BMW 3-Series (E90 E92) Forum
Wastegate rattle cover by bmw used warranty
06-20-2013, 03:09 AM | #4 |
Rep 793
Keep in mind that the BMW NA (US) warranty on this is different from BMW UK, but if the car is under the Approved Used warranty, you shouldn't have any problems - I had mine changed under the extended Insured warranty with no fuss. Just expect to be without the car for a couple of days!
2021 G21 M340i XDrive | ACS springs and spacers
Previously 2019 VW Golf GTI Performance | H&R rear ARB Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1 |
06-20-2013, 07:57 PM | #5 | |
Rep 81
06-21-2013, 02:16 AM | #7 |
Rep 793
BMW's process for changing the turbos involves removing the engine from the car, so the dealer needs to know what they're doing. I only use Sytner Chigwell these days - I had some bad experiences with Stephen James when I first bought the car so I don't trust them with things like this.
06-21-2013, 06:09 PM | #8 |
Rep 966
I had my turbos removed and wastegates adjusted in first few months of having my Mar 07. Sure they didn't remove engine. Only comments were for Wastegate actuator being below spec diameter and replaced waste gate actuator and reset using vacuum.
06-22-2013, 04:47 AM | #9 |
Rep 793
You can replace the actuators without removing the turbos. I'm sure it's possible to change the turbos without removing the engine too, but I think it's quicker to drop the subframe, so that's what BMW tell them to do.
