F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Where are you guys mounting cameras?
Extreme Powerhouse
      08-04-2013, 12:58 AM   #1
JN1
JN1's Avatar
301
Drives: S211 AMG E63
I've noticed exterior mounts create way too much wind noise and you can't tell hand movement/braking, etc.
Where are you all mounting interior cams without having roll ages, harness bars?
-JustinNApproved
      08-04-2013, 10:16 AM   #2
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
Underside of sunroof glass.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      08-04-2013, 11:14 AM   #3
JN1
JN1's Avatar
301
GoPro?
-JustinNApproved
      08-04-2013, 12:35 PM   #4
AZ330FZL
Drives: 2012 335i Sedan Sport Line
Suction cup GoPro mount. Will stick to anything flat up to 150mph.
      08-04-2013, 11:44 PM   #5
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
Wtf is up with the new app? I cant post video/photo correctly with [u2b, etc]. Ill repost from computer.
I have a gopro mounted to a DIY headrest mount. You can google it. Its $5 total to make.
Heres a video.
I mount an external mic next to my license plate with the gopro suction cup mount.
http://i580.photobucket.com/albums/s...D25F7CD4AF.jpg
      08-05-2013, 12:50 AM   #6
Forgiven
Forgiven's Avatar
No_Country
122
Drives: 22, X5 45e
Good vid! That was fun watching
G05 - M Performance roof spoiler
      08-05-2013, 01:26 AM   #7
JN1
JN1's Avatar
301
Definitely a good video! Love the POV. Thanks for the advice, will most likely do that. I've driven Buttonwillow for drifting events and its one of my favorite tracks. I definitely need to be on track with an instructor and get my lines down, I'm all over the place.
Just found this. It's relatively inexpensive and looks easy to remove/reinstall as needed. http://www.smercengineering.com/onli...era_mount.html
-JustinNApproved
      08-15-2013, 01:00 PM   #8
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
I like outside behind the sunroof, angled down. Set the GoPro on spot mode for exposure, and make sure the center line hits the pavement and not the car to get the correct exposure.
I can see my hands and head (LOOK AHEAD!!!). I use my iPhone and TrackAddict HD with an ELM327 WIFI obd2 unit and a Dual GPS150A Bluetooth GPS sender to get good GPS data. I use the audio from the iPhone
I also like it for autocross b/c the angle lets you see how close you're coming to the cones on each side
I've also had success with the GoPro using the skeleton back with a Micover stickover wind-screen, furry grey thing that covers the holes in the skeleton back
This angle is also useful when comparing lap to lap video as the interesting part of the video is on 50% of the screen. It's easy to crop without scaling and stretching the video
This audio isn't representative, as it's just the GoPro audio with the full sealed case on
      08-15-2013, 01:01 PM   #9
utenigma
What External mic is that?
      08-15-2013, 01:08 PM   #10
pkimM3r
pkimM3r's Avatar
205
Here's me quoting myself on m3post. I went a little in detail since when I was researching, there wasn't many threads with detail about the whole setup.
I've searched so many times for a setup that worked before going through a few different mic setups ($20 to $150 setups) so I will post a pretty detailed and cheap and effective way for a pretty decent setup.
As far as some action cams, here is a comparison on a few (im sure these same companies have newer versions now so maybe search for the newest available - but its a starting point):
http://gizmodo.com/5965732/the-best-action-camera
I decided on a gopro hero 3 silver and this is my specific setup:
DIY head restraint mount close to this one ($5 total). The only difference is I used a T-joint on the end of the pvc pipe and placed the adhesive mount on it. I will post a picture of my setup when I get the chance but this is what I followed.
http://www.mazdaspeedforums.org/foru...gopro2-100933/
This is the mic I use (Sony ECM70 - $50 from Frys and you will need the stupid usb mic adapter from gopro, why did they do this? another $20) and I made a windsock using the tail of a fox of a toy from petco ($3) and i put it next to the license plate through the center pass with an extension chord ($10):
Coupled with the windscreen and using the gopro suction cup (is it $30?) which I already had, and it looks like this:
The settings I use are either 1080/960p (depending on how much time i need of recording) with 11mp wide angle with spot setting ON (you need this so looking out the windshield the sunlight doesn't cause it to just look white - youtube spot setting and it will show the difference).
