BMW 3-Series (E90 E92) Forum
DTC: How does it work?
03-04-2010, 07:04 PM | #1 |
I pretend to be smart.
20
Rep 237
How does DTC limit slippage?
Does it limit the throttle, does it transfer power from a slipping wheel to the other wheel(s) at the diff, or does it apply the brake to whichever wheel slips? Does it use a combination of these methods? Are all modern 3-series engineered to accomplish this in the same way? Thanks in advance. |
03-04-2010, 07:09 PM | #2 |
Rep 746
in short it cuts power from the engine until the wheels are back in sync (front and back). it wont allow the rear wheels to spin, it will cut power before this happens... Also, there is DTC and DSC...
DTC wont allow for wheel spin period... DSC wont allow the car to slide when taking turns.. when you press DTC once... you turn DTC off which will allow for wheel spin, but if the back slides DSC will cut in take away power and apply braking... yes braking is applied to my knowledge... i have only had this vehicle but i am going based on research and reading numerous threads... Search... is your friend... but i hope i was able to help...
2009 BMW 335i Sedan / Auto / Paddles / Sport / BMW Assist / Heated seats / JB Matte Black Grill / Tischer First Aid Kit w\Triangle / Tischer Hood Pad / "Custom" rear fog switch <---- SOLD!!!!
03-04-2010, 07:21 PM | #3 |
Where'd my VTEC go?
481
Rep 6,067
Actually, pressing the DTC button once turns DTC ON. The message in the iDrive shows "DTC activated, DSC limited!"
Turning ON DTC allows for some wheel spin. The default mode is DSC fully on. DTC is basically a synonym for restricted DSC (think of it sort of like M-dynamic mode for non-M cars). So by turning on DTC you are turning off part of DSC. Pressing and holding the DTC button will turn everything completely off.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
03-04-2010, 07:23 PM | #4 |
you know he kills little girls like you
390
Rep 892
03-04-2010, 07:32 PM | #5 | |
Rep 1,190
DSC will use DTC and also limit engine power as well as selectively braking any wheel to stop the vehicle from going sideways. That includes the front wheels. here is a video that describes the features.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD Last edited by DJKhan85; 03-04-2010 at 07:39 PM.. |
03-04-2010, 07:34 PM | #6 |
Where'd my VTEC go?
481
Rep 6,067
To answer the OP's question, in full DSC mode the computers will cut power and brake individual wheels to try to restore traction and keep you going in your intended direction.
The system does not have any torque vectoring capabilities to power the opposite wheel. xDrive in the X6/X6M/X5M does have torque vectoring (Dynamic Performance Control) though.
03-04-2010, 07:56 PM | #7 |
Rep 746
i stand corrected.. i had some of the stuff right though... hehehe...
still learning...
03-04-2010, 08:03 PM | #9 |
Rep 403
Do our 3 series have ESP?
My Ferrari 458 experience http://www.e90post.com/forums/showthread.php?t=738262
My McLaren MP4-12c experiences http://www.e90post.com/forums/showthread.php?t=794746 http://www.e90post.com/forums/showthread.php?t=939740 |
03-04-2010, 08:39 PM | #10 |
20
Rep 237
03-04-2010, 08:47 PM | #11 |
Where'd my VTEC go?
481
Rep 6,067
Yeah, almost every company has their own acronym or name for stability control. ESP, ESC, DSC, VSA, VSC, VDC, etc, etc
03-04-2010, 09:25 PM | #12 |
Rep 1,190
Glad I could help guys. You should try out each mode(DSC,DTC, and all off) in an empty parking lot in the rain or snow. It's really astounding how the car handles differently in each mode. It's really like driving another car. If you mange to lose control with DSC on, well, you're boned lol.
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
03-04-2010, 09:28 PM | #13 |
Rep 1,190
if you have a march 08+ vehicle then you have whats called an eLSD. It functions sort of like DTC except it doesn't cut engine power and just uses the brakes to try and modulate power between both wheels. It is a "feature" of the 1 series that BMW later slipped into the 335's.
03-04-2010, 10:25 PM | #14 |
Joyride
Rep 71
Drives: 2007 335i | Black/Black/Alum
So why would you need to turn DTC on? It's on by default, you need to deactivate it by pressing once and/or holding for DSC & DTC off. Hence the warning lights on the dash.
When i want to launch hard, press once == allows for wheel spin, when on by default, not pressing anything, power is cut when wheel spin is detected.
2007 335i Coupe | MT | Black/Black/Alum | Sprt + Cold + Prem pkgs
03-04-2010, 10:31 PM | #15 |
Where'd my VTEC go?
481
Rep 6,067
DTC is not on by default. DSC is on by default.
03-04-2010, 11:23 PM | #16 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
03-04-2010, 11:30 PM | #17 |
Rep 778
03-05-2010, 05:55 AM | #18 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
Just hope we dont have the same electronics as a lexus and we will be fine
DOH! TOO SOON? And I have only used the DTC ON feature a few times on snowy roads and it works awesome as well as the AWD set up on my XI
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i ProGaMeR on the XboX 360 |
03-05-2010, 07:12 AM | #19 |
Dismembered Member
3610
Rep 9,213
I actually didn't know how to differentiate between the two until reading a lot of the very insightful comments on this thread. It actually works pretty well in the snow (with DTC enabled, which I seemed to have found out the hard way). Thanks guys
My delivery experience and beach photoshoot here. |
03-05-2010, 08:10 AM | #20 |
Rep 959
Again, DTC is deactivated in normal conditions. DTC can be useful in winter weather conditions because some winter tires may need more wheel slip for maximum traction. With DTC off the car will restrict the wheelslip and not allow for the maximum traction.
03-05-2010, 12:24 PM | #21 |
Joyride
Rep 71
So everyone says it's OFF by default. What happens when you, start car, rev motor to 4000 RPM and let out clutch? Engine cuts power to try and regain traction, at least it does in my car. Every time! Same thing happens when accelerating on bumpy road and traction become unstable
Do the same thing by pressing the DTC button, light shows up on dash, allows for wheel spin, no power is cut. Unless DSC engages... Maybe it's terminology.. but the function i'm describing is correct?
03-05-2010, 01:07 PM | #22 |
Joyride
Rep 71
Ah.. i guess i've never heard of a traction system that allows for More wheel-spin then normal everyday driving. To me, wheel-spin means less traction. But oh well..
Thanks!
Tags |
dtc, traction |
