BMW 3-Series (E90 E92) Forum
TPMS on e91?
08-24-2009, 09:58 AM | #1 |
Rep 822
TPMS on e91?
I have just taken delivery of an LCI 335i touring and am going to pull the trigger on a set of aftermarked wheels for it.
I am unable to get a concrete answer for my local dealer whether my car uses TPMSs on the wheels. It is my understanding that cars with metal valve stems are TPMS and cars with rubber valves use a different system - mine has rubber so I'm presuming not. Is this correct? |
08-24-2009, 10:01 AM | #2 |
Rep 8,095
Yes. It uses ABS sensors so you don't have to worry.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
08-24-2009, 10:41 AM | #3 | |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
08-24-2009, 01:20 PM | #4 |
Rep 7,519
Drives: 2009 E90 335i MT
If all else fails, have someone look inside the tyre. Requires breaking the seal and then rebalancing the tyre but you'll absolute know for certain. If you're really interested it's probably worth the £10.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
08-24-2009, 03:48 PM | #7 |
GT3
47
Rep 1,679
my VMR wheels have come from the States and they are fitted with the tpms be interesting to see if the cars computer pics them up when I fit them.
PORSCHE GT3
08-25-2009, 02:16 AM | #8 |
Rep 8,972
Reading stateside stuff on their TPMS, the US cars have extra pickup sensors mounted in the wheel arches along with additional cabling and equipment etc for it to work.
08-25-2009, 06:08 AM | #9 | |
Rep 6,912
Getting back to the point, it seems that it is quite difficult to get a non-BMW metal valve to fit some rims, so I carry a couple of spares!
E92 M3, Jerez Black, Fox Red Novillo, 19'' M Double Spoke, folding mirrors, lumbar support, front seat heating, PDC, USB, DAB, EDC, Bluetooth, Logic 7, High Gloss Shadowline, big smile
08-25-2009, 07:29 AM | #10 | |
Rep 822
What did people do before e90post? (other than talk to their wives/girlfriends during an evening) |
08-25-2009, 07:36 AM | #11 | |
Rep 4,302
Drives: M135i
VW were slightly better but not a lot. Strangely Suzuki are very good - but expensive. |
08-25-2009, 03:02 PM | #12 |
Rep 7,519
If your car is set for the ABS rotation rate method then it will use that whether you have the TPMS in the wheels or not.
08-25-2009, 03:25 PM | #13 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
I can well believe dealers not knowing this....well, the front line staff anyway.
Someone in this lineup of first contact personell within the dealership should be fully product trained. Muppets.
08-25-2009, 04:43 PM | #14 |
Rep 522
Its a bit hit and miss. My local dealership is generally pretty good, but they do have one guy looking after the parts department sometimes that can't even figure out how to use the computer. So very little hope asking about anything out of the ordinary unless you have the part number.
08-26-2009, 03:01 AM | #15 |
Rep 8,972
That's it, they are a 'parts' department, not a 'vehicle engineering' department.
Its a bit like going into McDonalds and asking them the ins and outs of the milkshake dispenser pump technology.... errmmm fries with that? Best off researching yourself first, then just go in with part numbers... ...try visiting the Church of realoem.com, its enlightening. |
08-26-2009, 09:02 AM | #16 |
Moderator
324
Rep 5,493
To give some clarification about TPMS/ABS sensors with regards to flat tyre monitoring...
The USA uses TPMS sensors in the wheels, which are mounted as part of the metal valve stem. The sensor sits on the inside of the outer rim, and relays the information to a communications module located just inside the wheelarch trim. This communications module is hooked into the MOST bus and the iDrive system uses this data to indicate the possibility of a flat tyre. In the UK, all E9x models from March 2007 onwards use the ABS sensors to determine the possibility of a flat tyre. The ABS sensors measure the comparative rotational speed of each opposing wheel to determine whether there is a substantial change in the rolling circumference of the wheel. These cars do not have the TPMS receiver module in the wheelarch, and so even if a set of wheels is supplied with the TPMS sensors installed, they are totally redundant. Incidentally, cars built before March 2007 may have had TPMS sensors - it is unclear which models have or have not, and what build dates are affected by the specification change. My own car, a September 2006 E92, uses the ABS sensors. However a friend's July 2006 E90 uses TPMS sensors.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
08-26-2009, 10:02 AM | #17 | |
Rep 8,972
08-26-2009, 10:09 AM | #18 |
Moderator
324
Rep 5,493
Correct. And there are only two ways of finding out - 1) take off the wheelarch liner to have a look if the receiver module is there, 2) take off the tyre and see if the TPMS sensor is installed!
08-26-2009, 10:13 AM | #19 |
Rep 8,095
Is there no functional difference in the i-Drive though Tony? My understanding was that the ABS warning just told you that a tyre was low but the full (sensor) TPMS allowed you to actually read off the pressure in each tyre in PSI? I'm sure the hire car I had in the US gave individual readings but I might be mistaken.
Ian
08-26-2009, 10:16 AM | #20 | |
Moderator
324
Rep 5,493
08-26-2009, 10:19 AM | #21 |
Rep 8,095
I must be mistaken then. I also drove a Buick in the US that definitely gave individual tyre pressures on the display so it is possible. The rest of the car was a POS though so I wouldn't recommend it purely on that basis...
Ian
08-26-2009, 11:33 AM | #22 |
Rep 7,519
This is true. My wheelwells have the sensors and my car needs the units in the wheels. Of course I could just remove them, go to non-runflats and when the car starts swerving all over the road with a thump, thump, thump, I'd know I had a flat tyre. I'd rather have the car tell me before the thump, thump, thump.
