Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > xDrive Suspension Compatibility List
Reply
      04-15-2009, 01:35 AM   #1
deletedelete
deletedelete's Avatar
Drives: m
~ xi/xDrive Suspension Compatibility List ~
- M3 Rear Sway Bar
- M3 Rear Bushings (2 of 33312283382 and 2 of 33312283383)
- M3 Rear Guide Rods
- M3 Rear Upper Links
- M3 Rear Lower Camber Kit
- M3 Front Strut Brace
- BMW Performance Front Strut Brace (with aftermarket intake)
- BMW Performance Springs
- BMW "i" Sport Springs
- H&R Rear Sway Bar
- H&R Bushings
- H&R Sport Springs (i and xi)
- H&R Race Springs
- H&R Coilovers (xi version)
- KW Coilovers Variant 1 & 3 (xi version) (v1 10220048 coupe/sedan, 10220049 wagon)
- AST 4100 Coilovers (custom order through HP Autowerks)
- Fortune Auto Coilovers
- Sonic Tuning Coilovers
- ISC Coilovers
- Cross Front Strut Bar
- UUC Front And Rear Sway Bars (xi version) (the M3 front/rear bushings are not compatible with these)
- Hotchkis Rear Chassis Brace
- Eibach Pro Springs
- Bilstein B8 Struts/Shocks (xi version)
- Stainless Steel Brake Lines (xi version)
- Any e9x Rotors
Notes:
* Staggered setups work
* The rear of the "xi" is the same as the "i"
* All e9x compatible spare tires work
* I take no responsibility if any information is inaccurate
      04-15-2009, 01:56 AM   #2
PKumarM3
Air India
India
145
Drives: 2018 Dodge Durango
is there a difference in kw3 application for the e90 and e92?
PKumarM3
      04-15-2009, 02:01 AM   #3
deletedelete
Drives: m
KW3 are the same for e90 and e92.
      04-15-2009, 05:59 AM   #4
deletedelete
Drives: m
So, this is the xi suspension upgrade path. Thoughts?
Stage 1:
-H&R or KW Coilovers
or
-Eibach or H&R springs with Konis in the rear. (this is what dinan does, front struts remain the same)
Stage 2:
Front and rear sways bars, rear chassis brace, front strut brace, m3 parts. (not sure which are most valuable, useless, etc)
      04-15-2009, 07:51 AM   #5
bolty
/r/trees
bolty's Avatar
50
Drives: 08 e92 335xi
Originally Posted by Prowess Symphony View Post
-OEM BMW "i" Sport Springs
If this is truly the case, then the BMW performance springs would make this list as well. I believe they'd give you a lower drop than the ZSP springs.
      04-15-2009, 08:01 AM   #6
J.P.
Close to bein Bannned
J.P.'s Avatar
Drives: Pussy Magnet
I believe the performance springs are also made by eibach.
I would just go with Eibach springs for now, and then purchase adjustable shocks when they are released.
Originally Posted by sexye92 View Post
JERRYS MOM= BEST HEAD OF MY LIFE
      04-15-2009, 02:03 PM   #7
deletedelete
Drives: m
The xi apparently has a 15mm rear sway unlike the i which has a 13mm. I was wondering if I should not get a UUC or M3 rear sway now since the install is long and hard.
For my list of stage 2 (Front and rear sways bars, rear chassis brace, front strut brace, m3 parts) is there anything that should NOT be added. Since there is a limited number of xi parts, there has to be a perfect list of what to add or not add.
      04-15-2009, 07:31 PM   #8
PKumarM3
Air India
India
145
would this set up work ?
http://www.tirerack.com/suspension/s...140&perfCode=S
PKumarM3
      04-15-2009, 08:12 PM   #9
deletedelete
Drives: m
Yup, its fine.
      04-15-2009, 09:27 PM   #10
SGxi
Drives: E90 328xi
2007 328xi  [0.00]
-M3 Rear Sway Bar
-M3 Rear Subframe Bushings
-M3 Front Strut Brace
-M3 Rear Guide Rod
-M3 Upper Link Kits
They all fit the E92 xi from the E92 M3?? what about for the E90s?
MY07 A22 E90 N52Nxi
      04-16-2009, 08:17 AM   #11
J.P.
J.P.'s Avatar
Originally Posted by SGxi View Post
-M3 Rear Sway Bar
-M3 Rear Guide Rod
-M3 Upper Link Kits
yes, would I recommend it?
not really
      04-16-2009, 10:08 AM   #12
deletedelete
Drives: m
not really
Really? Some of that stuff isnt so expensive. A bunch of m3 stuff with springs is way less then coilovers. Whats the negatives to adding the m3 stuff?
      04-16-2009, 12:59 PM   #13
J.P.
J.P.'s Avatar
cause the m3 rear suspension is engineered for a lighter weight rear wheel drive car.
      09-02-2009, 12:40 PM   #14
deletedelete
Drives: m
I thought I would bump this in case their is any new info to add.
      09-02-2009, 03:56 PM   #15
SGxi
Drives: E90 328xi
2007 328xi  [0.00]
Not entirely related, but the M3 front and rear bushings cannot fit onto the UUC front and rear sway bars.
MY07 A22 E90 N52Nxi
      09-02-2009, 03:57 PM   #16
deletedelete
Drives: m
ill add that, thanks
      09-02-2009, 09:45 PM   #17
Zink330xi
Napoleon
Drives: the TiAg Beast
I have heard KW V1s fit the XIs, but the KW website says only V3s. I have talked to a guy saying he had V1s, but all others say V3s.
What the hell? Can anyone straighten it out for me?
330XI|6M|TiAg/Schwarz|Sport|Lux|Cold|Xenon|L7
      09-02-2009, 09:52 PM   #18
SGxi
Drives: E90 328xi
2007 328xi  [0.00]
V1 is new this year on the xi.
MY07 A22 E90 N52Nxi
      09-03-2009, 10:42 AM   #19
reprod
Drives: '16 M3 ZCP
Here is an official KW link for the e92 335xi suspension
http://www.kw-gmbh.de/en/30_Products...BMW&gruppe=all
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned)
'16 Mineral Grey F80 M3 ZCP
      09-04-2009, 07:54 PM   #20
derek1822
Drives: 2009,335xi, 19" GS1...
Wink bmw dealer said.........
BMW Performance Springs... not for 335i, 335xi...
there aren't much options for E90-335xi-09.... I checked daily on the web, BMW specialist....
Seems, Dinan S-pack, or suspension system is the $$ way but not the muffler, many feel like its like made in China quality!!
KW-V3, UCC front and rear sway bars, better way then Dinan's value!
      09-04-2009, 07:57 PM   #21
derek1822
Cool bmw dealer said.........
I even questions BMW specialist why BMW performance parts not for 335i, 335xi.....
Big brake kit, suspension set.....damn all for 128i, 328i....
BMW....make a new line of performance parts for 335i.........
      09-05-2009, 08:40 PM   #22
MMOTION
MMOTION's Avatar
109
Drives: like you'll never drive again
anyone try swapping in ZSP rear shocks on a E90 330xi with h&r sport "i" specific springs and retaining original front shocks?
Reply
