PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
BBS CH Question
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
02-12-2014, 06:36 PM | #1 |
Rep 1,511
Drives: 2014 i3 BEV
BBS CH Question
I have a 2006 330i E90 with the stock 18" 162 style rims. I have a line on a set of BBS CH's that are the following spec;
BBS CH -front: 8.5x18, ET 35 -rear: 10x18, ET 40 I don't know enough about rims and tires to answer the following questions. I would appreciate if someone could help answer them; 1. Will they fit my car 2. What size tires will I need TIA.
OMG! Born Electric 10/17/2018!
2014 I01 i3 BEV 2011 E91 328i xDRIVE TOURING | 2010 F83 X3 3.0i xDRIVE | 2006 E90 330i 6MT (Ret) |
02-12-2014, 06:44 PM | #2 |
764
Rep 10,033
Well if your car is on stock suspension then they should fit fine without any rubbing but if your car is lowered than i believe your rears might have to get rolled.
As far as tire sizes go, a lot of people run these specs with a 235/35 in the front, and then a 265/30 in the rear. but these are the sizes that will stretch your tires.
TiAg FTW! |
02-12-2014, 07:01 PM | #3 |
Rep 1,511
Drives: 2014 i3 BEV
Thanks! I have stock suspension. What do you mean by "stretch your tires"?
02-12-2014, 07:10 PM | #4 |
764
Rep 10,033
alright, so since your car is on stock height i'm pretty sure that you wont need to get your fenders rolled and what i meant when i said "stretch your tires" is that if you decide to go with the tire sizes that i listed then your wheels will poke out a little bit from the tire
TiAg FTW! |
02-12-2014, 07:11 PM | #5 |
Rep 1,511
Drives: 2014 i3 BEV
Ahhh. Got it. Thanks!
02-13-2014, 12:28 PM | #6 |
BimmerPost Supporting Vendor
2051
Rep 25,989
Front and rear specs look fine. No modification is necessary.
We recommend a 235/40/18 and 265/35/18 tire on those.
VMR|Wheels | 714.442.7916 |
02-13-2014, 05:38 PM | #7 |
Rep 1,384
18x10et40 will be fine in rear you won't need to do any modification. make sure you get proper alignment after new wheels and tires are installed
02-13-2014, 05:57 PM | #8 |
Rep 1,511
Drives: 2014 i3 BEV
Thanks for the input guys!! Much appreciated.
02-13-2014, 06:38 PM | #9 | |
Rep 1,699
Drives: BMW E60/E82/E90/E92/F10/F30
They will fit onto your car without any rubbing issue, you can even put in spacers to make it more flush. The recommended tire sizes are 235/40/18 Front and 265/35/18 Rear. This set up will be the best if you want to lower your car later without having any rubbing issue. -Eddie @ Xsthetic |
