PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
Will an offset of 20 fit an '07 335?
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
08-14-2012, 11:28 AM | #1 |
Rep 487
I'm sure there are other threads that may break this down, but I'm looking for a quick answer before I purchase some wheels. The wheel sizes are 18x8.5f/18x9.5r w/an offset of 20 all around. The lady who sells them are adamant that they won't fit (of course she's not into the mod scene). Also, the tire sizes are 225/35f - 255/35r.
Help w/a quick answer!!!
08-14-2012, 12:13 PM | #3 |
Rep 487
225/40 is what I currently have. I just thought /35 would look better and match the rears.
BTW, could you explain what offset is and if there's anything I should be aware of when going w/something other than stock? I think I have an idea and I will still google it. Just wondered if you/anyone had a short version.
08-14-2012, 12:26 PM | #4 | |
BimmerPost Supporting Vendor
2051
Rep 25,989
Also in terms of tire size, the tire profile is a percentage of the width. So a 255/35 will sit taller than a 225/35 even with the same profile. Hope this helps you out!
VMR|Wheels | 714.442.7916 |
08-14-2012, 12:31 PM | #5 | |
Rep 487
08-14-2012, 12:40 PM | #6 |
Rep 2,823
Donīt know for sure, but you might need to roll your rear fenders a little bit with 9.5 et20 and 255/35/18. Otherwise it might rub sometimes.
I have 18x9.5 et 20 and havenīt rolled my fenders, but i have 235/40/18 at rear.Im lowered with HR sport and no rubbing. |
08-14-2012, 12:46 PM | #7 | |
Rep 487
08-14-2012, 12:48 PM | #8 |
Rep 487
Also, should I remove the 12mm-f/15mm-r spacers and will I be able to re-use either the stock bolts or the long ones currently used w/the spacers?
On the other side of this - these wheels are made for 5/7 series. Does anyone know if I'll need hubcentric rings and if so, what size?
08-14-2012, 12:55 PM | #9 |
Rep 2,823
You canīt really know will it rub or not before you drive with that setup.
Even i canīt be sure that my setup wont rub if i drive with full load. Ride height is one thing which affect the possibility to rub. |
08-14-2012, 01:11 PM | #10 | |
Rep 2,823
Your car hub bore is 72.6. You need to ask the seller what is the hub bore size. Some 5-series have 74.1 like BMW E39. |
08-14-2012, 01:18 PM | #11 |
Rep 487
After hitting "send", I realized that the spacers will have to come off - pushes them out way too much. But I would probably need to use the extended bolts? And, that bore size issue is a pain! There ought to be a chart somewhere that shows every models' bore size, offset, etc. for those who are interested in going outside the OEM-box.
08-14-2012, 01:30 PM | #12 | |
Rep 2,823
You probably can use stock bolts. Depends of the bolt shape Stock bolts are conical seat atleast with 3-series. Ask what bolts seller is using.If he/she uses stock bolts you can probably too, depends at shape of the bolt seat. There isnīt that many models with 74.1mm hub bore, but if the wheels are aftermarket it still could have different hub bore even if the seller car is 72.6 This you need to ask from seller. Are the wheels original bmw? Last edited by MonacoBlueE90; 08-15-2012 at 11:43 AM.. Reason: There was incorrect info |
08-14-2012, 02:05 PM | #13 |
Rep 487
The wheel hub is 74.1 and rings are included.
08-14-2012, 04:31 PM | #14 | |
General
1571
Rep 29,202
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
08-15-2012, 11:49 AM | #16 |
Rep 2,823
