F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Track/DD alignment
ARMA SPEED
      08-02-2013, 12:16 PM   #1
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
I'm having my car aligned after I installed the H&R sport springs a few weeks ago (waited for them to settle)
I've settled on the following alignment targets
0.1 degrees toe out in the front
0.2 degrees toe in in the rear
-2.0 degrees camber in the rear
I'll post the results from the hunter when I'm get them. I'm doing an Autocross class this weekend then another Autocross the following Sunday. I'll let you guys know what I think of the settings.
Anybody else F'd with their alignment yet? Anyone have a spec they like that they want to share?
      08-02-2013, 02:23 PM   #2
utenigma
Ok, done
Front camber (because of the H&R Sports) has increased neg camber from -0.4 to -0.6 degrees - gotta love lower
Front toe set to 0.15 degrees of total toe out
Rear camber read -1.5 degrees, we were able to get -2.0 degrees with no problem
Rear toe is now 0.20 total toe in
Car does feel a little more eager to turn - we'll see how it goes tomorrow
(btw, front/rear initial readings
Front 0.24 degrees initial toe in
Rear 0.47 degree initial toe in
ridiculous)
      08-03-2013, 11:42 PM   #3
Forgiven
Forgiven's Avatar
No_Country
122
Drives: 22, X5 45e
Originally Posted by utenigma View Post
Ok, done
ridiculous)
Sweet as, that's similar to my set up!
G05 - M Performance roof spoiler
      08-04-2013, 08:27 PM   #4
utenigma
Autocross went really well - I could defiantly tell a difference in the slalom elements. Direction changes were much quicker and very balanced
On the freeway there's little change. It's no longer dying to go straight forward all the time, but there's not enough toe-out to make the car darty by any stretch of the imagination. Defiantly acceptable for daily driving.
Steering input at lower speeds seemed to lightened up with the new alignment, about back to where it was before I put 245's on the front.
As for tire wear, it was every bit as hot this weekend as it was last month - my front tires last month showed over 200 degrees internal temperature, this time they didn't get over 165. In fact when we'd been working the car quite a bit, both the front's and rears were within 5 degrees of each other (instead of the gross imbalance we saw last month)
Forgiven, what spec are you running?
      08-05-2013, 12:36 AM   #5
Forgiven
Forgiven's Avatar
No_Country
122
Drives: 22, X5 45e
Car is all stock except OE Camber bearing installed onto DHP M sport suspension.
Front Camber
Driver side: -.93 deg
Passenger : -.77 deg
Front Toe : .1 deg on both side out(edit)
Rear Camber
Driver side: -2.1 Deg
Passenger : -1.95 Deg
Upcoming/ordered: Yoko ADVAN 245/40/18 will be slap on OZ Alleggerita HLT 18x8.5
      08-07-2013, 09:48 AM   #6
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Sounds great - never thought about it before, but the fact that the tire temps were consistent is probably a really good empirical indication of the car's overall balance when pushed hard... very encouraging
Are you running a square set-up with 245s all around?
What is this exactly? I have heard of the OE -30min front knuckles (which add -0.5 degrees of camber) - is this what you did as well, or something else?
      08-08-2013, 09:45 AM   #7
utenigma
Yes, 245/40/R18 Bridgestone RE-11As on all four corners
http://www.f30post.com/forums/showthread.php?t=831520
      08-08-2013, 09:49 AM   #8
utenigma
Yeah forgiven has that on his car
To avoid confusion, BMW calls that part a "Swivel bearing"
      08-08-2013, 10:32 AM   #9
DVC
DVC's Avatar
Drives: 335i
Looks like the front camber numbers are stacking up pretty consistently:
Stock: -0.4
Lowered ~ 1": -0.6
Stock height/camber bearing: -0.9
So I guess with the camber bearing as well as an inch of drop, I could expect about -1.1 degrees of front camber.
With regard to the rear camber, would you guys advise dialing in as much as possible during the alignment? I read somewhere that the ideal would be to have front camber numbers equal to (or even exceeding) rear camber numbers, but maybe that's only practical for a skilled track driver on a track-only car (?)
To that end, with the camber settings at > -1, would you still advise a square wheel/tire set-up? Or would a slightly wider rear be appropriate with more front camber?
      08-08-2013, 12:10 PM   #10
utenigma
If we had camber plates, I'd be running about 1 degree of camber less in the rear than in the front
Assuming I could get there, I'd run -3.0 in the front -2.0 in the back and stick with the square setup
Unless you're drag-racing it's front-end grip that we need to make the car balanced. Too much rear grip and the cars get pushy under power
I agree with this guy's take for aligning e36 M3's
http://forums.bimmerforums.com/forum...or-your-E36-M3
Weight bias on the F30 and suspension geometry isn't significantly different. The 335 is a little more nose heavy which puts even more importance on front-end grip. Until we get plates and test though, it's all a theoretical conversation.
      08-08-2013, 01:46 PM   #11
DVC
DVC's Avatar
Drives: 335i
Great post by that link - thanks. (I didn't see it in the write up, but I assume the author probably runs a square setup... )
So it seems like adding -0.5 degrees (or even 2-3x more than that) of camber is certainly not enough to warrant looking for more rear tire width.
Is there any reason why you haven't gone with the OEM camber bearings yet?
* Edit: Just posted an update on the Camber Plate availability thread
      08-08-2013, 11:52 PM   #12
Forgiven
Forgiven's Avatar
No_Country
122
Drives: 22, X5 45e
Front Camber
Rear Camber
Changed my tire order to BF Goodrich Rival Very excited, it should be the stickiest street tire!
      08-09-2013, 09:14 PM   #13
ronin951
ronin951's Avatar
44
Drives: 2013 328i M-Sport
Very interested in your second weekend results. I have m-perf suspension and going square 235/40/18x8.5 next week. Have a 2 day DE in 2 weeks, so this info is invaluable. Thx for your OP
      08-15-2013, 03:50 PM   #14
ronin951
ronin951's Avatar
44
Updates?
      08-15-2013, 07:24 PM   #15
utenigma
Originally Posted by ronin951
Updates?
It went well. Turn in is crisp, nice balance, you can really steer the car with the throttle.
This is my fastest, got a little ornery and overshot turn 2. Overall I thought the run was sloppy compared to my others-it was my last run so I was hanging it out. Even with all that crap, it was my fastest run. This car likes to be driven like a hoon apparently
Need to work on my driver mod, I know I left at least a second out there
      08-19-2013, 11:37 PM   #16
pkimM3r
pkimM3r's Avatar
206
Drives: m3 saloon in granny mode.
Daily use will kill the tires though with toe out.
      08-20-2013, 12:26 PM   #17
utenigma
Not true, all things being equal any toe (in or out) causes tire wear. The 10 minutes of toe out I'm talking about are less than the 14 minutes of toe in the factory suggests.
And all things are rarely equal - when a wheel has negative camber as ours do, a little toe out actually reduces wear as the toe counter-acts camber thrust, reducing rolling resistance.
http://en.wikipedia.org/wiki/Toe_(automotive)
f30post
