BMW 3-Series (E90 E92) Forum
Retrofit cruise control
03-07-2012, 07:26 AM | #2 |
Squadron Leader (Ret'd)
25
Rep 627
Plenty on this can be found on the babybmw forum e.g. this thread.
http://www.babybmw.net/viewtopic.php...etrofit+cruise In short it can be done and if you use an indi you should just about be able to do using new parts withing your budget. You are looking at closer to £800 with a dealer and DIY with used parts a lot less. If you are going down the route of used parts you need to be sure the car it came off has the same setup and slip rings etc. Even if you fit it yourself, you will need to find an indi with Autologic to code it. |
Ali-E90381.50 |
