PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
Need wheel spacers?
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
10-28-2009, 02:51 PM | #1 |
Rep 41
Need wheel spacers?
I have E93 with BMW Performance Wheels Style 269. (8J x 19 225/35 R19Y front; 9J x 19 255/30 R19Y rear)
Do i need to get wheel spacers if i change suspension set to KW V1? |
10-28-2009, 04:54 PM | #3 |
thestream.tv
120
Rep 3,134
+1 if you want the flush look then get spacers if you like the tucked in look then you do not need spacers..
10-28-2009, 05:18 PM | #4 |
Rep 41
Last time when i installed FK coilover, my wheels touch the coilover spring slightly without spacer.
Is it possible installed KW V1 without the spacer? |
10-28-2009, 06:21 PM | #7 |
Rep 797
Drives: E92 335, E36 Ti, Porsche 986
Depends on how low you will be running your coilovers. When I ran my v2s on a super low setting, the ride height adjuster would rub against the front wheel on a 19x8 et35. Once I raised it up so that the ride height adjuster was no longer at the same level as the wheel I was fine. The rears won't be an issue though. I'd pick up a set of 5mm spacers and extended wheel bolts just in case. Even if you don't end up needing them they'll still make your stance look better.
Monaco Blue E92 335 - i-Forged Senekas, KW V2 Coilovers, OEM Bmw Aero lip, AFE DCI, LUX H8
Sublime Green Dodge Challenger 392 w/hellcat package. KW Coilovers, Speedlogix CAI Jet Black E36 Ti - E36 M3 drivetrain, Full M-Tech, H&R Coilovers, 3.73 LSD, M-Clubsport interior and much more... |
