BMW 3-Series (E90 E92) Forum
Smoke, Catless Downpipes & replacement PCV Valves
08-27-2013, 03:46 PM | #1 |
Rep 2,796
Quick question or two if I may.
Having fitted VRSF downpipes I had the odd issue where every now and again(usually after a motorway type run) after re staring the car I've had smoke from both tailpipes for a good few minutes(it eventually goes away and its seems bluey white if you follow me and there's aoil smell for sure) I've got a suspicion that I've got an issue re both the turbo(possibly seals)but this may of been going on for sometimes and was somewhat masked by the then fitted Cats. I've done what I can to keep everything in check by installing a Burger Motorsport Catch can to reduce the known 335i issue re oil consumption which is more of a preventive measure and one of caution. Therefore once I get the phone call to the warranty company sorted and the downpipes pulled off to check the turbo's, which I'm fully expecting to show signs of a problem these will hopefully get replaced. The next preventive issue is regarding trhe final part of my question and that's the murky world of the PCV valve. I've read a bit about the standard offering and it seems that Rob Beck in the States offers a quality and a well respected replacement item, but I also noted that over here Forge either direct or through dealers like Turbo Dynamics offer. Any help, thoughts re any of the above would be very welcome Thanks for reading Steve |
08-27-2013, 04:17 PM | #2 |
Rep 793
I've got the Rob Beck PCV valve on my car. I can blow through the standard item half of the time when it seats, so for the cost, it was a no-brainer for me.
I'm running an AR Design OCC, for which I've had to upgrade the hoses as the standard items started weeping oil after a few thousand miles. What do you think of the quality of the hoses with the BMS kit?
2021 G21 M340i XDrive | ACS springs and spacers
Previously 2019 VW Golf GTI Performance | H&R rear ARB Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1 |
08-28-2013, 02:16 AM | #3 |
Rep 2,621
I have the RB PCV and bms occ. No problems thus far..
The occ works great - oil in the inlet side and completely dry outlet hose.. For the price you can't really go wrong!
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
08-28-2013, 02:32 AM | #4 |
Rep 3,828
Drives: AzuriteBlack 335i E92
Hmmm sorry to hear about your turbo issues mate! I am doing the same...
I do not know how i have missed stories re: the PCV... could one of you give me a brief run down of the issue this causes and how the RB PCV Improves on the original? Huge Thanks |
08-28-2013, 03:17 AM | #5 |
Rep 2,621
Do a google search for:
"Advanced N54 PCV discussion and upgrade" In another forum hence I cant link.
08-28-2013, 05:59 PM | #7 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
is it compulsory to change the pcv valves when getting downpipes?
08-29-2013, 03:48 AM | #8 | |
Rep 2,621
08-29-2013, 03:56 AM | #9 |
Rep 2,621
From Rob:
"What the leaky PCV valve means is that when you are in boosted conditions, the "highly" pressurized PCV valve leaks turbocharged pressures into the crankcase. Pending on the condition of your PCV valve, it could leak worse than others. I believe the unit I tested is in very good condition, yet still leaks and therefore I am not impressed. Also what I have found is that if for some reason your valve cover is loose or has a bad gasket, you also could develop a pressure leak either external to the engine or internal into the crankcase causing further pressurization of the crankcase." zltm089 - No not related to downpipes or mandatory by any means..
08-29-2013, 05:09 AM | #10 |
Rep 9
I have the problem but now have solve it because I have change this all and replace a new one into my car.
Be yourself and drive and fetch the happiness in your life !
______________ "Five Star Car Rentals www.fivestarcarrentals.com.au 40 French St Eagle Farm, Brisbane, (07) 5575 5400" |
08-29-2013, 06:08 AM | #11 |
Rep 4,088
I'm guessing you already know this but will say anyway for the benefit of others - if your turbo seals are bad and causing the smoke, the PCV valve replacement isn't likely to help your problem.
Still a good thing to do as insurance, as you inferred. |
09-01-2013, 04:15 AM | #12 |
Rep 793
Direct from Rob, but via a different forum rather than his site...
09-01-2013, 04:41 PM | #13 | |
Rep 2,796
I'm also going to change the rocker cover gasket as well as this has just started to weep oil meaning that the gasket has come a little dry and crispy. All being well I'll also have the car in the air and the pipes off in the not too distant future looking into the smoke to check for signs of oil leakage from the turbo's, but as I have a vast amount if waste gate rattle going on at the moment chances are they'll be changed once the warranty company are on side. |
09-02-2013, 02:24 AM | #14 |
Rep 2,621
Change all your vacuum hoses at the same time!
09-02-2013, 12:56 PM | #15 |
Rep 2,796
09-02-2013, 02:47 PM | #16 |
Rep 793
Pair? Do you mean one of the PCV valves for the internal loop and one of the external check valves?
09-08-2013, 03:53 AM | #17 | |
Rep 2,796
Anyway [/URL] As you might be able to see things have moved on a stage, having seen blue like smoke mainly out the rear off side pipe the other day along with a very noticeable oil burning smell I've immediately and rightly pulled the car off the road, the oil residue on the offside rear pipe(as per picture)is as you can see very noticeable, the smoke so I'm told, when I've been followed also comes out the near side pipe, but nothing like the plum of smoke from the offside pipe. Spoken to the warranty company, cars due to be stripped over the next day or two. While this is going on a small rocker cover gasket leak will also be done the PCV valve purchased will be fitted, I'll also have a look at what residue is laying in the catch can as well. Shame really but hey that's life, personally I think the issue re the smokes gone on before the does pipes were replaced, chances are they'll of masked the problem. |
