Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Problem with gear shift
Reply
      01-07-2010, 11:43 AM   #1
toady
Drives: 335i '08 coupe
I'm driving a '08 335i coupe, automatic. The other day I was driving in sport mode and then suddenly when I was accelerating (I wasn't manually shifting) it felt like the gear was 'in between gears' and the exhaust was making a deep pitched rumbling noise and the car was shaking a bit. When I pressed on the gas it would aggravate the symptoms and actually the car wasn't accelerating that much even though I was pressing on the gas pedal. So I had to pull over, turn the engine off, and when I restarted it everything was fine. Has this happened to anyone and if so, what is the problem and solution? Thanks in advance.
      01-07-2010, 03:56 PM   #2
E92_328i_Boston
Drives: 2008 E92 328i
That sounds more like the dreaded fuel pump than a transmission/gear issue to me.
-A
Reply
