Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > can is run 235/275 tires?
Reply
      03-08-2009, 12:09 AM   #1
FusionBlitzz
Drives: 535i
re960as
235/35/19 25.5 817 revs
275/30/19 25.6 814 revs
      03-08-2009, 09:21 AM   #2
halB
halB's Avatar
Drives: W211 E350 4M MkV GTI 987.2 S
You should be more than fine with such small difference between F/R wheel speeds, as long as the wheel offsets are correct so the tires won't rub. In fact this combo is one of the best available 19" staggered setup for the Xi.
07 E93 335i - Returned at lease end
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged.
09 MkV GTI w/Leather & 18" Huffs. F1 Asym
10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels
      03-08-2009, 12:59 PM   #3
deebibi
student
Drives: E90 335xi
can be the
235/35/19
265/30/19 good for the e90 335xi?
      03-08-2009, 09:55 PM   #4
halB
halB's Avatar
Originally Posted by deebibi View Post
can be the
235/35/19
Speed difference between front and rear is too close to the 1% limit for Xi. 235/275 is closer to 0.1% so it is definitely better.
      03-09-2009, 02:12 AM   #5
deebibi
student
Drives: E90 335xi
if i am runing at this size 235/265, will it hurt the x-drive computer? that is the big problem?
      03-09-2009, 06:22 AM   #6
JeffL
JeffL's Avatar
35
Drives: C63
if i am running at this size 235/265, will it hurt the x-drive computer? that is the big problem?
no. you will be fine. That is my summer set up.
235/35/19 = 25.48
265/30/19 = 25.26
difference in diameter ~ 0.217 = ~ 0.857%
No issues.
no sig.
      03-10-2009, 08:41 AM   #7
NM_BMW
Vishnu Powered
NM_BMW's Avatar
Drives: 335xi, S1000RR
Either combo will be fine for the X-drive system. I run the 235/35 275/30 on 19s and I actually have noticed my speedo is a bit more accurate then with the stock tire/wheel config.
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3
      03-10-2009, 10:00 PM   #8
TL
TL's Avatar
Drives: Happy on H&R coil overs
2008 335xi  [1.00]
what if i ran the below on an E92 335XI? should the offsets be ok and is there a rule for offsets? thanks in advance.
235/35R/19x8.5 front 40mm offset
265/30R/19x9.5 rear 39mm offset
      03-10-2009, 10:05 PM   #9
NM_BMW
Vishnu Powered
NM_BMW's Avatar
Not quite sure on the offsets for an e92. You tire size should be ok, what kind of tires are you looking at? Sizing of tires for one brand will have a different OD then another brand.
On another note, if you decide to get 275's for an e92 be prepared to roll your fenders as I have heard 275's will rub on an e92, lowered or not.
      03-10-2009, 10:34 PM   #10
TL
TL's Avatar
2008 335xi  [1.00]
Michelin Pilot Sport PS2....yea i'm def not going to run 275, it's too aggressive for me.
      03-22-2009, 09:47 PM   #11
halB
halB's Avatar
It depends on whether the tire has square shoulder (like PS2) or rounded shoulder (like Falken FK-452).
      03-23-2009, 01:46 PM   #12
Lil'G
e92
Drives: 2012 Space Gray e92xi
So do you want square or rounded shoulder if you DO NOT want to roll the fenders? And do you know if the Bridgestone Potenza RE960s are round or square?
      03-23-2009, 03:15 PM   #13
NM_BMW
Vishnu Powered
NM_BMW's Avatar
You probably want rounded. I want to say that another member tried every way to get 275's in the rear and he said no matter what you had to roll your fenders to squeeze 275's. A lot of this is probably also due to what offsets you run on the rear as well.
      03-24-2009, 01:21 PM   #14
Lil'G
e92
Yea I'm figuring there's a 5% chance that 275s would fit on an e92 without any rubbing. I'd have to get the fenders rolled and I am trying to avoid that. I still don't know if Bridgestone's have rounded or squared shoulders tho.
      03-24-2009, 02:04 PM   #15
NM_BMW
Vishnu Powered
NM_BMW's Avatar
I'm pretty sure the Bridgestones have chunky square shoulders. The Falken's have that rounded shoulder because their going for that VIP sucked look. I love my Falken FK452's though.
      03-24-2009, 06:20 PM   #16
Lil'G
e92
Ok so now there's a .05% chance of 275/19 Bridgestone's fitting without rubbing...looks like 265/19s it is...thank you
      03-24-2009, 06:24 PM   #17
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
the offset of those wheels is pretty high. You would not rub with 275's. no way will it rub with a 39 offset.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      03-25-2009, 10:06 AM   #18
Lil'G
e92
For what I've read, 275's fit on e90, but not e92 unless you roll the fenders. But your saying to go with a 39 offset and there will be no rubbing? and this is on an e92?
      03-25-2009, 08:06 PM   #19
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
19x9.5 +33 with 275/30/19 works perfectly. No rubbing at stock/sport ride height for E90's. E92's on the other hand, I would recommend going with a 265/30/19 to be safe. If you are running a +39, you should be fine.
-Charles@VMRWheels
www.vmrwheels.com
Reply
