PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
19x9.5 +25 and 19x11 +25 .. need tire help !
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
10-10-2011, 09:49 PM | #1 |
MOE
214
Rep 2,530
If im going with 19x9.5 + 25 front and 19x11 + 25 rear, what tires should I go with? Looking for an aggressive stance, however I dont want to rub much (after of course rolling my fenders)
and for cambers, what degrees should I go rear/front? pretty much, how can we make this work thanks
10-10-2011, 10:08 PM | #2 |
Rep 1,007
225/35
265/35 What're you lowered on? The rears can be adjusted to -3.1 on stock adjustments. The front...depends on what coilovers you have or if you have camber plates. But..should work with -2.5 or -3...But camber you can mess around with after you get the tires on and mounted
10-10-2011, 10:22 PM | #3 | |
MOE
214
Rep 2,530
I will be lowered most probably on KW V1
10-11-2011, 12:42 PM | #5 | |
Rep 6,092
10-11-2011, 12:43 PM | #6 |
Rep 5,367
10-11-2011, 12:50 PM | #7 | |
Rep 3,879
You would most likely want to run a 225/35/19 front tire and a 245/35/19 rear tire to keep the stretch even and allow for the most fender clearance in the rear end. Front camber should be -1° and rear camber -2° maybe a few points more, but again this will vary depending on your suspension setup (height, stiffness, ect) |
10-11-2011, 01:00 PM | #8 |
MOE
214
Rep 2,530
Im being told I cannot run this set up and it is impossible to do so,
I may have to go at it with 19x8.5 front and 19x10 rear, 235/35 and 275/30
10-11-2011, 01:06 PM | #9 |
Pro Hater
49
Rep 1,717
10-11-2011, 01:13 PM | #11 |
MOE
214
Rep 2,530
so can I run this set up without rubbing against fenders/shock/spring?
No offense but I just want to know how you know so I can be at ease with doing it
10-11-2011, 01:17 PM | #12 | |
Rep 3,879
If your game, I am happy to help make it work |
10-11-2011, 03:36 PM | #13 |
Pro Hater
49
Rep 1,717
10-11-2011, 04:17 PM | #14 |
Rep 458
im going to preorder a similiar setup 19x9.5 +20 19x11 +25 will need stretched tires, fender roll and negative camber but it WILL work. where in la u located im going to get these wheels hopefully by end of next month
10-11-2011, 07:30 PM | #16 |
MOE
214
Rep 2,530
what set up are you running?
10-13-2011, 12:24 AM | #18 |
Rep 281
Here's what I've seen work
19x9.5 225/35/19 19x10.5 or 11 245/35/19 This still allows for a drop And I've never ever seen anyone running these specs with out a drop. Lol Some will still need a little camber Oh man your car is going to look sick!! Keep us posted. |
10-13-2011, 12:31 AM | #19 | |
Rep 5,530
