BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      06-23-2016, 02:54 PM   #1
1spirit
Drives: BMW 135i
Talking First Time Drifting on the Track
Here's my first try at drifting on a circuit, and why people get hooked to this crazy activity is starting to make sense. The wet conditions caused for a much slower pace on the track, providing for a perfect opportunity to practice and learn. As I'm not confident in my drifting skills at the moment, I proceeded with each slide as slow as possible. My irreversible path towards hooningdom may have begun...
Setup: Stock tune, 235 square (Hankook RS3), Ohlins R&T, Quaife LSD, M3 arms/bushings, Vorshlag camber plates at -2.1
Camera: GoPro HERO4 Black
This same video without music: link
      07-14-2016, 11:23 AM   #2
MVEED3
Drives: '16 GT4
Not bad for your first time. You were improving toward the end. The LSD likely helped but I'd flush that fluid soon.
Have you done rodeo in the past? Your right hand had a rodeo reaction
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick
2016 Agate Grey GT4 PCCB LWB
2013 HP4 Competition
      07-15-2016, 12:51 PM   #3
1spirit
Drives: BMW 135i
Thanks for the comment! Regarding the fluid, Quaife says it is a fit and forget item with absolutely no maintenance required. Aside from an initial break-in flush that was already done at 1K, I originally planned on doing the next one at 30K miles. But on second thought, you're probably right - it can't hurt to flush the fluid much sooner with this kind of driving. Good suggestion. In retrospect, I'd choose an OS Giken instead...never foresaw myself doing this kind of driving
Only on a machine simulated one once a long time ago.
      07-15-2016, 01:01 PM   #4
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
A quaife ATB LSD doesnt have clutches inside, its a helical gear lsd so fluid ages the same as on an open diff
      07-15-2016, 01:07 PM   #5
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
Looks like a good start... if you want to get more into drifting, you'd need some changes to your car.
You'd be able to drift easier with a clutch type LSD. The Quaife doesn't do any lock up on deceleration and you'd want more aggressive and faster locking so you can power both wheels evenly for drifting. Quiafe is designed for cornering, not sliding. It'll send more power to one wheel or the other, it never locks fully.
Auto Detailing Enthusiast!
1spirit204.50
      07-15-2016, 01:38 PM   #6
1spirit
Drives: BMW 135i
Thanks for the suggestion. If I were to choose again now, I'd for sure get the OS Giken. The Quaife was installed when I thought all my driving would be on the street.
Some say I should get a different car altogether for drifting...but this car will have to make do with some changes.
      07-15-2016, 01:54 PM   #7
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Yes they do, but maybe not as much as an agressive ramped salisury LSD, so less noticeable. It's also (I think) impossible to adjust deceleration lockup in the design without affecting the acceleration lockup (which is it's primary goal).
Another big difference is that a salisbury clutch LSD always locks as long as throttle is applied (more throttle=more lock). The quaife only locks when one wheel cant put the power down. So the salisbury has a more tendency to oversteer when throttle is applied and the quaife more or less followes the balance on which the chassis/wheel geometry was designed. So like you said very much designed for cornering (as it constantly adjusts lockup to the need of the tyres, its a force balance) and maybe more driveable on a day to day basis, certainly more predictable in wet or treacherous conditions. But for drifting not the #1 choice.
But the quaife seems to do fine in the video (with me, drifting is more like facing the wrong way ), the thing it wont be as good at is like that car in front sliding the tail left and right on a straight piece of road. But that car is a purpose build driftcar judging by the steering angles and front geometry.
1spirit204.50
      07-15-2016, 02:40 PM   #8
1spirit
Drives: BMW 135i
That is cool to know!
I like how you observed till the end
I felt out of place with the 135i...seemed almost everyone brought a purpose build drift car out there. There were many Nissan 200/240SX's - those drift so easily and naturally.
      07-15-2016, 03:18 PM   #9
Z K
Z K's Avatar
1889
I had a 1991 S13 model 240sx swapped with the SR20DET turbocharged engine from Japan. It's small by today's standards and 300hp in a 2700lb car is fast by most standards. In stock form with the US engine, it is not a great car. But with relatively little modifications and upgrades, it becomes a weapon on track.
It is by far the most popular platform to modify in Japan so there is a huge following and aftermarket support for it. When production ended in 2002 with the S15 model (never sold in the USA), it was huge blow to the Japanese enthusiast community.
I dumped a good $30k in restoration and modifications to my 240sx. It was in mint condition when I sold it. It's the one car I really regret letting go. I just didn't have the time and space for a project car anymore. Maybe when the S15 becomes legal to own 10 years from now, I'll revisit the dream of owning one of Japan's iconic tuner cars.
1spirit204.50
      07-16-2016, 01:50 PM   #10
1spirit
Drives: BMW 135i
Z K, thanks for sharing the story. That was one light beast! It's sad to hear you let her go...but hopefully you'll reunite with one someday. The car is one I'd love to have in my future garage.
      08-05-2016, 02:58 AM   #11
skyscraper_g80
skyscraper_g80's Avatar
Australia
371
Drives: 2022 G80 M3 Competition xDrive
Nice work! I had a Quaife on my 130i but then got into drifting and upgraded to the OS Giken
1spirit204.50
1addicts
