01-29-2018, 03:33 AM | #199 | |
im a car
739
Rep 1,117
Drives: 220i M Sport | 520i M Sport
after a lot of trial and error (and bending my other fender) finally got the lca+ts combo and caster bushings installed (had to replace 10mm spacer with 5mm and raise height twice) to minimise rubbing. front does feel much grippier and responsive now but quite a headache to sort out the rubbing issues lol. kinda wish I just went with camber plates haha
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB] Instagram: @icyj95 | FB |
Dylan861330.00 |
07-09-2018, 04:58 PM | #200 | |
Rep 891
Bringing this thread back from the grave here. As many have found, fitting these LCAs can cause quite a headache for the ones lower than stock. Most of the forum posts are here on 2addicts, and I do know that the front fenders on the F22 are tighter than the F30, but I was wondering if you or anyone in here may know what I should expect when I install LCAs to my F30 (haven't gotten a reply on F30Post). I'm considering the F8X TSs as well, but some have reported still having clearance issues once installed, so I'm unsure if worth the investment (as I can add them myself later without another alignment, if needed). I'm also contemplating having the shop raise my front end 1/4-1/2" up front to help mitigate potential rubbing. If you or anyone else could chime in on their expectations, it would be greatly appreciated. I would love to hear "don't worry about it" too, hahaha. My wheels are 18x8.5et38 wrapped with 245/40 PS4S (1.2% smaller than OE) [IMG] View post on imgur.com [/IMG]EDIT: I had the ride height raised about half an inch and the LCAs fit inside without a problem.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 07-10-2018 at 09:17 AM.. |
07-17-2018, 12:19 PM | #201 |
Rep 912
Curious - I've read the thread and it appears there was a complete kit for this and that vendor is no longer actively posting?
So - is there one vendor that offers all the parts as a kit to do this? |
07-18-2018, 03:05 PM | #202 |
Rep 891
So I have my car in the shop as I write this and I just got off the phone with them. While they haven't reported any issues as far as rubbing goes, my foreman was concerned with the extension of the tie rod ends and that they are very close to the end of adjustment to compensate for all the toe these add.
My question is, has anyone here ran into any issues with their tie rods in conjuncture with this upgrade? I have done some searching across the board and I can't seem to find anyone even hinting at their tie rod arms not successfully accommodating the excess toe compensation. Thanks in advance. (post is in another thread as well) Edit: Called Turner Motorsport and spoke to Doug. He says they've installed these to countless cars and never had a problem getting it aligned, or had knowledge of problems related to tie rod ends reported later.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 03-27-2019 at 03:21 PM.. |
07-18-2018, 09:42 PM | #203 | |
Rep 1,184
The threaded rod that we use is typically cut from mild steel. I would imagine that this is weaker than most bolts used in automotive. A 1/2" rod would have 1/2" insertion and a 3/8" rod would have 3/8". That is typically the height of the associated nut. |
MacklinUSOB519.00 |
07-18-2018, 10:23 PM | #204 |
3727
Rep 3,632
Assuming the materials that are threaded are roughly equivalent in strength, 6 complete threads is normally the minimum for standard threads, for example M12x1.5 or M12x1.75, but 8 threads for a less common ultra fine thread such as M12x1.25.
MacklinUSOB519.00 |
07-19-2018, 11:31 AM | #205 | ||
Rep 891
"Install new front control arms. INSTALLED CUSTOMER SUPPLIED FRONT LOWER CONTROL ARMS. UPON INSTALL TECH NOTED THAT TIE ROD ENDS ARE AT MAX ADJUSTMENT. ADVISE CUSTOMER THAT TIE RODS ARE UNSAFE FOR DAILY DRIVING, THREADED ENDS ARE ONLY CAPTURED BY CLAMPING SECTION OF OUTER TIE ROD END. CUSTOMER DECLINED FURTHER REPAIRS OR REPLACEMENT PARTS AND REQUESTED CAR BE DELIVERED AS IS."
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
07-27-2018, 02:10 PM | #206 | |
Diligentia Vis Celeritas
559
Rep 1,476
Drives: 335i
Dylan861330.00 MacklinUSOB519.00 |
07-27-2018, 03:32 PM | #207 | |
Rep 891
I had my KW's raised up to max height (only another 1/2" up) because I wanted to be sure it'd be good under compression at LRP and I didn't have a single instance of rub. I'm running the 18x8.5 ET38 SM-10s with 245/40-18 PS4S, good to know I have room if I choose to upsize to 255s. The arms make a fantastic difference on track, the bushings and extra camber really help out a ton. Very happy with the mod, even without the tension arms.
07-27-2018, 05:43 PM | #208 |
Rep 2,214
The LCA/TS mod absolutely send more vibes and feedback through the steering column. Between that and coilovers I get wheel movement/feedback from almost everything, probably more than most would want, lol. This is why most people buy M cars, "feel", and I can see how one person driving an M2, then an M235 would be suggesting a "numbness" from the M235, it's exactly what BMW intended on doing.
We're lucky to have the flexibility to do this, it's a great mod for the F22/F30 crowd!
12-11-2018, 01:44 PM | #211 |
559
Rep 1,476
Drives: 335i
negative
12-13-2018, 03:27 AM | #212 |
im a car
739
Rep 1,117
I had some rattling/knocking over bumps which largely went away after alignment. After alignment I still get a few noises but nowhere near as much
12-14-2018, 09:12 PM | #213 |
Rep 136
01-13-2019, 08:10 AM | #215 | |
Rep 928
01-13-2019, 04:42 PM | #216 |
Rep 9,708
From memory I used 12.2mm and 6.3mm, which replicated the positioning of the stock bushing. Was a tight fit.
I also used a 2mm spacer for the LCA. OD 30mm stainless steel. No knocking experienced whatsoever. Also a bit of a Meh!!! mod. Not the vast improvement others before me made out. The tighter M bushings made the most difference IMO. |
01-14-2019, 04:28 PM | #217 | |
Rep 928
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
01-14-2019, 06:41 PM | #218 | ||
Rep 928
02-03-2019, 01:21 PM | #219 |
Rep 176
Question:
I just love the look of some negative camber. Would just adding the M4 LCA on its own be ok? My car has a tiny knock at 55k miles which to me indicates worn bushings and soon will need to replace. Any possible adverse effects to consider? I noticed some comments on rubbing. A bit of info: my car is 100% stock. Only looking to upgrade the stock 18" wheels to 18" wheels that are 8.5"front, 9.5" rear with 235 & 255 tires respectively. |
02-03-2019, 07:38 PM | #220 | |
Rep 891
