12-20-2017, 11:16 PM | #45 | |
Rep 281
Tpeterson156.50 |
12-21-2017, 07:06 PM | #47 |
Rep 281
12-21-2017, 07:19 PM | #48 |
Rep 525
Sort of. I guess I'm going to have to check mine just in case. I feel like I have unnecessary noise sometimes, but it's more of a slightly muted thud than clicking.
12-22-2017, 03:26 AM | #49 |
Rep 1,161
stupid question coming up.
does it matter which way up the springs go.??
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
12-22-2017, 12:02 PM | #50 |
Rep 1,184
12-23-2017, 07:43 AM | #51 | |
Rep 1,161
2014 M5
12-26-2017, 04:41 PM | #52 | |
3726
Rep 3,632
Front struts Cross-brace screw - 56Nm +90° (replace screw) 3x strut bearing screws (if M8 thread) - 30Nm +90° (replace screws) 3x strut bearing screws (if M10 thread) - 56Nm +90° (replace screws) Pinch bolt - 44Nm +90° (replace bolt and nut, tighten down with suspension in normal position) Shock absorber to top bearing - 64Nm (replace nut) Rear Shock absorber to camber arm - 100Nm +90° (replace bolt and nut, tighten down with suspension in normal position) Camber arm to wheel carrier - 165Nm (replace nut) Torque Conversions: 30Nm - 22ft lb 44Nm - 32ft lb 56Nm - 41ft lb 64Nm - 47ft lb 100Nm - 74ft lb 165Nm - 122ft lb Last edited by aerobod; 12-26-2017 at 04:47 PM.. |
wfujay19.50 |
03-14-2018, 09:18 PM | #53 |
N54 to N55
66
Rep 308
Hey going to tackle this in a few days, I purchased a 1/2in socket set but just realized there 12point sockets and not 6point will they still work? Also I should be purchasing metric and not SAE correct?
03-15-2018, 12:28 AM | #55 |
Rep 225
Make sure you get all the tools you need in this thread. The pinch joint spreader is key. I didn't think I needed it - big mistake. Also I had a rear bolt(s) that was e-torx but 12 point worked.
18 340i F30 mostly stock |
este66.00 |
03-15-2018, 07:47 AM | #56 | |
N54 to N55
66
Rep 308
cool thanks for the info, Yes I seem to have the majority, were you able to find the pinch spreader at any local stores? |
03-16-2018, 03:05 PM | #58 |
Rep 225
I couldn't get a pry bar in there. At least not the one I had. Best option is probably eBay although ECS I think has them. During my installation I was in a bit of a bind so took an angle grinder / grinding wheel and made one from a 2" extension. Worked perfect.
este66.00 |
03-18-2018, 10:10 AM | #59 |
Rep 986
Iv used this kit multiple times on a few m235s. I like the design better than the socket style. Having the right tools makes the job way easier
https://www.amazon.com/gp/aw/d/B004W...KIL&ref=plSrch https://m.ebay.com/itm/ASTRO-PNEUMAT...ty!08054!US!-1 |
casper83119.00 |
03-21-2018, 11:50 AM | #60 | |
Rep 221
ER DP, MPE, ER CP, IC, JB4, Dinan springs
11.624@119.75mph |
04-25-2018, 11:25 AM | #62 |
Rep 4
Nice detailed post. I've been thinking about getting Dinan Supplemental Ride Quality & Handling Kit for BMW for my 230i.
Question about the springs, can they be used to lower the car more then 1/2 inch? Last edited by Sidm; 04-26-2018 at 04:53 PM.. |
05-05-2018, 01:05 PM | #63 |
Rep 525
Thank you very much for the DIY! Got mine done this weekend. Took me quite a bit longer. I had a heck of a time getting the struts out and then getting everything back together. Lots of wiggling and raising, lowering the jack to get it lined up to put bolts back through.
08-14-2018, 08:55 PM | #65 |
Rep 350
Yes you should.
2016 m235i RWD 8spd 2016 Mazda CX-5 Past - B6 Audi A4 |
05-18-2019, 12:33 AM | #66 | |
Rep 23
