BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Harmon Kardon vs Hi-Fi Sound System
      02-02-2012, 08:39 AM   #1
jamot
South Africa
Drives: Ford Fiesta
Hi Everyone,
Is the difference between Harmon Kardon system vs Hi-Fi Sound System vastly noticeable?
Is the Harmon Kardon really worth the extra cash you pay for it?
      02-02-2012, 09:26 AM   #2
Underwood
BMW > Audi+ Merc. Simple math.
Underwood's Avatar
Sweden
34
Drives: 14' Wrangler
yep
      02-02-2012, 12:15 PM   #3
Occean
Drives: 1 series
I have I only heard the standard and hk systems.
I have the hk, and I'm quite into my audio and it really is a top system, one of the best incar system I have heard. If I had to have one option, this would be it.
      02-05-2012, 11:59 AM   #4
airblade550
United Kingdom
Drives: F20 118D Auto Mineral Grey
I had the pro hu and the std speaker system with my E87 which I soon upgraded via the Alpine route... I always assumed that the BMW Business speaker system was on par with the Alpine, ie tweeters in the mirror housings in the front doors... However, after checking in the options spec list, http://www.bimmerpost.com/goodiesfor...lequipment.pdf, it would appear that tweeters are not included in business pack for the F20 just mid-range speakers front/aft/dash with two woofers... You have to specify the HK system to get any real, "HiFi" potential, which is what I spec'd for my new F20 expected in March...
      02-06-2012, 09:29 AM   #5
Sonnig
Drives: F20 118i Sport
Is the HK hifi system available to add after if I did not order it with my car?
      02-06-2012, 09:37 AM   #6
me11ada
United Kingdom
Drives: 2011 1 Series F20 118D Sport
Hi Sonning, check with your dealer if it hasn't entered it's build phase then you can as it's what I did, if it has an upgrade may be possible once it arrives but will probably cost more - hope that helps
      02-08-2012, 01:40 AM   #7
Fanis
Fanis's Avatar
Greece
53
Drives: 116i (F20) Auto
The professional Hi-Fi is not that good. I have it in my car and I can barely notice any difference compared to the standard one...it is nowhere near in audio quality compared to the Professional Hi Fi I had in my E46. If I could order the car again, I would either pay for the HK or keep the standard one...the HiFi is not worth it.
2011- : BMW 116i (F20)
2009-11: BMW Z4 2.5si (E85)
2007-09: Mini Cooper S (R56)
2005-07: BMW 325ti (E46)
2004-05: BMW 318i (E36)
      02-08-2012, 12:44 PM   #8
LUV2XLR8-NL
LUV2XLR8-NL's Avatar
Netherlands
Drives: BMW 116i Business Sportline
I had HK in my 2005 MINI Cooper...it was great in all sorts of music!
Everything will be okay in the end. If it's not okay, it's not the end.
      02-09-2012, 12:35 AM   #9
jamot
South Africa
Drives: Ford Fiesta
Thanks. Everyone has been very helpful.
I'll go for the HK.
      02-09-2012, 05:24 AM   #10
AlpineVert
AlpineVert's Avatar
Drives: 2012 135i vert
And just to make sure you don't have any buyer's remorse.
The HK is fantastic. It's my favorite option.
      02-09-2012, 04:10 PM   #11
Doubleyou
Doubleyou's Avatar
Netherlands
Drives: 2012 BMW 116d F20
I have tested all 3 systems at the IAA in Frankfurt last September. HK is really super! But I decided for the Hifi Active as I think this is also a very nice upgrade. The standard system is not bad but I could really hear the difference. I had a limited lease budget so I decided that the Active system was good enough and spent the difference with HK on other options . You can not have it all...But if you can: take the HK!
2012 BMW 116d F20 in Mineralweiss with Oyster
      02-10-2012, 10:12 AM   #12
Sonnig
Thanks me11ada, I be checked that in Hong Kong, I can upgrade the system to an Alpine system via BMW dealer. But kardon must be ordered with the car.
      02-11-2012, 11:42 AM   #13
padishah
padishah's Avatar
Turkey
Drives: F20 1.16i
Is it possible to upgrade pro system to harman kardon ? Or does it need more holes for speakers?
