system and I'm quite happy. Changes are recorded in the initial post.
      03-26-2016, 11:21 AM   #8
kdog26372
Drives: 2015 M235xi BSM
Was installing the rear speakers a drop in easy solution or did you need adapters or anything to make them fit? Also, in the HK system aren't the back speakers component and if so did you plug the tweeter hole with something since you went coaxial?
Thanks
      03-26-2016, 11:41 AM   #9
selmeralto
selmeralto's Avatar
227
The JL Audios went in very easily.
Yes, the HK unit is component. The car feeds a signal into a connector on the mid-range which has a crossover that feeds the tweeter by way of a second connector. I removed both connectors and just left the (disconnected) tweeter in place. I then connected the car's signal wires into the JL Audio. Worked like a charm. No problem with clearance.
Regarding the electrical connections I used a set of speaker wires that have a BMW compatible connector that I ordered on eBay. That way I didn't have to splice the car's wires. That's one option. But if you want to just splice into the wires that'd be easy, too: the speakers come with slide-on speaker connectors that can be crimped onto the speaker wires.
You don't need a physical adapter. The JL has 4 mounting holes. Two of them fit exactly over 2 of the 3 mounting holes in the car. You just bend and remove the two you aren't using and use the existing BMW screws to anchor the speaker. I tried the speakers with just those two mounting holes secured and the speakers sounded just fine. I went ahead and used a washer and the 3rd screw to anchor the last mount anyway, as insurance. I also installed narrow window weatherstripping foam under the mounting bracket to make sure the speaker installation is nice and tight. You shouldn't over-tighten the screws, though. You don't want to bend the metal frame.
The grille just pops out and you can make the change entirely from the top. It's really very fast.
I was really surprised at the huge difference in mid and lower bass response. And of course I knew from replacing the front speakers how truly terrible the HK tweeters are so it was great to get rid of them in the back. I highly recommend making the switch, especially since the change is so easy and cheap.
Thanks
      03-26-2016, 03:08 PM   #10
kdog26372
Ok thanks for the input; the stock HK rears produce next to no sound and everyone else says replacing the rears is a wast of time, but sounds like you've had a much different experience. For $100 I think I'll give it a try too.
      03-26-2016, 03:16 PM   #11
selmeralto
selmeralto's Avatar
227
I'm sure you'll notice a big difference. Let us know in any case. Good luck.
By the way, when installing the JLs make sure to line up the speaker mounting holes over the two car mounting holes carefully so that you tear away the right mounting tabs from the speakers. You'll be very unhappy if you tear off the wrong strips!
And if you splice the wires be sure you connect them correctly so that the speakers are in phase. Otherwise, your bass response in particular will suffer and the soundstage will lose definition. See note 129, below.
      03-26-2016, 03:22 PM   #12
kdog26372
Ok I'll let all know how it goes. Also I'd prefer to use the speaker wire harness, do you recall what the part # was? I searched Ebay and couldn't really figure out which one would work.
Thanks
      03-26-2016, 03:28 PM   #13
selmeralto
selmeralto's Avatar
227
If you search for
"BMW OEM Speaker Connector Harness Pigtail"
you should be able to pick it up.
I'm not sure what the forum protocol is on mentioning specific eBay items in a discussion so if you have trouble PM me and I'll send the exact link.
      03-26-2016, 03:33 PM   #14
selmeralto
selmeralto's Avatar
227
I'm sure you know this but you can simply crimp the JL connectors on to the bare wire in the pigtail harness and then slide the connectors on to the speakers. The pigtail harness has instructions to help you make sure you've got the polarity right on the connections.
      03-27-2016, 05:21 AM   #15
DanATL
Drives: '89 635CSi, '16 M235i, '23 X5
Great write up. Thanks, I'm all over it.
      03-27-2016, 07:39 AM   #16
selmeralto
selmeralto's Avatar
227
Thanks.
I might also mention that this solution involves a heresy.
The heresy is that the solution violates the principle, Thou shalt not mix speaker models and types.
But think about it. We use different speakers all the time for different effects: tweeters, mid-ranges, woofers, subwoofers. I realize that the use of Etons in the front and JLs in the back here is a little different. In particular, through the use of cross-overs we can control the differentiation of sounds sent to individual component speakers whereas I'm sending approximately the same signal to two systems with different sound signatures.
But the overall effect here is the same. In this case the Etons provide a natural sound throughout which is balanced by a more pronounced mid-bass and bass and high end in the JLs. I find the combination to work very nicely.
