2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Advice logs MHD stage 1 91oct/95 ron
      01-14-2026, 03:29 PM   #1
Pbdeed
Drives: M240i
Hello,
I've recently flashed XHP stage 2 and Mhd stage 1 in my m240i F22 217.
Before flashing, I got some logs stock (4th gear, sport+), where I had some occasional -3 timing correction on cylinder 1 (https://datazap.me/u/pbdeed/stock-b58?log=0&data=3-16)
Then I flashed stage1 93oct/98 ron and logs were bad (4th gear sport+)
So I used the multimap to change to the 91oct/95ron map. And decided to log with DTC OFF and in 3rd (easier in public road).
I got 3 3rdrd gear pulls (https://datazap.me/u/pbdeed/stage-1-...og=0&data=3-16) and one 4th gear pull + an additional 3rd gear pull https://datazap.me/u/pbdeed/stage-1-...r-and-3rd-gear
Summary:
Log 1 (20:51): cylinder 3 has a timing correction of 5.9
Log 2 (20:53): 0.0 in all
Log 3 (21:00): 0.0 in all
Log 4 (21:03): cylinders 2 and 5 have -3 corrections
And the log in 4th gear, all of cylinders have -3 corrections but the cylinder 2 has -6 correction.
I'm using Shell V Power 93oct/98 ron. OEM spark plugs with 2000km.
I'm worried about logs in 4th and also big corrections.
Could it be spark plug gap? Should i gap them to 0.024"?
      01-18-2026, 05:39 PM   #2
n55david
n55david's Avatar
1701
Drives: 17 m240i, 20 x4m, 15 X3 x35i
2015 X3 x35i  [10.00]
2017 BMW m240i xDrive   [10.00]
2020 BMW X4M   [10.00]
Originally Posted by Pbdeed View Post
Hello,
I got 3 3rdrd gear pulls (https://datazap.me/u/pbdeed/stage-1-95-dtc-3rd-geae?log=0&data=3-16) and one 4th gear pull + an additional 3rd gear pull https://datazap.me/u/pbdeed/stage-1-95-dtc-4th-gear-and-3rd-gear
Summary:
Stock oem gap is fine.. gapping tighter likely won't change anything at that level and will be a waste of effort. I ran whatever the stock gap is at 30psi and e45.. thats not the problem.
Where do you live?
2017 m240i xDrive 10.40@133mph w/bm3
2020 x4m 10.63@130.39mph w/bm3 ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: n55david - Youtube: @ n55david For videos or Racing etc
      01-22-2026, 07:12 AM   #3
Pbdeed
Drives: M240i
Spain