This is the result (and it makes the stock exhaust sound awesome imo ):
      08-15-2013, 01:15 PM   #11
utenigma
Neat, I was thinking of an external mic setup - even thinking about putting it in the air-box to see what kind of induction note I could get in there. Does that Sony mic work plugged into an iPhone?
      08-15-2013, 01:18 PM   #12
pkimM3r
pkimM3r's Avatar
205
i would think it would work as a mic as long as the iphone software reads it as a mic.
      08-28-2013, 03:27 PM   #13
ronin951
ronin951's Avatar
44
Drives: 2013 328i M-Sport
My setup is in this thread: http://www.f30post.com/forums/showthread.php?t=882296
I tip I got this weekend was to mount in the wheel well facing the suspension. I thought that was a neat idea.
      08-28-2013, 03:55 PM   #14
pkimM3r
pkimM3r's Avatar
205
no sound in that video though lol
      08-28-2013, 09:22 PM   #15
ronin951
ronin951's Avatar
44
Clearly you don't have your volume at 150% Yeah I was really bummed. I had the wrong gopro case. Just imagine a little tire squeal around the corners and wind on the straights. Oh, and trash talk about all the high end cars being poorly/not driven. What a waste.
Your sig pic says it all.
      08-29-2013, 12:04 PM   #16
pkimM3r
pkimM3r's Avatar
205
Yeah when I had the closed "underwater" case the sound was horrible - basically it was all wind.
The CTS-V, who was cleary a beginner and signed up for the red group (due to ego - I have a fast car), which is an instructor/advanced level, open passing group and causing massive traffic, which not only ruins the day for everyone else in that group, is just flat out stupid, and dangerous. Hence, my WTFFFFFFF, and don't be the CTV-S. This was not, "ok , he is driving pretty decent and I'll pass him", this is pretty much, "you are parked in the middle of the track, what were you thinking signing up for this group" type of stuff. And then the idiot in the CTS-V, being a beginner, does not let the other driver pass on the straight, he actually tries to drag race him down the straight! There are two videos in the thread below. No one should be the CTS-V guy, ever. It was such a funny video, and a good lesson to learn for beginners that i had to pause the video, take a screenshot, and edit as my sig.
(I did get permission from the guy driving in the video though!)
http://www.m3post.com/forums/showthr...end+in+his+own
      08-29-2013, 09:02 PM   #17
ronin951
ronin951's Avatar
44
Yeah, I always worry about being "that guy" during the open session. Usually I pit when I catch myself driving with my mirrors. It's too bad there's not enough time in the day to split out run groups by not only driver level, but car hp/speed. This past weekend we had a blue group that had spec GT-R and GT3's mixed in with 944's and miatas. I was actually glad to be in green.
That CTS-V driver should have been black flagged much less not allowed in the group...though I see there were other circumstances that allowed him in. The funniest thing is he's clueless as to what he did and gave you permission to use it.
      08-29-2013, 10:15 PM   #18
pkimM3r
pkimM3r's Avatar
205
Oh no i got permission from the camera car. Gtr. The ctsv guy isnt on these forums lol.
      08-30-2013, 06:27 PM   #19
vwong
vwong's Avatar
Drives: All Euro
This was where I mounted mine when I had only 1 camera. Now that I have 2 cameras, I mount one outside on the top center of the front windshield, and the other one inside pointing at me. The camera on the outside is connected to an external mic that is located at the rear license plate area. When I get home after a track day, I use RaceRender to sync them all together. I think the external mic is the best way to capture good sound. Just take a look at my video below. This was with a STOCK S4 exhaust.
2010 Audi S4 6MT
2009 BMW 335i Coupe 6MT
YouTube Channel
      08-30-2013, 06:54 PM   #20
pkimM3r
pkimM3r's Avatar
205
Sup vwong. I had the black f30 with cca back when it was the infield only setup. I got the same mic you used after multiple setups and $$$ and it seems the best!
You coming on sep?
      01-07-2014, 06:13 PM   #21
LDSM
LDSM's Avatar
Drives: ...
Thumbs up
Heres a video.
Great video, great sound!
Subbed on youtube
      01-30-2014, 06:17 PM   #22
nfwb11
nfwb11's Avatar
Drives: '14 435i M-Sport - SB
Reviving an old thread here but…. anyone figure out if/how to feed GoPro images into the iDrive display?
f30post
