F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Diesel break in procedure?
Studio RSR
      10-18-2012, 07:15 PM   #1
TF30Z
TF30Z's Avatar
42
Drives: BMW 320D F30
I was wondering if the break in for a diesel car is any different from petrol? My 320d is coming in next week and the manual only mentions gasoline do not exceed 4500rpm.
Thanks.
      10-18-2012, 07:25 PM   #2
BavarianFanatic
Too much is never enough
Drives: Too Many
Follow the same guidelines. The primary thing for the motor is to avoid cruising at sustained revs for long periods. Though it's not really that much of an issue for any new car these days as far as the motor is concerned. It's more important to go easy on the brakes than anything else.
      10-18-2012, 08:08 PM   #3
TF30Z
TF30Z's Avatar
42
Right thanks.
      10-18-2012, 09:24 PM   #4
J1n
Drives: R8 V8 '14
My manual states 2000kms I wonder if its because it's petrol
      10-19-2012, 03:24 AM   #5
TF30Z
TF30Z's Avatar
42
What are the repercussions of not breaking in properly?
      10-19-2012, 04:39 AM   #6
NISFAN
NISFAN's Avatar
United Kingdom
3489
Drives: BMW M2
The engine? ....Nothing it has already been run flat out on a dyno. As has been mentioned better to run at different engine revs and loads than steady state cruising.
The Brakes? Not bedded in will not give full braking force, but not really a big issue on 'street' pads. Bedding in correctly only takes 5 mins and involves 5-10 slow downs from 60mph-10mph gradually getting harder on the brake application. Don't come to a stop until the brakes have been given the chance to cool.
Tyres? Still have mould release agent when new, so loss of grip for first 20miles, especially in the wet.
Everything else? Nothing specifically requires bedding in just warm everything up as you should normally then drive like normal.
      10-19-2012, 04:47 AM   #7
MikeVictor
Australia
210
Drives: anything given a chance
http://www.f30post.com/forums/forumdisplay.php?f=437
      10-19-2012, 07:09 AM   #8
darmawaa
Drives: 2017 M2
4500 in petrol is equivalent to 3000rpm in diesel
f30post
