BMW 3-Series (E90 E92) Forum
Parking Brake gets tight then loose then tight
06-02-2011, 09:44 AM | #1 |
Rep 18
Hi All,
Did a quick search on the forums and believe this may be related to the hill assist feature on my 2006 330i MANUAL w/sport package, but couldn't get any further than that. Here's what happens: The parking brake becomes very tight one day (I can only pull up 1 - 2 clicks) then randomly loosens up another day (3-5 clicks.) What bothers me is that I can't seem to determine why it changes so frequently. It is usually is in the (3-5 click range) but will randomly feel SUPER tight and stiff other days. Any ideas? I'd say it switches back and forth a few times a month. Thx! S |
06-02-2011, 11:10 AM | #2 |
Rep 1,730
Same thing happens to me in my 335 auto...
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
06-02-2011, 11:13 AM | #3 |
Rep 7,089
Drives: '06 AW 330xi
The car prevents the hand brake from locking up the wheels when your driving...at least that's what i have observed. My car usually is loose the first time I pull it, then it tightens up after I release it then pull it again.
06-04-2011, 12:17 PM | #4 |
Rep 284
Mine is all over the map too, and I haven't found any real pattern. I had my local shop look at it three separate times when I first got the car because in some cases I could tell that it wasn't quite releasing fully. Best I could get was a short term improvement, so I've simply turned a blind eye to it. Of late, it now produces a loud metallic squeal if the car moves at all while it's set, but aside from an initial slight roll, it does hold. It baffles me how a company can build a car where so many things work so well, yet a simple handbrake can't be built to work correctly and reliably.
06-04-2011, 02:39 PM | #5 |
Rep 7,089
Alot of people don't reset the tension in the hand brake cable after changing rear rotors...this is probably why you guys are having these problems.
06-04-2011, 03:57 PM | #6 |
Grozniy
179
Rep 2,602
do you know how to reset the tension?
-fatman
