BMW 3-Series (E90 E92) Forum
f**ing clunking sounds
08-31-2009, 11:56 PM | #1 |
Rep 172
hi guys i have 08 335i sedan i lowered the car with H&R race springs on stock struts..when i turn the steering wheel it makes a clunking noise..some of my friends say the spring isnt sitting good(installed springs 1 year ago)and some of my friends say that my struts are gone...any help will be great..thanks
09-03-2009, 05:56 PM | #4 |
SCCA B Street
117
Rep 660
Could be either anti-roll bar (sway) endlinks or the mounts. Just tighten the endlinks and test. If you still have an issue, the mounts would be next. Find which corner is making the noise by riding in the trunk or replace as a pair.
02-24-2010, 09:48 AM | #6 |
Rep 296
Drives: e92 328xi
Did you every fix the clunking sound?
02-25-2010, 01:45 AM | #7 |
Vorstiener
17
Rep 364
Drives: 07' e90 335
also could be a loose lower or upper control arm too.. I was hearing a clunking sound when turning at low speeds and brought it back to my friends garage and they looked and it and said it was a loose lower control arm.
| 2007 335 e90 | KW V3 | AR DP | ICONZ | AFE | JB3 | VORSTIENER | MTEC | 3D DESIGN | SNOWS | STETT | FORGED DV | VANGUARD | GODSPEED FMIC | |
02-25-2010, 05:53 AM | #8 |
Rep 2,979
Drives: 07 SBM E92 335i 6MT
I really hate it when the OP doesn't come back and post the outcome....cause then you do a search and get all happy when you find a thread about your problem...and then you get to the end...and NO SOLUTION!!
02-25-2010, 11:29 AM | #9 |
Rep 1,906
Drives: black 335i e90 PRE-LCI
might help some people: http://www.e90post.com/forums/showth...teering+column
02-25-2010, 01:09 PM | #11 | |
Rep 7,952
op got a set of v3's
02-25-2010, 03:53 PM | #12 |
Rep 1,906
+1
03-21-2010, 05:12 PM | #14 |
Rep 4
Just installed H&R sport springs on factory sport struts clunking noise!!
I just got new H&R sport springs installed on my 2007 e90 with stock sport struts and every time i go over a little bump there is a loud clunking noise froming from the left front wheel. Not sure if my right side makes the clunking noise also but has anyone faced this problem?
