11-23-2021, 05:49 PM | #1 |
Rep 171
Square 255s without camber plates?
Looking to run a more aggressive summer setup next season and trying to understand if 255’s all around is achievable without camber plates up front.
I will be having a set of wheels built so have full flexibility over offsets and widths. Car is xDrive on KW DDCs, Dinan F&R roll-bars, and VAC Motorsport thrust arms. Front strut to tire clearance on stock wheels w/ 225 PS4s = ~17mm. Prefer not to use spacers. Are 255s on 19x8.5 ET35 achievable/ the way to go without camber plates? Thanks all. |
01-10-2022, 08:44 PM | #2 | |
Rep 619
01-10-2022, 09:02 PM | #3 | ||
Rep 171
tgmsocal162.50 |
01-10-2022, 09:32 PM | #4 | ||||||
Hello
Rep 18
Running 245/35/18 square on my x drive m240i let me know if 255 works out for you |
01-11-2022, 07:38 AM | #5 | |
Rep 160
Unfortunately the tolerances with our cars are so low theres never any guarantee beyond the tried and true setups.
[Build thread] Mineral White | Cognac | 6 speed | Moonroof deletion
01-11-2022, 09:56 AM | #6 |
Rep 919
Off topic - I like your hood!
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
01-11-2022, 12:48 PM | #7 |
Rep 1,056
I hope to run the same 245 square, but reading through this forum gives me many mixed opinions on what is required to do this. Do you mind my asking what wheel sizes you are running, and if you are otherwise stock?
01-11-2022, 01:13 PM | #8 |
Rep 373
I'd love to run 235x40 square on 18x8 or 8.5, but again, so many mixed results...just can't stomach running 225s on the rear, even though it's well-documented to fit....
01-11-2022, 02:04 PM | #9 | ||
Rep 171
https://www.2addicts.com/forums/show....php?t=1846417 Thank you! I would be disappointed if I end up having to run 235's, hoping at the very least to be on 245's all around |
