2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Drivetrain malfunction and fuel rail codes
      06-20-2020, 07:15 PM   #1
K8_M235i
K8_M235i's Avatar
Drives: CM E36
Today I got a Drivetrain Malfunction followed by by fuel rail codes.
Has anyone ever dealt with these two lower codes? My car threw a drivetrain malfunction, shut off, then I restarted it and it was down at least a couple cylinders. I let it sit for 5 mins and it restarted like normal.
Throughout the day I randomly smelled gas a couple times as well.
Hpfp, injectors leaking, in tank fuel pump?
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM
1995 E36 M3 Sunbelt S52
      06-21-2020, 10:49 AM   #2
XutvJet
Mods? Any work been done on the motor?
      06-21-2020, 10:51 AM   #3
K8_M235i
K8_M235i's Avatar
Drives: CM E36
It's completely stock other than a fabspeed sport cat. Not tuned either
      06-22-2020, 11:59 AM   #4
Maynard
Drives: 228iX & M2C
Kinda looks like your high pressure system is leaking, or HPFP is going south. Smelling gas is suggesting the former. I'd get it checked real soon, and carry a fire extinguisher until then. If you do have a small leak in the high pressure side of things it can spray an explosively misted cloud of fuel, much more flammable than a simple drip leak from a carb or low-pressure line.
      06-22-2020, 12:32 PM   #5
Feddersen
Feddersen's Avatar
Denmark
451
Drives: X1 xDrive25i
I had the exact same errors on my F30 335i with MPPK - same engine as yours. It was a defect fuel pressure sensor.
      06-22-2020, 12:37 PM   #6
Feddersen
Feddersen's Avatar
Denmark
451
Partnumber: 13537620946
https://bimmercat.com/bmw/en/parts/i...0946/appliance
      06-22-2020, 12:38 PM   #7
K8_M235i
K8_M235i's Avatar
Drives: CM E36
I will be dropping it at the dealer this week. (Still under warranty). I do have a car fire extinguisher I'll throw in it I drive it.
Thanks so much. Did you car feel any different when the sensor was bad?
      06-22-2020, 12:39 PM   #8
Feddersen
Feddersen's Avatar
Denmark
451
Yes. It turned it self of shortly after start and was jerking at low rpms.
      06-22-2020, 12:41 PM   #9
K8_M235i
K8_M235i's Avatar
Drives: CM E36
Okay, so very similar.
I found this code today too, stored in the ekp.
      06-22-2020, 12:45 PM   #10
Feddersen
Feddersen's Avatar
Denmark
451
Sound like mine. My mechanic told me that it was tricky to find because the error pointed him in the direction of the fuel pump but didn't find any problems. When he did a manual test (don't know how) of the pressure sensor it reported values totally out of range. Including negative values which could sound like your error reading.
K8_M235i476.50
      06-26-2020, 03:09 PM   #11
K8_M235i
K8_M235i's Avatar
Drives: CM E36
Just an update:
Dealer replaced the lpfp. We'll see how it is tomorrow.
      09-16-2020, 05:13 AM   #12
vango14
Drives: F22 220i MSPORT
***New to the forum - Just got my first 2 series last week***
I had this exact issue on my wife's old 1 Series.
Turned out to be a £10 relay that controls the auxiliary fuel pump. Sits in behind the back left passenger seat.
The old one was quite hot to touch when I removed it. I removed the plastic cover there was clear evidence of arcing.
Hope my first post provides some help!
K8_M235i476.50
