05-28-2014, 11:14 AM | #1 |
Rep 110
no oil/engine temp gauge
since the 2 series doesn't have an oil/engine temperature gauge, how do you know when it's safe/ideal to drive the car hard?
05-28-2014, 11:16 AM | #2 |
***** noob
1402
Rep 10,477
IMO
On a hot summer day...4-5 minutes Cold winter..10min
2006 325xi (Sold)
05-28-2014, 11:20 AM | #3 |
Rep 8,942
+1 I follow the same general rule, with the addition to never drive it hard before you finish your break-in and the oil has been changed. I am not enough of an engineer to tell you 100% if that shit really matters or not, but what's the harm in being careful for a few weeks? Nothing to lose, potentially something to gain.
05-28-2014, 11:22 AM | #4 |
Rep 139
05-28-2014, 11:27 AM | #5 |
Rep 5,582
I do believe on a lot of cars particularly Asian cars, engine temp GAUGES are actually switches where they will always go to the same position just below the half-way point. Only when coolant sensors in the engine sense a problem two things will happen: in the first less severe case the temp gauge goes to HOT, more severe event the engine will not turn back once stopped until it cools.
So usually a three to five mile sedate drive will get enough heat into engine oil and gear oil to start getting on it. You can also add in a few more miles before hitting red-line and extended top speed. Just my opinion and not some BMW suggestion. |
05-28-2014, 11:42 AM | #6 |
Rep 269
Use the hidden menu in the gauge cluster for water/oil temp. It takes me almost all of my trip to work to be close enough to be operating temperature. That's 15-20 minutes, depending.
That's lucky for me because the last few miles of my drive are 4 lane twisties with little traffic! |
05-28-2014, 11:44 AM | #7 |
Rep 110
another question that comes to mind also is that how would we know when to stop pushing the car hard. meaning we can't also tell whether the car is at the brink of overheating until we get a warning on the dash.
05-28-2014, 11:47 AM | #8 | |
Rep 110
05-28-2014, 12:00 PM | #9 |
Rep 9,160
Yep, five minutes will barely get your coolant warm and the oil will still be well under 200 degrees for a few more minutes. 10-15 is a better guideline.
05-28-2014, 12:15 PM | #10 |
Rep 1,115
Hold the trip odometer button for 5 seconds until it comes up, using the trip unlock button to scroll down to unlock, put it the sum of the last 5 digits of your vin, hold the trip unlock button, it will unlock a bunch of options including temp display.
05-28-2014, 12:21 PM | #11 | |
Rep 269
Unfortunately (or not, I guess), this mode ends as soon as you turn off the car. |
05-28-2014, 12:25 PM | #12 |
***** noob
1402
Rep 10,477
Ok lets take a step back.
Unless you're at a track where u need to push the car to its limits...u dont have to warm up 15min for some street spirited driving, sure its the safe way but oils today are made to protect the engine at all levels. If you need to redline all the way to your destination, by all means warm her up The temp sensors are indirect sensors so i doubt it really takes 15min
2006 325xi (Sold)
05-28-2014, 12:47 PM | #14 |
Rep 216
This is not the case in my 135 - it reports actual temperature. This model is supposedly the successor to the 135, hence why so many are upset that it is missing from the 2.
05-28-2014, 12:52 PM | #15 |
Rep 192
05-28-2014, 12:57 PM | #16 | ||
4986
Rep 10,210
Drives: 2024 Golf R / 718 SRS (on way)
Past rides: 2022 718 Spyder, 2022 MINI JCW, 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
05-28-2014, 01:46 PM | #19 | |
Rep 5,582
My 240sx had the switch style temp gauge. Once you know it's not a real gauge it's useless except for a problem - There may have actually been three settings on the Nissan gauge. Normal. Hot and 3/4 position - but not certain. |
05-28-2014, 01:59 PM | #20 |
4986
Rep 10,210
05-28-2014, 02:03 PM | #21 | |
Rep 333