      03-13-2013, 07:50 AM   #14
MI35i
Drives: M135i
I am getting business loud speakers in my car as don't have to pay extra... HK is £580 (Bit steep). If I get hold of the HK centre (mid range), HK front door (mid range) and HK rear shelf speakers would they just straight swap over? Not interested in faffing with changing amps adding tweeters etc.
I assume they are all same size/fitment and same connectors? Just better quality speakers? Might work out a decent upgrade without much cost/effort.
PS from what I can gather, the individual speakers are around £40 each so poss total upgrade around £200
      03-13-2013, 08:15 AM   #15
Bradbury
Vroooooom!
Bradbury's Avatar
Norway
Drives: F20 120d
I had standard speakers in my E87 and HiFi in my current F20. Honestly I don't notice much of a difference. Then again, I'm not much of an audiophile. I was content with the standard speakers, so I probably wasted money on the HiFi (wish I'd gotten the speed limit camera instead).
      03-13-2013, 11:21 AM   #16
airblade550
United Kingdom
i would be surprised if you complete the speaker upgrade for that price, (using genuine parts), unless of course u have access to a friendly parts dealer.
The main differences between HK and Pro are Amp power, eq, tweeters front and rear and of course better quality and higher power handling speakers.
In addition to the HK speakers, (if u choose the genuine upgrade path), would be mouldings front and rear plus some kind of x-over to filter the low frequences from the tweeters.
As has already been mentioned, the Pro is missing any tweeters and as you have mentioned you are not so worried about power. Therefore, the most cost effective and least hassle upgrade is just to add tweeters at the front only. You would still need the mouldings and x-overs but it would be much cheaper and a worthy quality increase. Better still to get some third party tweeters which would fit the mouldings and prob come complete with suitable x-overs.
Whilst the other speakers, door and parcel shelf would be better, it is unlikely without the xtra power supplied by the HK amp, that u would notice much of a difference...
      03-13-2013, 11:48 AM   #17
tawia
tawia's Avatar
United Kingdom
26
Drives: F21 125d
Back in my day, I seen me paying £600 for a poxy alpine CD head unit, then having to buy speakers amps and subs, then the hassle fitting and wiring everything. HK system for £550... Was a very easy choice. And loving it
      03-13-2013, 02:29 PM   #18
F20MAW73
440i Gran Coupe, Auto
United Kingdom
877
Drives: 440i GC
Lol very true.... But it was fun though
Z4M40i Black Sapphire
      03-13-2013, 02:45 PM   #19
MI35i
Drives: M135i
I believe with hifi in general, you get a bigger increase in sound quality from upgrading speakers as to upgrading amps so i think the doors and rears might be worth a shot for little cost. The business amp is fairly powerful anyway. This is the part for rear shelf + centre (mini i know but same part no). It gives an idea of the cost.
http://www.minigenuineparts.co.uk/mini-parts/info_BM65_13_9_169_690.html
If i decide to do this il report back.
      03-13-2013, 04:54 PM   #20
orcomma
Dividing by zero
orcomma's Avatar
United Kingdom
54
Drives: F48 X1 XDrive20d xLine
as one of the dying breed of audiophiles, and the owner of the standard system due to it being f*g overpriced, my two pence says that the construction of the door card and in particular the ability of it to cope with pressure differential in front of versus behind the speaker cone is the most important factor. "its all about the housing"
also Harman International aren't what I would call a premium speaker brand. Neither are the bose ones audi plonk in. Put in something from B&W or Castle and I will consider it.
      03-13-2013, 09:42 PM   #21
tawia
tawia's Avatar
United Kingdom
26
Drives: F21 125d
I'm an audio engineer, went through several years of education, have a trained ear and have many hours listening to the best of the best monitors in very expensive treated studios. perfect listening condition you just don't get anywhere else. I agree, Bose are just a marketing success, but for the money the HK system is very good. I have tested it with my usual reference material and altho not perfect, its very good and gets a thumbs up. At this price its a bargain and would recommend to anyone.
      03-15-2013, 04:52 PM   #22
orcomma
Dividing by zero
orcomma's Avatar
United Kingdom
54
at least we agree on bose
1addicts
