BMW 3-Series (E90 E92) Forum
bmw 335i cylinder 1, 2, and 3 misfire, HELP !!!
01-13-2012, 02:08 PM | #1 |
Rep 6
I have a bmw 335i (jz94496), have a 4 fault code (at the same time)
29cd combustion misfire cylinder 1 29cf combustion misfire cylinder 3 29ce combustion misfire cylinder 2 29cc misfire several cylinder I have changed 6 injectors 6 sparkplug 6 ignitioncoil I done the update for software it is ok exhaust system ok (catalitic convertor look clean and good condition) comprossion test ok (6 cylinder is same) hpfp is ok (I have test it with autologic) and today is put the new one. oxygen sensor look is ok (before the cat reading 2volts, after the cat reading 0.4 volts) I removed inlet manifold, I cleand the carbon from tract and valves (it is full of carbon) I done the check engine ecu with cas and key the other car it is ok but problem is same. Can does this problem when engine its hot and when rpm is between 1800-3000. Please can you help me. Thanks |
01-14-2012, 06:43 PM | #2 | |
Rep 111
Is your misfire intermittent? Or is it constant? Update us on any info?
2006 330 Premium Package AT Steptronic
03-29-2020, 07:15 PM | #5 | |
Rep 26
I have the same problem with my car misfiring cylinders 1 2 3 thank you. |
03-29-2020, 08:21 PM | #6 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
I'd be curious to see what index you have in bank 1 and in bank 2. Misfires usually means: A) bad spark plugs B) bad coils C) bad injectors |
03-29-2020, 09:40 PM | #7 | |
Rep 26
I change the bank 1 injectors used not new code all the injectors but still have misfiring cylinder 1 2 3 and swap injectors from bank 2 to bank 1 codes don't move to bank 2 check dme for bad mosfets they are ok |
03-30-2020, 09:45 AM | #8 | ||
Rep 6,968
Do you have a valve cover gasket leak? Are the plugs in 1-3 really black? How old are the plugs? You said you put in used injectors? I wouldn't be swapping injectors! Unless you redo the seals after pulling them & before installing them again, that alone could cause problems. |
03-30-2020, 11:49 AM | #10 | |
Rep 26
valve cover gasket its ok I bought used injectors on ebay yes I put new seals in the injector and coded the injectors with inpa. still the same. |
03-30-2020, 02:19 PM | #11 | ||
Rep 6,968
03-30-2020, 06:10 PM | #12 |
Rep 26
03-30-2020, 08:14 PM | #13 | |
Rep 6,968
I bet the used injectors might be your problem |
03-30-2020, 08:50 PM | #14 |
Rep 26
03-31-2020, 06:27 AM | #15 |
Rep 6,968
I'd encourage you to buy them from FCP Euro. You get a lifetime warranty with them.
03-31-2020, 06:33 AM | #16 | |
Rep 6,968
Hopefully, this will help I'm leaning on Mosfets https://www.e90post.com/forums/showthread.php?t=1473788 |
03-31-2020, 07:52 AM | #17 |
Rep 6,968
Here is a place you can send the DME to be repaired if you are not comfortable soldering
https://n54dmerepair.com |
03-31-2020, 06:21 PM | #18 |
Rep 26
[QUOTE=mweisdorfer;25990319]Here is a place you can send the DME to be repaired if you are not comfortable soldering
https://n54dmerepair.com[/QUOTE thanks for the info they're already replaced the mosfets to hear that sometimes replacing the mosfets will fix the problem but no luck . |
03-31-2020, 09:25 PM | #19 | |
Rep 6,968
[QUOTE=tello2020;25992875]
