BMW 3-Series (E90 E92) Forum
Flat tire alert on IDrive
10-20-2005, 07:26 PM | #1 |
Rep 873
I have a E90 with sport package, the flat tire alert went off as I was traveling to work. I don't know if the tire pressure is just low on the tires or if there is actually a puncture hole somewhere on any tire, but what I can externally see on the right front tire is a moderately size bump on the side wall of the tire. Does anyone know the specific tire pressure (PSI) for a 330i with sport package.
BTW on all the tires the PSI reads 23, except for the rear right tire reads 34 PSI. Thanks in advance for the help! |
10-20-2005, 07:29 PM | #2 |
419
Rep 12,276
I would suspect the bump. You should get it to a service location and have it checked out. Also, 23 is way low (about 10 PSI too low).
I think it is bad luck to be superstitious |