There is another theoretical drawback to mixing speaker models, that the soundstage would be adversely affected. But I don't think this is an issue in such a small environment, front to back. I myself don't notice a significant soundstage problem, though it's probably true that the soundstage would be marginally more defined if I had the same speakers throughout the car. The thing to keep in mind is that, with these changes, the soundstage is vastly improved over the HK setup.
One also has to consider matching impedances and efficiencies. But these are 4 ohm systems, as are the HK speakers, and they seem, at least to my ears, to have about the same volume levels. And there's always the fader control.
What I do notice is a noticeably improved sound at a modest price.
And the solution has the advantage of incremental changes: you can add the bits you like in any order as you feel the urge.
      03-27-2016, 03:28 PM   #17
DanATL
Selmer Alto.....just dawned on me. I'm slow on the uptake.
Anyway, I checked and I don't have the weather stripping on my 2016 M235i coupe so that's a quick fix.
I can't wait to get rid of the active sound. The droning is driving me crazy.
The rear speakers you mention are rather inexpensive so I'll give them a shot. Can always try something else if they don't do what I want.
      03-27-2016, 03:56 PM   #18
selmeralto
selmeralto's Avatar
227
Yup: you got it.
Yes, you won't be doing anything to permanently alter the car. You can even return it to the original horrid HK-ness if you like.
One other thing: I found it helpful to use needle nose pliers to remove the electrical connectors. There may be a latch on the side of the connector(s).
Good luck.
      04-01-2016, 02:00 PM   #19
kdog26372
Ok, so bought the JL Audio C2-400x coaxes to replace the rear HK's. ~$95 shipped for the pair. Then bought BMW harness on Ebay for $20 for 2. Maybe they were once $10/pair, but appear to be $10 each now.
Stuff should be installed next weekend and hoping for positive results. This is only forum I've found that someone actually tried and was impressed with replacing rears; most seem to feel they aren't worth changing in HK system. We'll soon find out and I'll let all know what I think. For $115 all in it's worth the risk to me and I can easily get most of that back by selling on Ebay if I don't like them.
      04-01-2016, 02:59 PM   #20
selmeralto
selmeralto's Avatar
227
Good. Let us know.
      04-08-2016, 04:16 PM   #21
kdog26372
Ok, so got around to installing the JL Audio C2-400x coaxes in the rear deck. Pretty straightforward installation. Take off grills using a thin plastic trim tool starting with a front corner and once that pops the rest just come off with ease. Take off 3 torx head screws using in my case a small allen like wrench individual torx. Can't use screwdriver type torx as you'll hit the back window, too tall. Then you simply use pliers to full out both clips to 4 inch speaker. The one wire will have a black grommet on it and go to the HK tweeter, tuck that one away and leave HK tweeter in place. Then plug in JL speaker using Ebay adapter using search BMW OEM Speaker Connector Harness Pigtail. It's $10 and says only 1 adapter, but there are 2 in box, so I ended up buying an extra that wasn't needed. You'll need to bend off 2 of the 4 JL tabs to mount the new speaker. I just used 2 screws and it was very secure. Easiest to do with seats folded down as headrest would be in way. 15 minutes and done if you have the tools handy.
Next is testing the sound. I have the HK system with no other mods. So just replaced the rear decks. As expected these speakers have a lower sensitivity when compared to the HK speakers up front, thus I needed to shift the fader to the rear to about the 65-70% range. Then main system volume will naturally need to be about 25% higher than you're used to get same volume level.
The sounds is substantially better. Simply put the soundstage appears to be around the front of your face rather than the front dashboard. The sounds is much more full particularly in the midrange and if I move the fader 100% to the back and turn volume 70% there's actually some base punch to be felt/heard whereas the HK were always garbage and tiny sounding. I can see how matching this with changing the fronts too would be a good combo, but I'd think the center would need to be changed or disconnected too if you went that route, maybe I'm wrong, but low sensitivity door speakers and high sensitivity center I'd think the center/worst speaker would be the dominating force up front in that setup.
All in all, a solid improvement for about $100. Side note, the HK speakers weigh next to nothing and appear to be complete garbage.
      04-08-2016, 05:10 PM   #22
Viffermike
Viffermike's Avatar
Just wait until you replace the fronts and disconnect that absolutely unnecessary center channel. "Solid" will become "surprising".
--Helmets are for closers.--
