F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Any Overheating or Limp Mode Issues For F30 On Track?
GetBMWParts
      02-04-2013, 04:19 PM   #1
JMK007
Drives: 335 M Sport, RWD
The e90 335i has some well-documented issues with overheating and/or limp mode on the track. I think they even referred to it as the "Limp Mode Party" or something. In any event, does anyone have experience with whether the F30 has any tendency to overheat or go into limp mode on track (whether the 328 or 335)? Whatever your experience, good or bad, please give as much detail as possible, including:
1) whether the car is a 328 or 335;
2) climate conditions (e.g. temperature outside, exessive humidity, high altitude...etc.);
3) number of consequentive minutes on track;
4) whether the temp guage moved;
5) perceived heat soak / loss of power over time; and
6) particular track set up for your car including whether there is any software upgrade, aftermarket radiator or intercooler....etc.
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09
Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11
Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19
      02-04-2013, 05:26 PM   #2
scott@bmwhn
Drives: Msport X3
I just had a track day this past weekend as well as one back in October, conditions were about the same.
2013 328i
80's - mild - sea level
4 x 15-20 minute sessions split my 40 minute cool down in between
didnt pay much attention to the temp gauge
no limp mode
no noticable heat soke
no engine mods
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      02-04-2013, 05:54 PM   #3
mocohead
mocohead's Avatar
54
Drives: '16 M235i 6MT & 12 128i Msport
328i
80's to 90's at sea level
4 20 minute sessions with a couple of hours between groups
no limp mode
no overheating
stock car
      02-04-2013, 06:33 PM   #4
DaaamnGina
Drives: E30 325ix, F30 335ix
  • 2013 335i xDrive M Sport
  • Elevation ~5000 ft. High Plains Raceway, Colorado
  • Temperature 50-60F, Low humidity
  • Sessions - 5 x 15-30 minutes
  • Breaks - 20-30 minutes with engine hood open
  • Gauge showed around 240F when I looked
  • No perceived loss of power
  • No limp mode
  • Stock setup
      02-05-2013, 12:59 AM   #5
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
328i
Multiple track days 4 runs each 20-25 minutes. Anywhere between 60-80 degrees on different days.
1-2 hours in between.
No power loss no limp mode. Oil temp guage didnt even budge. Tires. Different story. Ha.
Bone stock baseline model. Heated seats are nice when tracking. Anyone else try? Lol
      02-22-2013, 03:56 PM   #6
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
Originally Posted by pkim1079 View Post
328i
Sorry to threadjack...but how were the brakes? I'm taking mine out once it clears up.
      02-23-2013, 12:03 PM   #7
JMK007
There is a thread on this in the tracking section. However, we certainly need more info and experience on the topic of brakes on track.
      02-26-2013, 12:35 AM   #8
pkimM3r
pkimM3r's Avatar
205
328i
Brakes are pretty good but i am not braking at the latest possible moment. At times i will but my focus is on getting the car balanced and set up before turn in.
      05-05-2013, 09:30 AM   #9
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
An inline 6 is impossible to cool when supercharged or turbo charged. There's no way to get sufficient cooling to the last two cylinder to evacuate heat fast enough. That's why Dinan's tune for the N54 and N55 specifically address this by increasing water pump speed FIRST. During testing they found that even at moderate increase in boost, cylinder 5 and 6 were showing signs of hot-spotting. The problem isn't solvable without significant investment into multiple cooling cores for oil and a MASSIVE radiator. I would be surprised if the new M3 does not come with at least 4 oil coolers and some form of upgraded water pump and radiator, if it does come in a tri-turbo inline 6. And I would be surprised if the 335 does not continue to suffer from limp mode induced by insufficient cooling.
The turbo charged 4, on the other hand...should be far more efficient in that regard.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
      05-06-2013, 08:34 AM   #10
mocohead
mocohead's Avatar
54
I have run the stock brakes four times now, both with street tires and with r-comp's. They are not as strong a proper track brakes, but I had no issues with fade or warping. But as a cautionary note - I knew I was on stock pads, so I drove accordingly. I just started braking a bit earlier and more gently than I would if I was actually racing or running track pads with proper cooling.
The f30 328i is really solid on the track. Just take it out and enjoy!
      05-16-2013, 06:47 PM   #11
DarkTrigger
Professional
DarkTrigger's Avatar
Drives: 335i MPPK
1) 2013 335i M Sport
2) Mid 90's
3) 20-30
4) Each time Pegged at 250 degF
5) Zero Loss of power (to my amazement since I've had limp mode just driving around town before)
6) MPPK
      05-27-2013, 07:11 PM   #12
Accelerometer
Accelerometer's Avatar
Drives: 11 E90 M3 ZCP
I'm surprised the stock F30 brakes hold up to track use. I did a mild track day recently in the M3 and after a few laps the pedal wanted to hit the floor.
      05-27-2013, 08:26 PM   #13
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
2013 335i M Sport
50-60f
15 minute session with 15-20min breaks
No issues
MPPK
Brakes felt fine ( upgraded M-Sport brakes in Canada/i.e. not the US brakes on M-Sport cars )
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      06-10-2013, 10:38 PM   #14
SergioK
Drives: F30 328i
Buttonwillow last Friday. Temps around 100f, ambient! Several F30s with N20 engines and zero limps. It felt like 120 though with the humidity. Ick!!
f30post
